Question about Nokia N73 Cellular Phone
N73 time and date probmlem
Whenever I turn on my N73 the phone ask me to set time and date (I don't remove battery I just turn it off and on).
  • 3 more comments
  • Milos89d Apr 02, 2008
    I know ,but it allways resets my clock when ever I turn it on, the phone first ask me for the time and than the date, it didn't use to ask me allways, just when I remove my battery for some time. After I chose "Orig. Phone Settings" form phone settings menu, it started asking me when ever I turn it off and on. I don't know what to do.
  • Anonymous Sep 26, 2008
    same as mentioned
  • Anonymous Oct 05, 2008
    Yeah
  • getven77 Nov 30, 2008
    please help me.
  • Anonymous Mar 24, 2014
    Whenever I turn off the phone and then turn it on again, the date and time have changed back to 1st April 2009 at 9am. I update the date and time but when I turn the phone off/on, it has changed again. How can I stop this happening?
You do not need to set it
your service provider will do it once you are on
Posted on Apr 02, 2008
I've had exactly the same problem, i spoke to a technition at nokia who said that he'd worked there for 4 years and never seen a problem like this before. then i went into the carphone warehouse where i was told that it was a software problem that had caused this random glich. he advised me to send it away to T-mobile and get them to either fix it, send me a replacement handset or upgrade me to the new n78 since the n73 is no longer being made. good luck fixing it!
Posted on Jun 14, 2008
Go to MENU>Application>Clock>Option>Settings>Network Operator Time> (make it "Auto update").
I think your problem will be solved.
Goutam Biswas
Posted on May 08, 2008
Hi, I have an nikon coolpix s710...after I set date and time, when I turn off and start again, it ask me if I want to set date and time...please help me to fix this problem because when i start the camera...
1. In Set Up you must select the language you want to use by highlighting it then PRESS OK. If you don't do this then the date/time will not set.
2. When asked to set date and time you must select YES and press OK.
3. After completing each step you must press OK.
4. In the final step you must choose your preferred day/month/year display and then press OK.
If you don't press the OK button at each step the date and time will not set.
Aug 17, 2011 | Nikon COOLPIX S710 Digital Camera
The date and time is asked whenever the camera is switched on
Have you set the date and time? If so then your camera's date battery is probably dead and needs to be replaced. First get yourself a CR1220 battery, most often found at your local Radio Shack or online at amazon. Then open the camera's terminal cover (where your USB is) and using your fingernail. Open the battery holder, remove the old battery, and replace with the new one. Reinsert the holder with new battery in your camera and turn on your unit. set the date and time and you should be all set. For further information see your instruction manual or download from Canon at:
http://gdlp01.c-wss.com/gds/7/0900011217/01/PSA520510CUG-EN.pdf'
The instructions for changing the date battery start on page 137.
Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 05, 2011 | Canon PowerShot A510 Digital Camera
Camera Canon A710 IS started to ask set time date when turned on
When the camera is left without power for an extended period of time, the time and date settings are gone. You need to reset them and when you're finished, click the set/ok button twice.
Feb 25, 2010 | Canon PowerShot A710 IS Digital Camera
Have to set time and date evry time i turn on phone
to set the time u have to go to the settings option and in date and time option you can find auto update change it to ON and your time will be automaticlly updated
Apr 01, 2009 | Nokia N73 Cellular Phone
Everytime i have to set the time & date
Its because your battery is removed.......to keep the date and time intact there must
be some extra charge to keep it going like CMOS battery in computer...
If your battery is removed then the clock will be reset....
Feb 23, 2009 | Nokia N73 Cellular Phone
Memory full problem
The firmware software has got corrupted ...
you should give the "restore factory setting" once ,after you give this option you will be asked for the security code enter that .. and after the restoration is complete restart your mobile once and check it ...
if you still persist the same problem then you must upgrade the firmware software ..
you can do that only if you have the data cable ...
you can do firmware software upgrade by downloading the application from the website given below :
http://europe.nokia.com/A4579163
but remember not to turn off your mobile or remove the battery while updating is in progress ...
regards
-Dileep
Dec 26, 2008 | Nokia N73 Cellular Phone
My cam(sony dsc h7) ask for time whenever battery is inserted
Inside the camera is a button battery used for storing settings. It most likely is dead. It takes soldering to remove it.
Nov 13, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Date & time
Try to see in your settings of time and date are set to automatic or manual.
Oct 15, 2008 | Nokia N73 Cellular Phone
Reformating n73
Reformat the phone
To format:
  1. Turn phone off
  2. Hold the following keys WHILE it's turning back on: (3 + * + green call key)
  3. DO NOT let go till it asks you about your LOCATION
  4. DON"T forget to back-up all pictures and videos on the phone memory to the memory card before doing so
Jul 02, 2008 | Nokia N73 Cellular Phone
Nokia n73 music edition total raset
u can do dat by typing in *#7370# on ur N73 Music Edition but hey dont forget to back up all ur data in the phone memory like CONTACTS,USER SETTINGS,MESSAGES AND THEMES DAT UVE INSTALLED in the PHONE memory.nothing will happen to ur memory card.u can back up ur data by using the pc suite with cable (thru bluetooth it will take lotta time) by entering this code ull be doing a HARD RESET of ur fone i.e back to factory settings.it'll ask u the confirmation and after that the fone will restart automatically and will ask u to set date time etc like u did when u purchased it.after that u can restore all ur data that u backed up using PC Suite.ive done dis a lotta times so its safe and gud.BUT DONT FORMAT UR MEMORY CARD EVER CUZ IT CONTAINS SOME FILES THAT U CANT RESTORE EVER.
Jun 16, 2008 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
473 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
