Question about Kenwood DDX-6019 Car DVD Player
DDX-6019 Problem: The unit shuts off briefly while in use then turns back on
This unit is installed in 2008 Jeep Wrangler. While in use it would shut off for a few seconds and then turn back on. Tried reseting it but it still does it. Any ideas?
Check your ground. have had that before several times. the factor wire that you though was a ground may be bad but in newer cars its usually a very illusive wire to find. next if you ground your radio straight to the frame and it still dosent work work backwards. hook up only your accesory and your constant and the ground wire. if it still dosent work you have a problem and its not cheap. if it does work then you have a grounding wire or your wiring is not hooked up properly. if you have no idea about anything i just said take it to a install shop. more than likly in an 08 liberty they have a factory amp and your amp is drawing to much on your power antenna lead or you have other issues but this is where you start.
Posted on Apr 20, 2008
SOURCE:
My kenwood ddx-6019 worked perfectly fine for 6 months now and now the screen wont come on but the power will turn on and off and it accepts cds but nothing plays unit will turn on and off, and you can see...
I'm having the same problem on mine.
Could be the ribbon cable from main board to the face of radio?
I found one on pacparts.com
Im gonna order it and replace it myself...
Oct 05, 2010 | Kenwood DDX-6019 Car DVD Player
When i go to play a cd my amp will shut off ? but when i play the raido the amp will stay on !!
Verify that you used the "blue" remote wire from the radio to the amp. Some new stereos will have a dim light wire as well(pink) i think. Hope it helps.
Sep 05, 2009 | Kenwood DDX-6019 Car DVD Player
The jeep shut down while backing up and now the clutch goes all the way to the floor and i cannot put it in gear. what is this ?
Hi,It sounds like the clutch master cylinder or clutch slave cylinder have failed.This is a very common problem that is being seen more and more on the 2007 and 2008 models.If you still have a warranty it should be covered and if a recall is issued,it will be covered as well.You can also go here to see current recalls and technical service bulletins(TBS)
Please take time to rate this fixya
May 16, 2009 | 2008 Jeep Wrangler
Wind sheid wipers malfunction on new Jeep Wrangler
U will need to replace the switch for wiper and turn signals, there is a broken contact inside the switch.
Apr 30, 2009 | 2008 Jeep Wrangler
Unloc code for kenwood DDX-6019
www.kenwood.com. You can download the manual for DDX-6019. It will explain the procedures far better than i could put down here.
GGBMDB
Nov 29, 2008 | Car Audio & Video
Kenwood ddx-6019 password
i forgot my password to my kenwood ddx-6019 dvd player and the codes that you listed didn't reset it is there any other codes that might work??? or is there like a reset button that i am supposed to push please help me out
same problem
Apr 11, 2008 | Kenwood DP-R6080 5-Disc CD Changer
Video output not working
it sound to me like you have a broken connection on yourvideo out jack on the main unit becouse you say the lead is fine and the tv screens work with another unit.this can be caused by the plug being pulled out in a wrong angle. ask an audio dealer to chech the solder connections in the unit to see if they are making a connection with the pcb(printed circuit board. hope this helps
Feb 25, 2007 | Kenwood DDX-6019 Car DVD Player
New DDX-6019
haha ok shipping screw in a double din unit i have never seen before but in dual which is a big pos. but there should and will not ever be a screw that holds the laser in on a double din unit because the laserated in the very middle of the player on these models. sounds like you have a defective driver so i would try and get it exchanged or call kenwood
Feb 05, 2007 | Kenwood DDX-6019 Car DVD Player
Kenwood DDX-6019 Car DVD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
