Question about Sewing Machines
JUKI LK1900HS Broken machine
We currently have a computerized JUKI bartack and we had a needle break and now the presser foot is stuck in the down position. We have looked in the manual and cannot find any topic that covers this problem and are sort of in a dire situation as we are with a parachute team at the United States Military Academy in West Point, NY and have equipment that needs repairs using a bartack.
  • Anonymous Apr 18, 2008
    my juki lk-1900hs is show error E7
  • 106 Answers
Sounds like it was part way through a cycle when it stopped.
Remove the needle, turn the power off and try turning the machine through a cycle by hand. If that does not solve the problem do the same again with the power on.
Posted on Apr 02, 2008
Card
Posted on Dec 31, 2012
    Scholar:
  • Sewing Machines Expert
  • 176 Answers
Kindly please check LED3 on SDC board: Flashing once
check main motor rotate or NO?
check cn16 on SDC board
finaly maybe need to change SDC board
Posted on Aug 20, 2009
I have a Juki TL98E and when I got it forgot to put the presser foot down and obviously the needle broke several times. Now the thread keeps breaking. Thoughts?
Remove all the thread from the machine. Thoroughly check that there are no stray threads or lint stuck anywhere. Oil your machine per the instructions.
Make sure you are using a brand new needle.
ALWAYS RAISE the presser foot and rethread the machine. Verify the thread path is correct. Check that the bobbin is installed and threaded correctly.
Set the tension to the midway point. Pull the bobbin thread to the top of the fabric. Gently hold the thread tails while you take a couple of slow stitches.
If it is still not sewing correctly, it's quite possible the timing is off (which is common when a needle breaks). You'll probably need to take it for service.
Oct 27, 2016 | Juki Sewing Machines
Juki TL2200
Check thread routing
Jul 20, 2016 | Juki Sewing Machines
Thread is breaking 8700
needle too small. cheap thread. needle not centered in slot of presser foot which will cause the thread to be sheared of when needle passes presser foot. burrs on hook under machine causesd by breaking needles. tilt machine and use emery paper to smooth hook. stroke in same direction as hook rotation. maybe too much top thread tension also.
Jan 11, 2014 | Juki DDL-8700
Presser foot
Please check the needle correct size or not and another check presser foot join properly.
Dec 20, 2013 | Brother PE770 Computerized Sewing Machine
Juki DDL 227 top needle keeps breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Oct 08, 2012 | Juki Sewing Machines
Needle breaks a lot
Machine breaks needles
1.make sure you are using the right needle for your type of sewing machine.
Most machines can use generic Schmetz needles. There are cases where the machine will only use ones specified in the owners manual.
2.the presser foot may not be installed properly
3.use the correct needle for the type of fabric you are working with. To fine of needle on heavy fabric or to course a needle on silk or jersey can damage fabric.
4.let the feed dogs guide the fabric & the feed dogs will work with the presser foot .
5.the needle is not all the way in -push all the way up against the stop
Mar 05, 2012 | Juki Sewing Machines
Presser foot problem
Turn the handwheel so the needle is at the highest position and then turn the power off and then back on.
If this does not help, you will need to take the machine in for service.
Feb 27, 2010 | Brother CS6000i Computerized Sewing...
I just got a used juki ddl-5550-6 sewing machine. There is no owner's manual. I think I have the machine threaded right. When I put the pressure foot down to start sewing, it pulls the thread down into the...
PLEASE CHECK FIREST TIMMING BETWEEN NEEDLE AND HOOK
OR GO TO WWW.JUKI.COM U WILL FOUND USER GUID ALL LOCKSTICH MACHINE SAME ADJUSTMENT WITH DDL SERIES
BEST REGARDS
Jul 08, 2009 | Juki DDL-8300
CLICK AND GRIND IN 270D BROTHER SEWNG MACHINE
Make sure you're using the correct foot for the stitch. Is this during sewing or embroidery? Take off the bobbin plate using the screwdriver and remove the bobbin. Make sure everything is clean under and around the shuttle. If you've ever broken a needle the tip might have fallen down into the mechanism and occasionally be jamming it.
Nov 19, 2008 | Brother SE-270D Computerized Sewing...
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Sewing Machines Logo
545 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
