Question about Ovens
CANNON LANGDALE C50GLK
More of a question then i problem..when you turn the knob of any of the top rings, you can hear the gas come through,you push the knob inward and it ignites,which is how it is suppose to be. Now when it comes to the grill or oven knobs when you turn them no gas can be heard coming through until you actually push the knob inwards to ignite it, which then as to be held inward for a number of seconds or the flame doesnt stay lit...is this the way the oven and grill are spose to work??
docjohn174
  • 943 Answers
SOURCE: Pressure of flames in Cannon gas oven
HI thanks for your question. the part that's at fault, is the igniter. it glows but not hot enough to ignite all the gas. replace the igniter. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
philbran
  • 242 Answers
SOURCE: Flame will not stay lit in oven of countrychef 100g
Yes very simple. There is a bulb the flame is heating with a small tube that runs to the gas valve this is the saftey sensor that is bad called a thermo-couple , they are common to go out and should be easy to find online. Let me know if you have any other questions.
Phil
Posted on Apr 10, 2009
jmgldsmth
  • 1906 Answers
SOURCE: oven lights on low flame but will not come up on
all gas range ovens have a small metal box in the back upper area of the broiler burner; a gas line runs into this box as do two wires; this is a "flame control " gas valve; the way it works is: after the pilot has been lit as you turn the oven temp control a heating element in the box causes a small valve to open allowing a larger amount of gas into the oven burner to ignite the whole burner If you can only get pilot flame on high replace this valve
Posted on Apr 26, 2009
protek480
  • 1723 Answers
SOURCE: Hotpoint cooker, grill doesn't work but top oven does
If the elements 'look' okay, they probably are. The 'infinite control switch' is probably the problem. With out the use of a meter, it's guess work. Unless you can see a connection problem.
Posted on Sep 03, 2009
Testimonial: "very useful thanks"
TheMobilian
  • 8220 Answers
SOURCE: pilot light is lit both on oven and stove top...
On standing pilot ovens the maker uses a safety device to kill the gas in case the pilot blows out. As long as the pilot is lit the gas safety magnet hold the gas flap open inside the safety valve.To save energy the pilot has 2 flames. The standby pilot keeps the cooper/nickel probe/sensor warm so the oven will light faster, the 2nd pilot is much larger, only appears when the oven control is turned on and this is what opens that valve. So when you turn the oven knob on the gas leaves the control and goes downtown to burner land. If that pilot is lit and that slow opening flap inside that valve is open, then the gas will enter the burner tube and ignite when it hits the pilot. Pretty slick ain't it? So what can go wrong? With age the flap inside the safety valve will wear out, get weak, work a little, then take forever to light and eventually just goes bye bye. When you get ready to replace the valve it ain't gonna be adjusted exactamundo, you gotta tweak it. To do so after bubble testing for leaks and lighting the pilot you turn it on and observe the flames. It needs to be not more than half way up the flame spreader. If it is to small of a flame it will take forever to bake even a pie shell, if it is too much their could be burned bottom and in some cases fire hazards. OOPs.
Posted on Apr 06, 2010
Testimonial: "Thanks ! I will use this to investigate further... u da man !"
Unable to replace front control knobs when they go on cannot turn them
the knobs only go on one way, you have to line them up then they will push on. if you have an electric range you have to push on the knob before you turn it. failure to push before turning will result in breaking the knob again.
Feb 04, 2012 | Ovens
How do I lift the stove top to turn off pilot model # FGF366DCB?
there isn't a pilot in it,it has an electronic spark module in it.what problem are you having?when you turn it to lite it you'll hear a clicking sound,that's the sparking that lites the gas just like you're gas grill.if you want to remove the top you have to remove the two phillips screws out of each burner head,sometimes they don't come out and you have to drill them out,if the burner isn't shutting off the gas valve could be broke or the knob could be broke,if it's clicking just unplug it and you can lite the top burners with a match or bbq clicker to lite them until you get it fixed depending on what problem you are having.if the gas won't shut off by turning the knob you'll have to shut down the gas at the valve that feeds the stove.but like i said if you want to lift the top you have to remove all the screws in the burner heads.hope this helps you out.http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Range-Parts/Model-FGF366DCB/1428/0124002?pathTaken=&prst=0&shdMod=FGF366DCB go to this site and you can look up your machine.
Sep 03, 2011 | Frigidaire Ovens
Mad gas flame at back of New World G70M
HI it could be agas pressure problem meter pressure too high get the gas company to check it out for you
Feb 04, 2010 | New World G70m Gas Double Oven
Bottom oven on Cooker Cannon c60gcw will not ignite, continuouos sparking and no gas when knob turned on
Fault caused by trapped and therefore cut wiring to main oven valve at bottom rear of cooker causing wiring overheat melting and open circuiting electrical supply.
Sep 15, 2009 | Ovens
Oven lights on low flame but will not come up on high flame .cannon chester cooker.suspect by pass is not working. Do I need control knob/thermostat with the phial. Thanking you.
Apr 26, 2009 | Ovens
Halogen ring not working
Hi .
It sounds like the temp control is faulty.
Either way you are going to have to remove the hob top to access the controls and elements, Then you can check if the element is getting a feed to it.
Sometimes you can see if the element has gone, .
If you need any further help, let me know.Good luck.
Nov 23, 2008 | Ovens
Mid 90's Magic Chef gas stove
hi there,
since you can smell gas, you have a gas leak. i would recomend checking and cleaning the gas valves. if you can hear sparking, that means it's just the valves. sometimes cleaning the rods will fix the problem.
Oct 10, 2008 | GE JGRP17 Gas Single Oven
Oct 09, 2008 | Ovens
Cooker
I just installed one in my house. I found that when you start the lower (gas) oven you need to turn the dial all the way on to 500*, push the knob in (you should hear the igniters clicking), then even when you see flames coming out of the burner, continue the ignition for 10 to 15 seconds. It should continue to stay lit thereafter.
Apr 01, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
