Question about Apple MacBook Pro Notebook
Apple OSX Hi, Any idea why my Macbook Pro sometimes shuts down (all the way off) while it's in sleep mode and the battery is still charged? Could this be a software problem? How come you guys don't have software manuals on line? .. Thanks in advance, Harry
    Genius:
  • 3,422 Answers
You can try out these solutions to fix your problem.For more solutions you can check the lick HERE
These will definetly fix your problem.
1) Shut down MacBook and remove the battery;
2) Hold down the Start button for ten seconds and then release it;
3) Reinstall the battery
4) Restart the computer
This procedure resets the MacBook's PRAM settings which contain many of the computer's basic settings, including the RAM disc which needs to be accessed for the computer to awaken.
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 01, 2008
  • 871 Answers
Hey Harry
try resetting the PMU.
this is not a software problem. it just needs a little tweaking.
well, some experts are free to post software manuals online. but that will be upon the experts themselves.
here is a link for discussions that is related to everything about your MAC.
thanks for using fixya.
  • 818 Answers
    Genius:
  • 1,913 Answers
Hi
check your laptops hitting event.
scan your sys witha ntivirus.
then format the sys.
Macbook pro dark screen
Close the lid, attach an external monitor, reopen lid.
Your display should now show on that monitr. If it is, your display on the MacBook Pro may be bad. I would try resetting the PRAM and the SMC before going to an Apple store. The SMC controls the MacBook's power founcts (see below)
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jan 12, 2014 | Apple Computers & Internet
When I turn my macbook pro laptop on all I see is an envelope with a question mark
The computer cant find a start up directory so your Harddrive may be corrupted or physically bad. But there are other causes so...
First thing to do is turn it off, remove any connected devices or cables, unplug the power supply and remove the battery. Wait a minute or two then replace the power supply leaving the battery out and start the macbook while holding down the SHIFT key on the keyboard to start in Safe mode. If that works you're lucky and you can restart the computer normally (no shift key) replace the battery and any connected devices one at a time (with a shut down in between) to see if one of your devices was to blame. If that didnt work you will need to start the computer from your OSX start up DVD to repair your start up directory/harddrive if possible. See this link http://support.apple.com/kb/TS2570 for more details. let me know if you need more help.
Oct 11, 2013 | Apple MacBook Pro Laptop Computer with...
Keyboard Backlit not coming on at all
Set your backlighting in
Apple menu
System Preferences
Keyboard.
otherwise try:
Resetting the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jul 08, 2012 | Apple MacBook Air
My Macbook Pro is not starting, it seems it goes
Try starting up in Safe Mode by holding down the shift key. That will be a start to get you into the System Preferences, find your Power Saver preferences and turn Sleep off.
Hope this helps!
Dec 28, 2009 | Apple MacBook Power Inverter Car Adapter
Macbook goes to sleep and doesn't wake up unless I do a hard reboot.
I have seen this caused by having a mouse plugged into mine. I have removed the mouse and touch the touchpad and it has come up from sleep.
That very well may not be your problem.
Here is the procedure that is recommend from Apple to help with the not waking from sleep problem. I included both methods as it is not clear which macbook you have. I also included the link to the article at the bottom.
The System Management Controller is an integrated circuit (computer chip) that is on the logic board of the computer. As the name implies, it is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
Over time, the settings in the System Management Controller may become unusable, which can result in operational anomalies with the computer. Examples include not turning on, not waking from sleep, not charging the battery, or not recognizing the AC Adapter, among others.
MacBook (13 inch, Late 2008), MacBook Pro (15-inch, Early 2008), and MacBook Pro (17-inch, Early 2008)
  1. If the computer is on, turn it off.
  2. Disconnect the AC adapter and remove the computer's battery.
  3. Press and hold the power button for 5 seconds and then release the button.
  4. Reconnect the battery and AC Adapter.
  5. Press the power button to restart the computer
Note: Starting with MacBook Pro (Late 2008) and MacBook (Late 2008) models, you may instead use the reset method for MacBook Air (below) to reset the SMC. All earlier models of MacBook and MacBook Pro must use the method described above, which involves removing the battery.
MacBook Air and MacBook Pro (Late 2008 and later)
  1. If the computer is on, turn it off by choosing Shutdown from the Apple () menu.
  2. Connect the power adapter to a working power source.
  3. On the built-in keyboard, press (left) Shift-Control-Option along with the power button once.
  4. Wait 5 seconds and press the power button to start the computer.
Note: You must use the keys on the left side of the built-in keyboard.
Here is the link to the article at the Apple support site.
http://support.apple.com/kb/HT1411
Aug 28, 2009 | Office Equipment & Supplies
Don't know how to put my new macbook pro to sleep :P
All that can be done in the aluminium button on the top rigth corner of the body. Try this: go to the blue apple icon on the top left of the screen, and pull down menu, there is the Sleep, Restart, turn off options.
Jul 10, 2009 | Apple MacBook Pro MC026LL/A 15.4-Inch...
Macbook pro unexpected shut down
After determining the battery health:
http://support.apple.com/kb/HT1519
Then calibrate the the battery:
http://support.apple.com/kb/HT1490
Apr 14, 2009 | Apple MacBook Pro Notebook
Apple MacBook Pro Notebook Logo
106 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
