Mouse is whacked
I've got an optical mouse that has stopped working. First the red light was always on and the cursor was not moving at all. Now, the cursor moves when I move the mouse but when I click on an area nothing happens. I'm stuck and have no idea how to get this to work.
  • trailblazer5 Nov 20, 2008
    I have the same problem...how do you open the mouse...
    Problem Solver:
  • 18 Answers
First you should check it in any other system if mouse does not work then u should exchange your mouse or open it u can easily repair it..
but if the mouse works then there may be a spyware in ur system so check for it .
best of luck
Posted on Apr 01, 2008
SOURCE:
How do I get the mouse to mouse the mouse cursor
the battery in the mouse makes the red light come on, not the operating system.
Look in Device manager,find the mouse, uninstall the drivers, scan for new devices, re-install the drivers.
Otherwise look for new drivers on manufacturers site.
Apr 13, 2014 | GE 98566 98566 wireless optical mini mouse
My mouse cursor will not move on the screen when I try to use my new wireless mouse. The light comes on on the bottom of the mouse and the USB is plugged into the computer. The USB blinks red when plugged...
Hello, hope this isn't a silly suggestion, but have you pressed the 'connect' buttons on the mouse and receiver so that the 2 devices can synchronize?
Regards,
nicam49
Dec 29, 2010 | GE Wireless Optical Mouse
Sir, i want to know about the optical mouse in detail. what is the important point of it to use. thanks, tin
Optical mouse was developed by Agilent Technologies and introduced to the world in late 1999, the optical mouse actually uses a tiny camera to take 1,500 pictures every second. Able to work on almost any surface, the mouse has a small, red light-emitting diode (LED) that bounces light off that surface onto a complimentary metal-oxide semiconductor (CMOS) sensor.
The CMOS sensor sends each image to a digital signal processor (DSP) for analysis. The DSP, operating at 18 MIPS (million instructions per second), is able to detect patterns in the images and see how those patterns have moved since the previous image. Based on the change in patterns over a sequence of images, the DSP determines how far the mouse has moved and sends the corresponding coordinates to the computer. The computer moves the cursor on the screen based on the coordinates received from the mouse. This happens hundreds of times each second, making the cursor appear to move very smoothly.
Optical mice have several benefits over wheeled mice:
No moving parts means less wear and a lower chance of failure.
There's no way for dirt to get inside the mouse and interfere with the tracking sensors.
Increased tracking resolution means smoother response.
They don't require a special surface, such as a mouse pad.
Although LED-based optical mice are fairly recent, another type of optical mouse has been around for over a decade. The original optical-mouse technology bounced a focused beam of light off a highly-reflective mouse pad onto a sensor. The mouse pad had a grid of dark lines. Each time the mouse was moved, the beam of light was interrupted by the grid. Whenever the light was interrupted, the sensor sent a signal to the computer and the cursor moved a corresponding amount. This kind of optical mouse was difficult to use, requiring that you hold it at precisely the right angle to ensure that the light beam and sensor aligned. Also, damage to or loss of the mouse pad rendered the mouse useless until a replacement pad was purchased. Today's LED-based optical mice are far more user-friendly and reliable.
Thanks and regards,
Anil.B.R
Aug 18, 2010 | Computers & Internet
Mikomi 3 Button Mini Optical Mouse AM-9170U Not Working!
On an optical mouse, two thngs happen. The light shines out and a sensor reads the reflection almost like a camera image. Try some other surfaces, particularly ones which are not shiny. If that doesn't help, install the mouse on some other computer. If that works, reinstall your drivers on the first computer, removing the old ones as best you can (Control Panel...Device Manager...etc.). If it doesn't work on the other computer, check for any switches on the mouse (that would be uncommon) and for warranty coverage. Otherwise, the light sensor is probably broken and there is little you can do.
Sep 19, 2009 | Computers & Internet
IBM Optical Scroll Mouse doesn't work (Device Driver Problem)
connect your mouse. then restart your laptop do not remove mouse while restarting laptop. if not work after restart there is a problem in your mouse IC.
