Question about Brother IntelliFax-2820 Laser Fax
How do you reset the phone number I am faxing from?
    New Friend:
  • 120 Answers
Go into the function or set up under caller name and ID. adjust with keys and press set. Lawrence
Posted on Apr 23, 2008
HP 2727nf fax machine Fax not working what is the problem ?
Get an analog phone to test your phone line first. Then, make sure this line is connected to LINE port on your fax machine. Use the same analog phone to connect to the EXT port to test the line again.
Use another line to call this fax number to see whether the analog phone rings. Once you know the line and connection is okay, let's reset your fax machine. See http://www.fixya.com/support/t2503076-hp_laserjet_m2727nf_mfp for the cold reset instruction.
Dec 13, 2016 | HP LaserJet 2727NFS All-In-One Printer
HOW DO I CHANGE THE PHONE NUMBER ON MY FAX MACHINE
go to menu setting there you can see factory default select and press .then machine will reset as factory default.off machine and on it again it will ask time ,date your fax address fax number everything give it.
Aug 01, 2010 | Sharp UX-B750 Inkjet Fax
How do I reset the fax machine to answer on my
Turn off auto receive and set to manual, or unplug phone line to fax when not in use. -Carl
Jul 14, 2009 | Brother IntelliFax-2820 Laser Fax
Fax machine will not reset to be able to answer the phone
When you set your fax machine to answer on a certain number of rings it will answer it on that number of rings expecting it to be another fax machine. If you do not answer it before the aloted number of rings you will not be able to talk since the fax machine will be trying to talk in computer speak. To help you may want to set it to answer after more rings.
Jan 15, 2009 | Office Equipment & Supplies
Hpofficejet: will not receive fax. Sender is given our phone number, our phone is answered and we dial our code -- this no longer works. Cannot find manual. Do we reset the number and how, or what...
I just got a new line just for my SF-5100 fax. It was working before I switched to this phone company. I checked the line on a regular phone and it seemed ok. When I plug it up to my fax machine, when it rings I get this static sound instead of rings. One of my customers said when she tried to fax something, she got that same static sound and it would not go through. When I tried to fax her something, I dialed the number and when the fax machine was repeating the numbers it was a series of that same static sound. Then the operator said I should try my call again - so it did not dial through. A few minutes ago, the screen said RX also. Can you please help?
Oct 07, 2008 | Samsung SF 5100 Laser Printer
Resetting the phone number currently displayed on the top of the page
On your fax control panel, press the MENU button. Choose either INITIAL SET-UP or FAX SET-UP, from the display. You should be able to scroll through the settings until you come to either HEADER, TITLE, NAME, STATION ID., or PHONE NUMBER. You can then use the number and letter keys to change the title and phone number.
Aug 09, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Setting fax ringtone
get distinctive ring service from your phone company, that will get you a different number, on the same line, with different ringing pattern, my tel compnay charges $5 per month, then set the fax options to DRPD, and it will go directly to fax machine, while the phone calls on first number, will go to telepehone.....
Feb 13, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
It is called 'Station ID', press Menu/Set 1 then 3 then put in your number.
Jan 24, 2007 | Brother FAX-575 Plain Paper Thermal
Brother IntelliFax-2820 Laser Fax Logo
51 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
