Question about Mitsubishi VS-60607 TV
My projection tv
My tv has a kind of a crooked line about 1/2 inch from the top of the set and the color is irratic and seems to have lost its brightness and the picture kind of moves around a little it seems to get worst when the programming makes sudden changes .like from commercials or vice a versa . i keep hopeing itll go away but its not ,can any help A horizontal line runs through middle of the screen. Top of picture starts below this line and bottom of picture is at the top of the screen. This is also hooked up with dish.
  • 813 Answers
Hi friend
i think its a problem of defaliction coils problem so u have to sovle this problem u have to go with a good technision he has the all the need equipment so he doing easy & safely
Posted on Apr 01, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
There are some problems that occurer like this! It could be your tube that has busted or it could be that a magnet was near the TV. But most probably it has to be your TV tube!!! You better replace the Tube quickly or it could get worse.
  • 3,037 Answers
Usually this problem is associated with no picture other than the horizontal line. It is an indication of the vertical deflection amplifier failing.
BUT, since you have a picture, it means you still have the vertical deflection. However, it could still be a bug in the vertical amplifier. It could also be a bug in the raster generator.
So,
ONE: Do a hard reset of the tv. Unplug the power cord for 4 hours, then power up again.
TWO: Do the whacking test to make sure it is not a loose connection or cold solder joint somewhere in the works.
THREE: Unplug all the inputs on the back or front of the set and reinsert them again; do this two or three times. It will make sure of a good connection. The multiple insertion cuts through any micro corrosion on the connection points.
FOUR: Try a dvd player into the video inputs. Do you still have the line? This means the line is coming after the video input circuitry and is not associated with the tuner or rf input area of the tv.
Then let me know the outcome and we can take is one step further. I hope you don't have to take it back to Mitsubishi for repairs. These kinds of symptoms are always hard to find, hence more expensive than you might expect!
JVC Hd56fn97 56-inch 1080p Hdila Rear Projection Tv with all blue color green
Talk to JVC as I have suggested and this is likely a known problem: loss of any color, picture upside down etc requires a upgrade to correct and I have seen about twenty sets with their name like this with this kind of problem.
Dec 11, 2012 | JVC Hd56fn97 56-inch 1080p Hdila Rear...
The green is out of line. i tried the convergence but its too far out of line, also the line is crooked.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 03, 2011 | Hitachi 43UWX10B 43" Rear Projection...
My Mitsubishi VS-60621 seems to have a convergence problem
Projection TV2_bing.gif sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Mitsubishi VS-60621 60" Rear Projection...
I have a hitachi 43FDX10B ultrascand HD rear
well it seems to me that you need to call the manufacturer to see how to reset the pixels for that tv. it seems someone has taking a magnet or something like that to the tv screen
Nov 29, 2009 | Hitachi 43FDX01B TV
Picture on AKAI 54 inch HD ready tv is not square.
akai is not a good brand of tv to start with they seem to have alot of problems and finding parts is impossible to do
Oct 16, 2008 | Akai PT5598HD 55" Rear Projection...
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Possible auto convergence board failure
Possible convergence issue.......change STK392-560 IC's....T.
Oct 21, 2007 | Sony KP-57HW40 57" Rear Projection...
Philips 55PP9401 ProjectionTelevision
it seems as you need your tubes re-alinged dont get riped off by tv experts saying it will cost you loads if you have a screw driver and a gentl touch just re focus your red green and blue-simple cost you nothing
Aug 08, 2007 | Philips 55PP9401 55" Rear Projection...
My projection tv
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
Sep 26, 2006 | Mitsubishi VS-60607 TV
Mitsubishi VS-60607 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
