Question about Lexmark T644 Laser Printer
T644 202.03 paperjam
I get this 202.03 paper jam eroor and it says check rear door. Checked every door on printer but nothing resolved. unplugged for a hour still the same message.
  • 14 Answers
Ah, that's easy. you probably have a loose spring in one of the 2 paper jam sensors located in the fuser, or a shred of paper stuck in one of them. take the rear door off, then remove the 2 screws on the rear output cover. 2 tabs hold the top of the rear output assembly to the printer itself. once that is off, you'll be looking at the fuser. there is a jam sensor to the left and one to the right. make sure both flags point up, and that nothing is stuck in the flag itself. one of those 2 sensors is the cause of your 202.03 error. best of luck.
chris
Posted on Jul 28, 2008
SOURCE:
How to open rear access door
1, To clear the paper jam issue at the rear of the printer, perform the printer reset to resolve the issue in a simple way.
2, To reset the printer, remove the papers from the input tray while the printer is turned on. Unplug your printer's power cord from the rear of the printer.
3, Now open the cartridge access door and check if the carriage can move freely along the paper width guide. Look for the jammed paper and gently pull it out. If some paper bits are found inside the printer parts, try to remove them too.
4, You can now print a test page by pressing and holding the Cancel button along with the Resume button. The printer would have got reset, and the test print would have resulted well.
5, Even after resetting if the paper jam issue did not get resolved, better service the printer in the nearest HP retail stores.
For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220
Aug 07, 2014 | HP LaserJet M1005 Printer
Hello paper jam error appears with no paper jammed. Then printer refuses to print or doesn't print well
To resolve paper jam issue, follow the steps
1. Open the rear access door.
2. Remove any bits of paper stuck.
3. Clean the rollers using lint free cloth ( upward position )
4. Close the rear access door
5. Open the front panel door
6. Check for any paper stuck between the rollers.
After doing all these steps, to make sure if your printer is working fine, try to make a copy.
If the printer can make copy, Click on the link to resolve printing issue -> Link
Oct 12, 2010 | HP Photosmart 2575 All-In-One InkJet...
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
ON button on hp photosmart C5280 will not turn off. keep saying paperjam but there is no paper.
Open and clean your printer with some air compress can.
Check the cartridges, take out and put them on place again
Unplug the printer for a while and plug in again
Reset the printer to factory settings
If still not shut down, the printer need to be serviced
Solution one: Clear the jam from the back of the All-in-One
Follow these steps to clear a paper jam from the back of the product.
CAUTION: Trying to clear a paper jam from the front of the product can damage the print mechanism. Gain access to and clear paper jams through the rear door whenever possible.
Step one: Remove any loose paper
Remove any loose paper from the input tray.
CAUTION: Do not remove jammed paper at this stage.
Step two: Clear the jam from the rear access door
Press the Power button ( ) to turn the product off.
Unplug the power cord from the back of the product.
Turn the product so that you can access the back of the product.
Press in the tab on the left side of the rear access door to release it. Pull the door away from the product to remove it.
Figure 1: Remove the rear access door
Gently pull the jammed paper out of the rollers.
CAUTION: If the paper tears, check the rollers and wheels for torn pieces of paper that might remain inside the product. Remove all the pieces of paper from the product to prevent more paper jams.
Reinsert the rear door. Gently push the door forward until it snaps into place.
Plug the power cord into the product again.
Press the Power button ( ) to turn the product on.
Press OK to continue the current print job.
NOTE: Sometimes the print job cancels instead of continuing when you press OK . If this happens, restart the print job beginning with the page number when the jam occurred.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Solution two: Open the top cover and clear the jam
If you cannot remove the paper jam from the back of the product, follow these steps to remove the paper jam from the top.
CAUTION: Remove the paper jam carefully, because it is possible to damage the product when removing paper from the top.
With the product still turned on, unplug the power cord from the product.
Raise the cartridge door.
Figure 2: Raise the cartridge door
Gently pull any jammed paper out of the rollers.
Close the cartridge door.
Figure 3: Close the cartridge door
Wait until the product is idle and silent, and then try the print job again.
Solution three: Clean the rollers
Follow these steps to clean the paper feed rollers and the pressure rollers to remove any debris, dirt, or paper scraps.
Figure 4: Remove the rear access door
Lightly moisten a lint-free cloth with distilled water, and then wipe the rollers inside the product with the cloth. Rotate the rollers upward with your fingers to clean the entire surface.
