Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer will not spin sometimes
Hi Catriver,
My washing machine runs fine until I get to the spin cycle. It will spin if I take some clothes out (down to 3 or 4 pieces of clothes). I have to run about 4 spins cycles by taking clothes in and out. It will not spin w/ all the clothes in the washer. Do you have any suggestions what could be wrong?
Email address:
Note: not sure what model it is right now. I had to put something in.
  • rjreyob Apr 04, 2008
    clucth went bad. Fixed and running again.
  • 1,198 Answers
Look under for the belt(s). Belts must be clean and dry, and in good shape, no oil or grease on them. If the machine is leaking on the belt, it will slip. Detergent will make the belt slip.
Posted on Apr 03, 2008
Bosch maxx plus wfo 2260 will not spin it is working fine up until it is time for the spin cycle. Sometimes I have to stop the washer then just put it on to the spin cycle sometimes this works sometimes it...
Sounds like it is not rinsing properly.
If you have not already done so, then check the pump filter.
This is located at the bottom front right of basher behind drop down cover.
Unscrew anti-clockwise to remove and clean.
Mar 25, 2010 | Bosch Washing Machines
Washer will not spin sometimes/ Safety switch broken and I need to lift the lid to install new switch. Any suggestions?
If you are talking about replacing the lid switch, the following link explains how to remove the washer case to access:
The intermittent spin cycle problem is generally a clue that the lid switch may be malfunctioning in some way. If you've already diagnosed this to be your problem, then the link I provided will give you the necessary guidance to complete this repair. If you have any questions along the way, please let me know. I hope this is helpful to you.
Jun 03, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Machine not spinning due to uneven load balance although clothes are loaded evenly initially
I suggest you stick to the maximum load capacity (or less) of the machine; and not over-load the machine with clothes.
Apr 14, 2007 | Haier XQJ50-31 Top Load Washer
Kenmore washer
Lori, first check the lid switch, if it's broken, it won't spin or drain. Put it into spin and hold the switch down, see if it drains. Check that back.
Feb 23, 2007 | Kenmore 20722
Rinse cycle spinning... clothes still soaked
It sounds like your washer is not going through it's neutral drain. After agitation, your washer should pause and drain for around 90 seconds to pump out the water before spin. Check this out by starting a wash with a small screw driver holding the lid switch down. This will allow you to observe whether or not it's going through it's neutral drain. If not, it's a transmission problem. The trans is covered under warranty for 5 years. You may also want to check the pump to see if it's gunked up. back.
Dec 04, 2006 | Kenmore 24982 Top Load Washer
Washer will not pass wash cycle...Will not Drain
Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad back.
Nov 08, 2006 | Roper RAS8445KQ Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
138 people viewed this question
Sal De
 Brian Main
Brian Main
