Question about KitchenAid 24 in. KUDI01ILBS Stainless Steel Built-in Dishwasher
KitchenAid 24 in. KUDI01ILBS...
I have a load of dirty dishes in the washer and it won't come on. The buttons will light up but nothing happens when I push the START button. I have turned it off at the circuit box and allowed the computer to reset (KitchenAid suggested I try this) but that didn't work.
  • ChefSusie Apr 01, 2008
    How do I figure out which one it is? This problem has been ongoing for a few weeks. It seems hit or miss as to when it will come on. That makes me think it is not the motor, but rather a fuse or electrical problem. What do you think? Also, it the thermal fuse something that my husband (who is a handy kind of a guy) could replace with common tools?
    Genius:
  • 3,422 Answers
HI,
Please read the following troubleshooting steps properly.Few of the steps which i mentioned here can be tried out byurself and for the others if it is a serious problem you will have to call a technician to get it repaired.
Problem: dishes don't get clean enough.
Solution: Many times it's just bad detergent at fault. Some detergents are less powerful the longer they go unused. Some new detergent may be all you need. If that doesn't solve it, it could be the way you're loading the dishwasher. Make sure nothing is obstructing the spray tower or arms. It could also be that the water wasn't hot enough. Don't run the dishwasher right after everyone's just taken a shower. If you have a water conditioner in your house, it may be time to refill it with salt.
Remember, these are just some of the more common problems with the most common solutions. With appliances, there are an infinite number of potential problems you may face. Hopefully, yours will be one of the easy ones. I hope with these guides, we can help you save some time and money. To save you even more time and maybe a headache, be sure to have your dishwasher's make and model number when heading to the parts shop.
Problem: The dishwasher won't turn on at all.
Solution: With every electrical appliance, it pays to check the power at the source. Make sure the breaker is on. If it is, then check the power at the dishwasher. If it's hardwired, go back and turn the breaker off. You will have to open the dishwasher door, unscrew the screws holding it in place underneath the countertop and shimmy the unit out. The junction box is located at the rear, on the bottom. Open the junction box and check the wires for corrosion, breaks, or loose connections. Check the interior of the box for any burn or "arc" marks. If everything is clear, turn the power back on and check for voltage by probing the black and white wires. If you get no voltage, the breaker may be bad.
If this isn't the problem, then here's a few other things to check:
  • The door latch switch may be bad -- Open the door's access panel and set your VOM to RX1. With the latch in the "open door" position, probe the two terminals. You should get a reading of infinity. Now close the latch and probe again. The reading should be zero. If not, replace the latch switch. If it's a matter of the latch switch not closing, then you probably just need to adjust the latch. Loosen and reposition the latch and re-tighten. You want a nice, tight seal on the door when it's closed.
  • The control timer motor could be bad -- With the control panel off, disconnect the motor leads from the timer. Set the VOM to RX100 and clip the probes to the lead wires. If you get an infinity reading, or a very high resistance, then the motor is bad.
Goolduck,
Please don't forget to rate the solution.
Posted on Apr 01, 2008
  • Priya darshan Apr 01, 2008
    was that comment for me?
    I have mentioned out all the things clearly to help you fix the problem already..
  • 2,335 Answers
The motor could be defective on this appliance and will need to be replace, it could also have a defective thermal fuse.
Water in bottom of dish washer. power to washer, but nothing. no lights on controls, nothing. will not do anything
According to the information you gave, your model had an issue with the thermo fuse inside the control panel inside the door. This can blow for only one reason, the wires carried heat back to it. In the replacement kit link below, you will find a line break, this line break will prevent this from happening again. Fail to install this kit completely will end up doing it again.
Fuse Kit
Please install completely, you can purchase this from any part house or from the link I sent you.
Good Luck.
Aug 17, 2011 | KitchenAid 24 in. KUDI01ILBS Stainless...
Dishwasher won't start KUDIO1ILBS
How old is this dishwasher that you are using? Is this under warranty
Apr 24, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Soap gets clotted is soap dispenser. Dishes greasy and dirty after cycle.
Hi, the soap is clotting because there isn't enough water being sprayed around inside. The water spray washes the soap out of the dish, if all is working well. My machine had the same problem. I had sufficient water level, but the spray head wasn't spinning very well. I found the end-most hole in the spray bar to be plugged. It is the end hole that provides a jet that makes the head spin. I cleaned a bunch of debris out of the hole and the machine started working and cleaning like it was new.
Jun 26, 2011 | KitchenAid 24 in. KUDI01ILBS Stainless...
The soap dispenser opens while in cycle but it doesn't wash the dishes they come out greasy and the entire washer is dirty It does get hot but dishes come out dirty Model FP4702799 Serial KUDIO 1ELB L3
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 22, 2011 | KitchenAid 24 in. KUDI01ILBS Stainless...
KUDE60FVSS Clean light is only flashing
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Mar 15, 2011 | KitchenAid 24 in. KUDI01ILBS Stainless...
Mould on inside of washer
The water may not be heating up. Does the DW feel warm to the touch when it is washing? How long do you leave dirty dishes in the machine? Do you empty the clean dishes right away. If you do not you should open the door a crack to allow the steam and moisture to escape so the dishwasher can dry itself.Some people who don't have a lot of dishes don't wash them often enough and this can happen. You should inspect the inside of the diswasher for food debris build up even in the little holes of the arms, which you can pull out with needle nose tweezers.You can't use bleach to clean it. Nor any other household cleaners.I would clean it with very hot water mixed in a little bucket with some dishwasher detergent. You don't want to introduce any other kind of detergent into it. I would clean it thoroughly, using a semi rough washcloth then use a clean cloth to rinse it off with hot clear water. Then I would run a full cycle with no dishes in it.Maybe even twice. I hope this is helpful!
Dec 16, 2010 | KitchenAid 24 in. KUDI01ILBS Stainless...
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
Upper rack dishes dirty
Is it filling with enough water. Look or if you don't know how much water is supposed to be there , Just add a gallon of hot water to the machine after it fills. If this solves the problem check the filter in the fill valve or replace the valve.
Jul 04, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
I have the same problem. Sometimes after trying and trying again it will start. Sometimes I hit cancel, wait for it to 'cancel' and then sometimes it will start.
I'm getting fed up.
Apr 01, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Diswasher stopped working
there is a fuse in the washer that needs to be replaced reply to me and will walk you through it
Dec 31, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Open Questions:
See all KitchenAid 24 in. KUDI01ILBS Stainless Steel Questions
KitchenAid 24 in. KUDI01ILBS Stainless Steel Built-in Dishwasher Logo
203 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
