Laptop not holding charge
I have a Toshiba P30 3.06Gz "17. A few months ago the battery stopped holding a charge, now frequently it says battery low when it is still plugged in. It then shuts off.
  • 655 Answers
Remove the battery and pluged in the power suply throu adoptor.
And boot your lap, if its work then changing your battery will fix the problem...........
Thanks
Iqbal
Posted on Apr 01, 2008
My laptop is not switch on even i plugged in....
I was using my laptop just a few hours ago browsing Facebook, when my laptop just completely shut off instantly, and then wouldn't turn back on... the laptop was plugged in at the time.
The laptop shows no lights or anything indicating the laptop it plugged in like usual, and nothing at all happens when I press the power button.
I have tried plugging the laptop out, taking the battery out and holding the power button for 1 minute and plugging back in with no luck.
Also I should add that for about 2 months now ever since I installed Windows 7 I have been getting the message "Consider replacing your battery" and the battery hasn't been holding much of a charge, maybe 25-30 mins. But I don't know if this is the problem because shouldn't the laptop work as normal when plugged in?
Sep 07, 2013 | Lifetime Toshiba Satellite U505S2965...
Computer not charging
Sounds like you got a bad battery probably need a new one. Click here for tech support
Mar 26, 2013 | HP Pavilion Computers & Internet
My 18 month toshiba satellite lap top battery is not taking a charge.
I had a similar problem with a Toshiba laptop. Problem was an issue with the bios being out of date. Go to the Toshiba website, download the bios for your model and install per Toshiba's instruction. That should fix the problem.
Dec 06, 2011 | Toshiba Computers & Internet
My battery will not hold a charge for more than a few hours. It shows it is 100% charges and after a few days with the power orr, the charge is gone and I have to plug in to recharge.
Time for a new battery. My Toshiba "ate" batteries every 6 months. They will onyl recharge a number of times and then...that's all, folks. Replacements are on ebay, etc... BE SURE TO GET ONE with more milliamps than the standard one. They will stay charged longer.
Jan 17, 2011 | Toshiba Satellite M115-S3094 Notebook
Our Super Gaucho 24volts is 2-years-old and barely used. Now the battery is not lasting to long. Is this normal? I mean, with a more frequent charging/use will its performance be improved? Thx ahead &...
Unfortunately the batteries just lose their holding power after awhile, and if you don't keep them charged every few months (like during winter if your child isn't riding, you still need to charge / refresh the battery every 2 months or so, if it isn't charged for a few months, it'll lose some of it's holding power), that's a very common problem. Our 24V Perego batteries for our Gaucho only seem to last like 30 minutes of constant riding (my son rides non stop sometimes for 30+ minutes). If you check out the site modifiedpowerwheels.com , people convert them to use non Perego batteries that run for much longer!
Nov 01, 2010 | Peg Perego Gaucho Superpower
TOSHIBA SATELLITE M45-S165 won't charge Battery. The power connector on the back of this laptop is losse but still powers the Laptop. I bought a new battery and the Battery light does light up on the front...
it could be possible that changing the dc jack at the back may fix the problem however it could be a faulty new battery as ive had a few copies (not original) which would work for a week or so then die or others which wouldnt work at all, i finaly splashed out on a new original battery and it hasnt let me down and i bought it over a year ago.
Hope this helps
Apr 19, 2010 | Toshiba Satellite M45-S165 Notebook
Battery power problem
The battery contains cells (about 12 batteries linked together, normally in groups of 3)
They will die just like any other rechargable battery will.
The main difference is if one individual cell dies, it can dramatically shorten the amount of power your overall battery holds.
Replacement batteries are easy to find, but they can be expensive. If you replace it, then anytime you intend on running the laptop from mains power for an extended period, remove the battery.
Apr 13, 2008 | Toshiba Satellite A105 Notebook
Battery is not charging
Let the battery go all the way dead. You may have to adjust the settings in your bios so that the laptop will stay on until the battery goes completely dead. Then charge the battery. Do this a few times if it does not fix the problem you do need a new battery.
Jan 21, 2008 | Compaq tc4200 Tablet PC
Battery failure
Yes perhaps you can be sure if you BIOS up to date. latest version of BIOS is v1.20. This version has several important fixes including critical battery wake up. You can obtain the BIOS from Toshiba support website. I am adding the direct link for your convenience.
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1721794xml&sliceId=&dialogID=30999201&stateId=0%200%2030995558
BIOS update is a critical process that you should close other applications and make sure computer is on AC power. the update process takes few minutes.
If the Issue persists after BIOS update you can think about replacing the battery, Just to remind you that usually brand new laptops warranty covers the battery for a year. So you have said that its only 11 months, you can think about using warranty.
For Toshiba Tech Support
1-800-457-7777
Good Luck
Jan 10, 2008 | Toshiba Satellite A135-S4467 Notebook
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