Jun 02, 2009 | IBM Optical Travel Mouse 2224P0480
Msk1056 optical mouse lights on won't move cursor
REPLACE THE BATTERY AND UPDATE THE SOFTWARE AND PUSH IN THE RESET BUTTON ON THE BUTTOM OF THE MOUSE SO IT KNOWS WHAT FREQUENCE TO OPERATE AT
RODGANDYSR
Mar 05, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Standard Wireless Optical Mouse does not move cursor
Your batteries are likely dead.....replace them and try it. Should work.
Jan 17, 2008 | Microsoft Standard Wireless Optical Mouse
Optical mouse
you can clean the lens with any window cleaner, does it have a red light coming out of the bottom?
Dec 13, 2007 | Microsoft Standard Wireless Optical Mouse
Mouse stopped working, but appears ok, batteries ok, can't determine problem
Hope this helps others. My mouse stopped controlling cursor but buttons worked. Problem was it would not work on a black table. Slip a piece of white paper under it and waaala! It works. I'm thinking optical mouse and dark surface might be an issue.
Oct 10, 2007 | Logitech Cordless Mouse
Open Questions:
Epson Printer Number #[1~855~536~5666]+ Epson Printer helpline number OIYCIZY [email protected] assistance available 24*7. If you are facing any issues in printer you will get expert assistance through [email protected] helpline number {+1855.536.56*66*}for fixing all kind of printer related issues within seconds. [email protected] SuPpOrT pHoNe #{1855.536~5666*} nUmBeR USA... [email protected] Support Phone Number +{1-855*536*5666*} to resolve all [email protected] products. is an American multinational company which was founded by Michael [email protected] its company headquarters in Round Rock, United States of America. SPOTIFY tech support pHoNe Number {18555365-666-} to resolve all SPOTIFY products. [email protected] is an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, [email protected] number, and selling of computer-related services and products. SPOTIFY Tech support Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY tech support number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and services. {1*855.536.5666T~} allows to any type of help is provided of experience employees [email protected] cArE {1*855.536.5666I~} nUmBeR USA OFFICIAL [email protected] cArE Number {1*855.536.5666-} to resolve all OFFICIAL products. [email protected] cArE is an American multinational company which was founded by Michael OFFICIAL using its company headquarters in Round Rock, United States of America. SPOTIFY toll free pHoNe Number {1855536,5666-} to resolve all SPOTIFY products. [email protected] an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, [email protected] number, and selling of computer-related services and products. SPOTIFY Toll free Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY toll free number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and vikki services. [email protected] tech support pHoNe {18555365-666-}} nUmBeR USA [email protected] tech support pHoNe Number {18555365-666-} to resolve all [email protected] products. [email protected] an American multinational company which was founded by Michael [email protected] its company headquarters in Round Rock, United States of America. [email protected] Support Phone Number for [email protected] support help. [email protected] Support is an independent body, which is established with the vision to deliver exceptional technical service for the Epson brands.
Oct 21, 2019 | Epson Computers & Internet
Linksys router CUSTOMER service pHoNe:~{-l84433O2330}-}nUmBeR USA USAiary Linksys router CUSTOMER service Number +l84433O2330}}USALogin Repair service center to resolve all Linksys router tEcH SupPoRt pHoNe nUmBeR products. Linksys router ROUTER is an American multinational company which was founded by Michael Linksys router ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Linksys router ROUTER support number, and selling of computer-related services and products. Linksys router ROUTER Tech Support Phone Number Recently, Linksys router ROUTER has been named the number Linksys router ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, Linksys router ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a Linksys router ROUTER Service Tag or a Linksys router ROUTER Get Linksys router ROUTER Technical Support Phone Number and Customer Services. Linksys router ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 21, 2019 | Linksys Computers & Internet
Outlook MAil Contact %%%{1=855=536=5666}#[email protected]@# NuMbER FLORIDA This SbcGlObAl mAiL USA phone number is ranked #2 out of 2 because 7,728 SbcGlObAl mAiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the SbcGlObAl mAiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbcGlObAl mAiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbcGlObAl mAiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact SbcGlObAl mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbcGlObAl mAiL USA Calling SbcGlObAl mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbcGlObAl mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbcGlObAl mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbcGlObAl mAiL USA's phone numbers against each other. Contacting SbcGlObAl mAiL USA in General While I********** is SbcGlObAl mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbcGlObAl mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbcGlObAl mAiL USA.
Oct 21, 2019 | Best Computers & Internet
Computers & Internet Logo
523 people viewed this question
Ekse
Marvin
Marvin
