Question about RCA DRC8335
Can not save television channels
I recently purchased an RCA DRC8335. I have a Direct Satellite system and have the RCA unit hooked up but when I run the scan to get the channels into the unit, it will not recognize any except the channel that the satellite is curently picking up. How can I get all of the satellite channels to download into the RCA unit so that I can record and use it as it was intended?
Send it back and get your money
Posted on May 13, 2008
I am trying to hook my tv up....what settings do I need to watch direct tv???
If you have a Sanyo TV with out audio/video connections, you will be using an RF connection cord between your TV and the satellite receiver. You will operate your TV on channel 3 or 4, match this with the channel 3 or 4 on the receiver box.If your TV has audio/video input connections, you will need to purchase rca connectors. They will have a red connection for right audio, white connection for left audio, and yellow is your video connection. The color codes will be on the input connections on the TV and the satellite receiver as well. You will than program the TV to input one or two, of the TV to receive the signal from the receiver. Use the satellite remote to control channels on the receiver box. When you are through watching TV, be sure to shut off your TV as well. Thanks for asking and show a few hands of support!
Feb 19, 2011 | Sansui Televison & Video
I have a wf24t5 that i want to connect to a dish sat hd. how and what do i need to do to connect?
After confirming by viewing the operation manual for this unit, this TV is only capable of inputting a baseband video and standard audio. Unless the Satellite Receiver you have has those type of output jacks then this TV will not be able to reproduce picture or sound from the Receiver. It may be possible to connect through the antenna connection but again the Satellite would need a connector that would output on Channel 3 or 4. Most recent satellite receivers do not offer these ouputs. You indicate that the Receiver you have is High Def. The TV you have is not high def and would drastically down grade the quality of your picture and audio being delivered by the satellite receiver
Television system: NTSC-M
TV Standard
Closed Caption
System: §15.119/FCC
Channel coverage
VHF: 2 - 13
UHF: 14 - 69
CATV: 2 - 13, A - W,
W+1 - W+84,
A-5 - A-1, 5A
Tuning System: 181 channel
frequency synthesized
tuning system
Channel access: Direct access keyboard,
programmable
scan and up/down
Terminals
Antenna input: VHF/UHF/CATV
75 ohm unbalanced
(F-type)
Video input: RCA connector x 1
(1 x Front)
Audio input: RCA connector x 1
(1 x Front)
1 speaker
ELECTRICAL SPECIFICATIONS
Sound output: 1W, 8 ohm x 1
OTHER SPECIFICATIONS
Remote control: Digital encoded
infrared light system
Operating
temperature: 5°C to 40°C
(41°F - 104°F)
Power requirements: AC120V, 60Hz
Power consumption
(Maximum): 98W
Picture tube: 23"
Dimensions: H : 20-3/8" (518mm)
W: 22-13/16" (580mm)
D : 18-7/16" (469mm)
Weight: 55.1lbs. (25kg)
•Designs and specifications are subject to
change without notice and without our
legal obligation.
•If there is a discrepancy between languages,
Feb 18, 2011 | Symphonic Televison & Video
Using RCA P61939 without Guide Plus
Guide plus still works even if you don't have the wand hooked up. In the setup section of the guide plus there are several questions that must be answered properly or it won't function as you would like. It maybe labeled as options as well. Thanks
Oct 02, 2009 | RCA P61939 61" Rear Projection Television
RCA DRC8335 or Curtis DRC8335 Problems at amazon.com rate poor?
There is a dvd stuck in the machine and I cannot access the setup or any thing else. The machine simply says hello.
Jun 09, 2009 | RCA DRC8335
How do I hook up a daewood vcr to a TV through a Direct TV
If you are trying to connect a VCR to your television and still have Directv, this is the way to do it. Disconnect your Directv receiver from your television, Then connect the VCR to the television either through coax or RCA cables. If using the coax cable connect the out to tv on the VCR to the television. If using RCA cables connect the RCA OUT to the television AV1 connection. Once that is done, connect tha Directv receiver to the VCR using either coax or RCA cables. the Directv receiver only has RCA outputs so, if using RCA cables connect to VCR in. Remember that in order to see the Directv the VCR needs to remain on and it must be on the channel line in. If using coax cable connect to the VCR where it says in from antenna. Remember that if using this method your VRC does not have th remain on to view Direct. If you're trying to record Directv, then your VCR need to be on the same channel as the Directv output channel either channel 3 or 4. If trying to record Directv using RCA connections the VCR needs to be on the AV settings. If you have any futher questions please feel free to call me at (361)510-0339
Jonas Lopez
Jag Satellites/ Directv
Installer and Technician specilist
jlopez.jagsat@sbcglobal.net
Mar 02, 2009 | Daewoo DV-T47N VCR
RCA Colortrak 2000 remote control will do everything except change channels.  I have Insight coax cable, just having disconnected from Direct TV satellite connection--only because new apartment does not...
I called RCA's 800 number on the back of the owner manual--got a response that said to replace the unit since only the up-down channel changer buttons were not working. Using another remote (universal) now--cost only $5.
Dec 13, 2008 | Akai LCT2701AD Television
RCA DRC8335 VHS / DVD player does not work
if it's new, send it back. it should still be under warranty.
Mar 27, 2008 | RCA DRC8335
I have an ilo 32hd
Unfortunately the ILO TVs aren't a good investment. If you just purchased the television, I would return it as soon as possible and purchase a more reliable and well known brand. ILO support services is almost non-existant and there are several comments on other blogs regarding the Ilo brand. I have two ILO 26" HD, which I purchased in Aug '06 and am now beginning to experience problems.
Dec 29, 2007 | iLO 2600 Television
RCA entertainment series GEMSTAR GOLD
Hook the cable to the back of the unit.. Go into the customer menu and make sure you've selected cable (as opposed to air). Then do an auto-program and that should solve the problem..
Bill
Dec 11, 2007 | RCA 32F531T 32" TV
DRC8335 not picking up channels when scanned
make sure you have tuner as input---if you are running through another unit as I am to get the signals to the tv--I have to select vidio1 as input to be able to see the screen. My guess is that input is not set to tuner.
Hope this works.
Oct 12, 2007 | RCA DRC8335
RCA DRC8335 Logo
102 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
