Question about Sony Ericsson V630i Cellular Phone
Sony Ericsson V 630i microphone problem after software update
Hi all :-)
I have Sony Ericsson V 630i and it worked fine. I use my Update software and all update finished ok. After that, when i make a call other side can't hear me or hear me very low. What's the problem and can be fixed?
  • rpjjuk Apr 21, 2008
    Having the same problem on my SE 630i. The microphone is not working correctly. person on the phone can't hear me.
  • doba666 Apr 25, 2008
    i try many other things, but finally brought the phone to service and
    the problem was in the microphone. service guy replace the mic and now
    everything is ok. :-)
My v630i has just done the same? the mic works from underneath, but pointless talking into the bottom flat bit! people cannt hear me... any fix?
Posted on Apr 24, 2008
SOURCE:
When i connect charger to my Sony Ericsson K750 it switched of automaticaly.
This is a software issue.
If your phone freezes, hangs up unexpectedly, vibrates continuously ,touch screen wont respond or in other similar ways doesn't perform as it should, this can often be solved by performing a software update. Software may perform incorrectly for many reasons without there being a fault in the phone. Some problems may be fixed by re-updating your current software, while others may require installing a new software version.
To keep your phone performing at its best, it's a good idea to perform a software update regularly. You might not always notice what an update has done, but it can prevent future problems.
To update or reinstall the software please go to nearest authorized service centre of your mobile make and they will update or reinstall the software as required.
Note: Reinstalling the software will delete all the content in your phone like contacts, calendar entry etc.
If still the problem persist please change the LCD screen.It will work fine.
Thank You
Dec 09, 2010 | Sony Ericsson K750
Update software
hi
visit to the given link for software updation... http://www.fixya.com/support/r4622711-updating_sony_ericsson_s_software_free
Hope this has helped you,,, Thanks....
Jul 11, 2010 | Sony Ericsson K800i Cellular Phone
Sony ericsson K750i phone died during update I was trying to update the phone on the Sony Ericsson site ,the update was underway (the part after you let go of button C) when the update failed (it said try...
I think are using sony Ericssin PC syn.This it will cause some problems.There is a separate software for updater, download it and follow the process given in the site.this should work.
Jun 04, 2010 | Sony Ericsson K750
How to update my mobile software?????
* These steps apply only for Sony Ericsson Mobiles (ex. Z550i)!
1. To update the Mobile OS / Firmware software, you have to connect to internet.
2. Goto Menu >> Settings >> General >> Update Service.
3. Select 'Search for Updates' to search latest available software update OR
4. Select 'Software Version' to display current software installed on phone OR
5. Select 'Reminder' to set time when to search for new updates.
* To use "Update" service online (not on phone) :
1. Visit www.sonyericsson.com/update
2. Select a 'Region' and 'Country'.
3. Enter the Product Name.
4. Select 'Sony Ericsson Update Service' and follow the instructions that appear!
please rate this advice if it helps...tc! :)
Jan 19, 2010 | Sony Ericsson Cell Phones
Hi my sony c903 has all of a sudden showed no network coverage. I have put my sim in another phone and it works fine. any advice?
Hi! I went through this tonight with my Cyber Shot too. There's a software update you need to install from the Sony Ericsson site. I've got the link to it and the information about it here on my blog - http://jackcullen.blogspot.com/2009/12/sony-ericsson-c093-dilemma-network-3.html
Thanks,
Jack
Dec 03, 2009 | Sony Ericsson Cyber-shot C902 Cellular...
Hang when play music
Yes update your software if u want to get rid from this freezing issue.
I was also a victim of this so i just update my W660i software now my cell is working 100% OK :)
Oct 17, 2008 | Sony Ericsson W660i Mobile Phone
Phone dead after opening java executor
I had the same problem with a k800i, i emailed sony ericsson and they told me what to try and it worked however you do lose everything you had stored on your phone. I believe this will work with most if not all sony ericsson phones. You need to update your phone, here's what to do;
1.Go to www.sonyericsson.com/support
2.Select UK
3.Select your model of handset
4.Click on Sony Ericsson Update Service
5.Click the link, and then click Run or Save.
6.Let the Sony Ericsson Update Service install.
Once you have installed the Sony Ericsson Update Service you will need to launch it. Once it opens simply follow the instructions that you will see on screen. The update should then begin.
Jun 22, 2008 | Sony Ericsson W700i Cellular Phone
Sony ericsson k800
try flashing(update software) the phone. does not require phone to be on. go to sony ericsson home website, on the page youl find the link (update software) download it. open the file and follow the instructions,(you will need a a sony ericsson transfer cable) updating the software will delete things on your phone ,take out ur sim b4 doing this.
Apr 02, 2008 | Cell Phones
How do i get the software update for my phone?
hi there here's the site that you can update your sony ericsson phone and you can download it here the update service setup, the compatible models that can be update, and requirements to update your phone.
Sony Ericsson
ok!
peace!
Mar 26, 2008 | Sony Ericsson W850i Cellular Phone
Sony Ericsson V630i Cellular Phone Logo
1,565 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
