Question about Car Audio & Video
RENAULT SCENIC 2004 MODEL ELECTRIC HAND BRAKE
Fitted new brake pads brakes O.K. but warning light on dash still on. How do I reset.
  • 2 more comments
  • hells 1312 May 17, 2008
    Hi have a renault scenic megan 1.4 3003
    The problem is the electric hand brake is not working. Pads are ok.
  • jgmac Jan 03, 2009
    when ever i release the electric handbrake it does not release properly so what can i do, can release it in the boot temporary renault scenic 7 seater 2005
  • Anonymous Feb 22, 2009
    2004 scenic got fault code (redundant brake switch on)
  • c roskell Feb 22, 2009
    2004 scenic fault code(redundant brake on switch internal electrical) what does this mean?
    New Friend:
My renault scenic just failed its MOT,the test examiner said i had no handbrake on my drivers side.On the fail form it reads axle 2 (pb) 0.17kn.What does this mean and how do you fix it.
Posted on Apr 16, 2010
SOURCE:
2014 Ghibli. If I replace brake pads and discs does brake warning light turn off by itself or need to be reset?
If you're talking about brake pads that have an electrical connector..
the warning light comes on when the pad is so worn that it allows the electrical connector to earth via the disk .. hence the warning light.
Fitting new pads will not cause a warning light on your dashboard. No reset required.
Dec 22, 2015 | Maserati Cars & Trucks
A Renault scenic we are buying gas a light on continuously on dash saying error code check hand break/gear box is this a big problem
Hi if that has an electric park brake don't buy it the motor and control unit are troublesome if they are gone it will cost up to 1,000 my advice is run!!!
Apr 16, 2015 | Renault SCENIC Cars & Trucks
Faults with renault scenic 2005 dci
the switch is malfing.
  1. You fix it.?
  2. replace it.
  3. get help (hands on)
  4. have it fixed.
May 19, 2014 | 2005 Renault Scenic 1.6
Clio 2002 authentique 1.2 8 valve stop light & hand brake light stay on in the dash can anyone help!
hi from uk the stop/handbrake light has two warning functions it will illuminate when hand brake is applied or is left on whilst driving or not fully off position ?? the other function is it is warning you that your brake fluid in the reservoir is low/requires topping up ? if it is low ? this could be due to a fluid leak ?either from pipes or wheel cyl's/calipers ? OR ? just that as your b/pads and shoes wear lower then fluid from reservoir displaces from res to cyl's to compensate for wear so may i suggest you 1st check fluid level+top up if low? then check for leaks as above more important have your brake pads and rear shoes or pads if fitted checked for wear/safety i advise this considering age/milage? of car and if you have no record of being checked/replaced recently? if your brake pads are fitted with low pads wear indicators this will also give warning hope this helps? good luck !
Mar 17, 2010 | 1986 Renault Sport
On my renault scnic 05 model i have an warning light and it tells me to check the hand brake which i have done many times but the light will not go out i had let my battery run down in the could spell and...
hi from uk the brake indicator warning light you mention has two functions it indicates thet the h/brake is either on or not fully off ? and is also an indication of the brake fluid level is low this may be either your car has a brake fluid leak ? somewhere or more than likely considering age of car the brake pads/shoes are worn low resulting in the displacement of fluid from reservoir to take up wear of pads operated by calipers/cylinders ? also if pads are low ?thenyour car may have brakepads worn very low indicators on the actual pads these are wires fitted on pads this too is a most probable cause of indicator illuminating ? SO asap check the above i have mentioned b4 you continue driving for any distance
Feb 05, 2010 | 2005 Renault 18I
Renault scenic flashing warning light on right of display bottom row right hand corner. i do not have a manuel so can you tell me what this means? looks like a circle with a line in.
check your brake fluid level( as this light is the hand brake warning light) but if it comes on with the hand brake in off position and ignition on it warning low fluid level in the braking system
May 16, 2009 | 2001 Renault Sportwagon
Hand brake light wont go out
this sounds like the brake pads may have worn down and the sensors have lit the warning light on the dash, check the brake pads and if the thickness of the pad is at about 3mm then a new set of pads and sensor will be required
Jan 22, 2009 | 1989 BMW 3 Series
Emissions warning light on Renault Grand Scenic II, 2004 1.5 DCi
i have a renult scinic 2004 1400cc emissions warning light on running uneeven and loss of power can this be sorted out what is it
Nov 25, 2008 | 2000 Renault 181
Car Audio & Video Logo
4,079 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
