Question about Panasonic KV S2065W Path-Through Scanner
Reinstall problems I had to replace the power supply in my scan computer (Windows XP) and now my scanner isn't recognized. When I try to reinstall it, I get a message "class installer denied the request to install or upgrade the device." (I was logged on as administrator.) I went into the device manager to uninstall it and it's listed under imaging devices as an unknown device. I can't uninstall. Any help would be greatly appreciated as I absolutely have to get this scanner up and running asap. Thank you!
  • 813 Answers
Hi friend
1 u have plug ur sanner on a other port
2 do not power on ur scanner
3 put ur scanner driver cd in cd rom
4 start the instollation of scanner
5 in between installlation sadi u power on ur scanner then u have do power on ur scanner
6 then after scanner driver taken by during installation automatically
7 finiesh the installation
& try to scan
Posted on Apr 01, 2008
How do I get my hp deskjet f4435 printer to scan? it will copy and print but not scan . when I push the scan button it does nothing
Hi
A good idea would be to follow the link below, its takes you to the HP website and small program that you can install and run a test on your printer setup to isolate the problem. I suspect it will be a simple driver not being loaded on you computer.
Try the HP Print and Scan Doctor for Windows
Thanks
Sep 28, 2014 | HP DeskJet F4435 Power Supply Adapter Cord...
Micorsoft Windows Fax and Scan has stopped working. > A problem caused the program to stop working correctly. Windows will close > the program and notify you if a solution is...
If if was working properly in the past, the problem is usually due to the device (your scanner, fax or camera) has somehow come unplugged from it's USB connector and Windows no longer "sees" the device. Try powering OFF the unit, unplug your USB cable from it. then power OFF your computer. Now, power ON your computer, log into Windows. Next, plug your scanner/fax/camera into an available USB port. WATCH to see if Windows detects the device. IF it does, attempt to scan an item... it should start the Scan/Fax wizard.
IF it does NOT recognize the unit or start the wizard, I would look to remove the device from Device Manager and try again.
Mar 09, 2011 | Computers & Internet
My HP 5300 C scans the items but when I try to open them they look like colors are missing. This happens on both black and white items and color items. What I get are shades of purple?
For Precisionscan scanning software, delete HPCCOPY files and reinstall the scanning software.
  1. From the Windows Desktop, select Start , Find , and Files or Folders .
  2. Type HPCCOPY.* in the Named box and C: in the Look In box. Click Find Now .
  3. When the files appear, select all the HPCCOPY files; right-click and select Delete .
  4. Reinstall the HP scanning software.
  5. Shut down the computer, cycle power on the scanner and turn the computer back on. The error should no longer occur.
For Precisionscan pro scanning software, delete HPIPCOPY files and reinstall the scanning software.
  2. Type HPIPCOPY.* in the Named box and C: in the Look In box. Click Find Now .
  3. When the files appear, select all the HPIPCOPY files; right-click and select Delete .
Feb 01, 2011 | HP ScanJet 5300C Flatbed Scanner
How do i get my mustek 1200 iii ep flatbed scanner to work with windows xp. my computer restarts every time i clink on scan.
If you have the orginal software that came with your scaner and it says that it is compatible to Windows XP, you may need to use the disc to reinstall it. YOu will first need to turn off the scanner and unplug it from the PC. Then uninstall the old software from install/uninstall in your control panel. (start>control panel>install/uninstall programs, search the list for your scanner software.)
If you do not have the software or it is not for Windows XP:
There is the link to a site with a driver download specifically for your scanner, instructions on installing it for windows XP and also a link to answers to problems for your specific scanner.
http://www.mustek.com.tw/Download/driv_scanr/english/1200ub.html
Before you begin any download make sure your virus control software is up to date.
First click on the link "Instructions for XP installation and print it out.
Next click on a driver for XP from the chart to download it. When a window pops up click save and browse until you locate desktop. Save this file to your desktop. It will be an .exe file.
Turn off your scanner and unplug it from your PC and uninstall the oldsoftware as advised above.
Click on your new driver file to install it. Follow instructions.
Once the driver is installed, plug the scanner back into the computer and turn it on.
Restart your computer.
It should now recognize your scanner.
Try a scan.
Dec 18, 2010 | Mustek Plug-n-Scan 1200 III EP Flatbed...
My computer will not recognize the pandidgital photolink scanner
Try attaching the scanner directly to the computer. If this works, the problem is obviously in the hub. Many scanners will not work if attached to a bus-powered hub. If you have a self-powered (with a power transformer) hub, double check that the power transformer is working (it should be warm).
I hope this helps.
Dec 25, 2009 | PANDIGITAL Office Equipment & Supplies
XP won't recognize HP 5370C Scanner
go to contol panel and select new hardware. then try it by reading that instruction. if its no result then u can reinstall ur Xp
Aug 03, 2009 | HP ScanJet 5370C Flatbed Scanner
My noteoook got the problem with port usb
Since you have these many problems with your laptop, Firstly try to reformat the system and reinstall all the neccessary drivers. Many times reformatting works well as your OS might malfunction when you have virus or malwares in your laptop.
OTHER SOLUTIONS
a. for USB:
  1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
  2. Expand Universal Serial Bus controllers.
  3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
  4. Click the Power Management tab.
  5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
  6. Repeat steps 3 through 6 for each USB Root Hub in the list.
  7. On the Action menu, click Scan for hardware changes.
    Windows XP recognizes the new device.
  8. Close the Device Manager window.
b. SD CARD
Your 1GB kingston card might have virus. use a card reader and reformat the card for future use.
c. Uninstall and reinstall the driver of your finger scanner.
Hope this helps,
~regards,
Jegan
Jun 01, 2009 | Lenovo 3000 N100 Notebook
Nikon Coolscan 9000 ED can not be recognized by computer
I am having the exact same problem...cannot get the Coolscan 9000 to show up in Device Manager. One thing I did try (to no avail) was to run the regsweeper.exe file that comes with the Nikon scan disk. It clears your registry when you reinstall. It still did not work though so I have a lovely "shoebox" sitting next to my computer that is worthless!
Dec 08, 2008 | Office Equipment & Supplies
Unable to scan, Unable to get the scanner to even be found (but twice)
Do you have a spare USB cable. Sometimes if that goes bad, that happens.
Try another available UBS port as well.
Jun 16, 2008 | Microtek ScanMaker 4900 Flatbed Scanner
Panasonic KV S2065W Path-Through Scanner Logo
114 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
