Question about KitchenAid Dishwashers
I need to know how to change the top rack on my kitchenaid dishwasher. Model #KUDK03ITWH Serial # FU2206278
I got someone locally to help me.
Posted on Apr 02, 2008
Need to replace the adjuster and need instructions how all the parts go together.
Replacing Adjuster Wheels on a Kitchenaid Dishwasher ...
? 2:50
https://www.youtube.com/watch?v=ClCHpDL--Gw
Jan 26, 2014 - Uploaded by natifamily
Replacing Adjuster Wheels on a Kitchenaid Dishwasher. natifamily ... Dishwasher Top Upper Rack Adjuster ...
Whirlpool, Kenmore, KitchenAid - Dishwasher Replacement ...
Nov 29, 2015 | KitchenAid Architect? II S SERIES KUDS03FT...
My Dishwasher door won't latch?
Its probably loose. pull the unit out and tighten it or fix any broken parts.
Aug 19, 2014 | KitchenAid KUDK03ITWH Full Console...
Upper rack track wheel broke
You can try to obtain the part from KitchenAid or an appliance parts supplier. However, you may only be able to get the complete assembly.
Nov 07, 2013 | KitchenAid KUDS30IX Dishwasher
Top rack rails came off the rollers
How to replace the adjuster on the top rack of KitchenAide dishwasher model number KUDS35FXSS1
Feb 03, 2012 | KitchenAid 24 in. KUDS01FLSS Built-In...
I need a top rack part #9741982 for my old Kitchenaid Dishwasher!!! Can anyone help me? thanks so much!
If you contact an appliance dealer that sells kitchenaid I'm sure they'll be able to get it for you.
Jan 09, 2012 | KitchenAid Dishwashers
We have an older KitchenAid dishwasher (Model e) that cleans dishes on the lower rack just fine but not the ones on top. Anyone have any ideas why or fixes?
Be sure you are not blocking the spray arm for the top rack. If your dishwasher has a telescoping spray arm in the botton center that retracts when the dishwasher is off, be careful about covering it with the dishes
Sep 17, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
My kitchenaid dishwasher won't stay shut. It pops
Check that there isn't something still in the very back of the rack (top or bottom) that's sticking out and keeping the rack from sliding all the way in. Similarly, if the problem goes away when you take the racks out, the problem is with the racks. Otherwise, it's the latch: either the eye (attached to the top of the machine) is bent/broken, or the hook (inside the top of the door) is broken. Good luck.
Mar 03, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Top rack whisperquiet dishwasher no water
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/8573754.pdf
I know this isnt the same model, they dont carry your manual as of yet. But it does have some suggestions to look at on page 17. I had the same problem and I looked really carefully and found my sprayer arm was blocked. I cleaned it out and havent had a problem with it again. I do check it regular now.
Sep 27, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
KitchenAid KUDK03ITWH dishwasher will not pump water out
Well,
You bought this on my birthday, so there can't be anything wrong with the dishwasher. :-)
1) Check that the drain hose did not get pinched during installation.
2) Check that the hose leaves the dishwasher in an upward fashion, to the bottom of the counter-top, before heading back down to the dishwasher connection.
3) Did the dishwasher ever work properly? And if it did, were you using the sink at the same time?
Reply back what you find out. Will be glad to help more.
Feb 02, 2009 | KitchenAid Dishwashers
Upper rack dishes not cleaning well
Yes, run an empty load with 1/4 cup vinegar. It sounds like there is mineral build up in the arm. Try to take the arm apart that supplies water to the top rack of the dishwasher. You can soak this in vinegar water once removed.
Jan 20, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
50 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
