Question about Acer Aspire 3000 Notebook
CD DVD I had a CD stuck in the CD DVD drive, I used a pin to open the drive to remove the CD. Now my drive does not see a disk when inserted and I still need to sue a pinto open the drvie
    Genius:
  • 1,913 Answers
Check your lense ,clezan it with lense clener cd.
replace your lense if u have warrenty.
Posted on Apr 01, 2008
SOURCE:
Disc inserted improperly now stuck
Carolyn:
Take a butter knife (not a steak knife) and push the diskette into the drive the rest of the way, and then eject it.
Jul 12, 2015 | HP 19-2014 All-in-One Desktop PC - ENERGY...
Cd drive wont open
DCD or CD stuck, exploded? In the Start Menu, Computer, right click the DVD/CD rom drive , scroll down, click on Eject. There may be a "pin-hole" on the face by the button, you can use a paperclip to insert and open. If All else fails remove the DVD and remove cover.
Feb 02, 2013 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
What if disk drive does not open during system says reboot and selesct proper booot device
Sounds like you may have a CD/DVD in the drive that is stuck and/or not inserted properly. There should be a small, pin-size opening on the front plate of the CD drive. Find a large paper clip, bend out one end of it then insert into the pin-hole. Push it until the drive pops open.
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Aug 10, 2012 | Toshiba Satellite P755-s5320
Cd dvd door wont open.i push the button to put in cd and nothing happens.i do see a little cd on screen ,then it goes away.
On the front of most CD or DVD drives there is a small pin hole that you can use to open the drive if it gets stuck. Grab yourself a strong paper clip, straighten one end, insert the straight bit into the hole and push firmly once you feel some resistance.
This will partly open the drive tray to either allow you to remove a cd or insert a new cd or dvd.
Question, Is there a light lit on the front of the drive when you are:
a. trying to eject (instead of using the front button on the drive try using the "Right Click and then Eject" option when selecting the dvd drive in My Computer), If not the drive may be stuffed (broken) or perhaps the 4 pin power connection lead at the rear of the dvd drive has fallen out.
b. is the drive tray sticky when opening or closing? (get a new drive...very easy and very cheap to buy and replace)
Good luck,
Steve (Melbourne,Australia)
May 14, 2010 | E-Machines eMachines Desktop PC
DVD drive will not open
use a pin or hook to pull out the drive while pressing the drive open button...
some time they get struck...
Dec 25, 2009 | Computers & Internet
Can't open the second cd rom drawer
Does the light flash when you press the button? If so, was there a disk in the drive previously? There is a small hole on the front of the unit. With power off, get a paper clip and open it up halfway. Push the open end into this hole and the drawer should pop open by about half an inch. This will be enough for you to gently pull the drive open and remove anything stuck inside. Ian.
Sep 27, 2009 | E-Machines T3256 PC Desktop
CD\DVD drive is stuck and will not open
Did you try the paper clip treatment?
There is usually a small pin hole somewhere on the front of such devices. Insert a straightened paperclip and release the internal catch.
I hope this works for you
a
Sep 27, 2009 | Sony VAIO VGC-RB40 PC Desktop
Will not eject disk
CD drive is messed up. You should not have to open the case. I take a paper clip and stretch it out. Then insert it into the pinhole of the cd drive. You have to push kinda hard to get the drive to pop open.
Every drive I have ever seen has such a hole
Jul 09, 2009 | Sony DDU-1615 / 16x DVD-ROM / 48x CD-ROM /...
Cannot open the disk drive.
It happens when you stop using your drive
use pins and insert in small hole present above the LED[light]
Dec 09, 2008 | E-Machines emachines (emachinees) CD-ROM...
Acer Aspire 3000 Notebook Logo
77 people viewed this question
Ekse
Alun Cox
