Question about Kitchen Ranges
I have a 20 Magic Chef freestanding oven Model# 31FA-92KW. Recently the oven part won't lite up (the top burners will). I have been told that the oven ignitor ismost likely the problem. Can it be changed out with a replacement part without pulling it out from the wall (through the front)? And assuming I kill the circuit breaker is there anything I should be worried about trying to tackle this replacement myself?
  • 871 Answers
You cannot change the ignitor without taking the Oven out from the wall.
it is accessible by removing the lower panel inside the oven. the ignitor will be mounted to the burner. Most commonly on the back left side or may be on top of the burner.
In most cases it can be visually seen looking in to the broiler compartment in the upper back left on the burners tube.
if you DIY, always be very careful!
about the breaker, of course you need to turn it off and always be careful when working on that.
thanks for using fixya.
Posted on Apr 01, 2008
    Genius:
  • 3,422 Answers
Chances are you have an igniter that is going bad and needs to be replaced. Don't allow a bad igniter to operate indefinitely, replace it as soon as possible.
I would recommend you to call a technician yo get it repaired If you cannot do it by urself.
Goodluck,
Please don't forget to rate the solution.
  • Priya darshan Apr 01, 2008
    A faulty igniter is probably the most common cause, however there
    are others:
    -- defective thermostat
    -- defective selector switch
    -- defective gas safety valve
    If you are certain the igniter is ok, and again it might be a good idea to
    call a professional appliance technician.
    Master:
  • 788 Answers
You model number should be three letters then four numbers like this: CEC1536
My money would be that the ignitor would need to be changed from the back. Also you will want to cut the power and only the gas and bleed the oven before working on it.
Did you try cleaning the ignitor? If there is grease or other things on the ignitor it will not light. It will also not light if it is wet.
Good Luck!
  • Dean Joly
    Dean Joly Apr 01, 2008
    Did you call Magic Chef at:
    Customer Service: 800.688.1120
    Canadian Customers: 866.587.2002
    They will probably be able to sell you the ignitor and maybe even help you with replacing it.
  • 2,337 Answers
Check the info from this site in regards to why the oven is not working.
  • Jaime Hernandez Apr 01, 2008
    I would also suggest to unplug the appliance from the main AC power just to avoid any surprises.
    Great link bestdarngood.
  • 3,037 Answers
The most common cause of this symptom is a defective ignitor like you think. Oven ignitors can glow and allow enough current through to open the oven gas valve but just not produce enough heat to ignite the gas immediately (see the link below).
In that case, replacing the oven ignitor is the usual solution.
http://www.appliance411.com/links/jump.cgi?ID=823
  • Benjamin Patri
    Benjamin Patri Apr 01, 2008
    you will most likely not need to move the oven the above link which you can click on HERE
    will show you how it is in the oven and you can replace it by going off of the diagram. You should switch off the circuit breaker before working or unplug the oven just for safety. Good Luck and let me know if you need any more help
    Guru:
  • 1,894 Answers
That may be due to the circuit breaker problem also.
that is also a chance
SOURCE:
Her do I find the model number on my magic chef electric oven. Red light is on staying on? Burners and ovens are all off, What's or how do I find out what's wrong?
There should be an identification plate or label located somewhere (or hidden somewhere) on your oven that indicates model.
Mar 29, 2018 | Magic Chef Ovens
Electric spark will not work, burners will not light
The spark electrode sends a spark to ignite the gas in the burner assembly. If the spark electrode is defective or worn out, it might not produce a spark, or the spark might be too weak to ignite the gas. As a result, the spark electrode will make a clicking sound when the burner is turned on, but the burner won't light. If the spark electrode is defective, replace it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
Mar 25, 2018 | Magic Chef Kitchen Ranges
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
We have a Magic Chef gas oven (model # CPL1100BDW) without electronic ignition. The oven isn't working. The oven pilot is out, can't get it to light, and the oven will not light - (obviously)....
Hello & Welcome to FixYa
If the pilot is clean and still won't light then the problem is with the safety valve that won't open and so needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 14, 2011 | Magic Chef Ovens
Magic Chef oven does not work but all burners do
25 yr old oven...........so I bought a new one with a few blemishes for $200.
Apr 04, 2010 | Magic Chef Ovens
Magic Chef oven stops working
the ovan could be a thermostat 3" 2 6'' long probe my first gess or the ignitor top you need more help with could be a lot of things hope this helps a lititel
Feb 13, 2010 | Magic Chef CGR3742 Gas Kitchen Range
Magic chefa313-230lw gas ignitio
hi .thanks for the question . A very common problem with gas ovens replace the igniter thanks the appliance doc
Sep 29, 2008 | Magic Chef 9512 Electric Single Oven
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
94 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