Wipe the pressure rollers on the inside the rear access door in the same manner as you did for the rollers inside the product.
Allow the rollers to dry completely.
Reinsert the rear access door. Gently push the door forward until it snaps into place.
Try the print job again.
Solution four: Reload paper and check the print settings
Follow the steps to reload paper and check the print settings. The print settings must match the type of paper in the product.
Step one: Reload paper
Raise the output tray.
Slide the paper-width guide to its outermost position.
Figure 5: Slide paper-width guide outward
Fan a stack of paper to make sure the pages are not stuck together. Then tap the stack on a flat surface to align the edges.
Load the stack of paper in the main paper tray with the short edge forward and the print side down. Slide the stack forward until it stops.
Figure 6: Load paper in main paper tray
Slide the paper-width guide inward until it stops at the edge of the paper. Do not overload the main paper tray. Make sure the stack of paper fits within the main paper tray and is no higher than the top of the paper-width guide.
Figure 7: Slide paper-width guide inward
Lower the output tray, and then pull the output-tray extension toward you as far as it goes.
Step two: Check the print settings
Open the program that you were using to print when the paper jam occurred.
Click File , and then click Print . The Print dialog box opens.
Click Properties . The Document Properties dialog box opens.
Click the Paper/Quality tab.
Make sure the Paper size and Paper type settings match the paper loaded in the product.
NOTE: A paper jam might occur if the Document Properties dialog box lists photo paper, but plain paper is loaded in the product.
Click OK , and then click OK again to print the document.
Solution five: Reset the All-in-One
Press the Power button ( ) to turn off the product.
NOTE: The product might not turn off after pressing the Power button. Continue to the next step regardless.
Disconnect the power cord from the back of the product.
Disconnect the power cord from the electrical outlet, and then wait 30 seconds.
Connect the power cord to the electrical outlet.
Connect the power cord to the back of the product.
Press the Power button ( ) to turn on the product.
Step six: Service the All-in-One
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Nov 06, 2008 | HP Office Equipment & Supplies
Paperjam in printer
1. Turn the printer off.
2. Unplug the power cord of the printer
3. Open the rear access door
4. Remove the jam
5. Clean the rollers of the printer with a lint free cloth that is moist with water
6. Close the rear access door
7. If you a document feeder open it and try to remove the paper jam and also clean the rollers
8. Close the document feeder
9. Plug the printer directly to the wall outlet
10. Try to print again
Aug 10, 2008 | HP Office Equipment & Supplies
Paperjam
1. Clear the paper jam
a. turn the printer off and unplug the power cord from wall outlet
b. check if there are paper jammed in the input and output tray
c. check if there are paper jammed in the rear door
c1. open the rear access door by pressing the handle to the right and then pull out the door
d. check if there are any paper jammed in the document feeder (if you have any document feeder)
2. Clean the rollers of the printer using a lint free cloth that is moist with water
3. Close the rear access door and then turn the printer on
4. Try to print again
Aug 08, 2008 | HP Office Equipment & Supplies
My paper keeps jamming
Clearing paper jams Paper jams can occur for a variety of reasons but are usually paper related. Follow the steps below to clear the paper jam:
  1. Turn off the all-in-one and unplug the power cord. With the power off, the paper feed rollers will turn.
  2. Open the rear access door of the all-in-one by pressing in on the left side of the access door and then pulling it toward you. NOTE: All paper jams must be removed by pulling the paper out the back of the all-in-one using the rear access door. Pulling the paper out the front of the all-in-one rotates the paper feed rollers in the wrong direction and can lead to additional problems. Figure 1: Rear access door c00101861.jpg Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door.
    • If under warranty, contact HP to obtain a replacement part.
    • Click How to buy on this page to order replacement parts.
  3. From the rear access door opening, gently pull the jammed paper free.
  4. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray. Do not continue to push the paper in after some resistance is felt. If the paper is pushed in too far, more than one page will feed into the all-in-one at a time.
  5. Reattach the rear access door by inserting the two pins on the right of the door into the holes for them (as shown in Figure 3 below) and then pressing in gently but firmly on the left side. Figure 2: Inserting the rear access door guide pins into the holes c00099183.bmp
  6. Reconnect the power cord to the unit and turn the unit on.
Jan 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
Lexmark T644 Laser Printer Logo
5,224 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
