Question about Dryers
My Whirlpool clean touch 7 cycle 4 temperature gas dryer is not igniting?
    Genius:
  • 3,422 Answers
HI,
The gas burners won't ignite until the gas safety valve releases gas to the burner area. A temperature control system, or thermostat, helps the dryer to maintain an optimum temperature in the drum. This system can help to prevent any scorching of your clothes, and it also reduces the hazard of fire.
I would strongly recommend to get it repaired by a technician
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 01, 2008
  • 4,234 Answers
I am not familiar with your particular model but there are 2 ways that the flame can be ignited. Older models use a pilot light which is a very small flame and uses little gas. More modern models (yours fits here) use a small igniter similar to those that are on gas grills. These igniters will fail over time. I would suspect that the igniter is bad.
Dan
  • 2,322 Answers
Does the dryer work with the other temperature cycles?
    Guru:
  • 1,894 Answers
Then there is problem in the power circuit sir
What is wrong with a whirlpool 4 cycles 3 temperature dryer that will not get hot?
First clean the vents inside the dryer and to the outside be sure and clean around the blower wheel. Check the thermal fuse, the cutout fuse & all the thermostats. Check the heating element also check that it is not grounded to the heater box. Last check the centrifical switch on the motor as the heater runs through it.
Hope this will help you
Feb 27, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Non Glowing Igniter
What solenoids are you referring to?
When you set the timer and heat selector switches on your dryer and press the button [switch] to turn it on, the direction of 120VAC passes through the heat selector switch through the timer switch through the cycling thermostat through the hi-limit switch, through the thermal cut-off fuse to the burner assembly's gas valve.
Simultaneously, as the current is traveling through a path to the 1st gas valve coil, current is also traveling through a path to the flame sensor- and then to the igniter.
The igniter will begin to glow and when it gets hot enough, the flame sensor will detect the heat and switch off. which then diverts current to the second gas valve coils.
The second gas valve coils activate plungers in the gas valve which allows gas to flow out into the burner housing. The igniter still being hot, ignites the gas to a long blue flame.
To maintain the proper air temperature, the heat in the blower housing is monitored by the cycling thermostat. During normal operation, air temperature should be between 120 degrees Fahrenheit and 160 degrees Fahrenheit.
When the air reaches the proper temperature specific to your dryer model, the cycling thermostat will switch off the voltage to the burner assembly.
The hi-limit thermostat and thermal cut-off fuse monitor the drum air temperature. If there is an air flow problem [restriction or total blockage], the hi-limit thermostat may switch off the voltage to prevent damage to the dryer.
Eventually, if the air flow problem [restriction or total blockage] is not corrected, the thermal cut-off fuse will fail (blow) and the dryer won't heat at all.
Check continuity to the following components, thermal cut-off fuse, hi-limit thermostat, igniter, flame sensor, and cycling thermostat. Of course you will take your readings with the power cord of the dryer unplugged from the wall outlet.
You will either disconnect [isolate] any of the wire leads going to their respective components during the test [using a multimeter (analog or digital)]; OR remove each of the components entirely from the dryer to test them.
1.) A good thermal cut-off fuse will have 0 Ohms of resistance. On the other hand, if the needle [on a an analog tester] does not move OR the digital display [on a digital meter] has not changed significantly, there is NO continuity - which means the fuse has burned out and needs to be replaced
2.) A dryer's Hi-Limit Thermostat is activated by hi-temperature changes (between 250 degrees Fahrenheit and 300 degrees Fahrenheit.
A good hi-limit thermostat will have 0 Ohms of resistance at room temperature.
To test the thermostat's response to temperature change, place the component on an electric griddle or skillet. Set the heat on the skillet or griddle to the appropriate temperature according to the temperature rating stamped on the hi-limit thermostat you are testing. If the hi-limit thermostat switches off within 5% of that temperature, the part is functioning properly. However, if the hi-limit thermostat does not switch off OR switches off prematurely, the hi-limit thermostat is faulty and will have to be replaced. [Remember, when the switch turns off at the appropriate temperature level- you should get a high resistance reading to show that the circuit is "open")
3.) Perform the same procedure as step 2 to test the Cycling Thermostat: First at room temperature and then its response to temperature change. The only difference is, the test temperature range will be somewhere between 120-160 degrees Fahrenheit Once again, refer to the temperature rating stamped on the component you are testing- and the 5% tolerance remains the same, too.
4.) The resistance reading for the igniter is between 50 and 400 Ohms of resistance; anything else, it's faulty- toss it and replace it.
5.) You should get a resistance reading of 0 Ohms at the flame sensor-
Flame sensors are tricky though. Flame sensors could still short out and
allow the igniter to glow- but would prevent voltage from reaching the gas coil. For example, the igniter will glow and not turn off and a flame will not be established because there was no voltage at the gas coil to open up and release gas for ignition.
Hope this info helps...I would appreciate a follow-up from you when you resolve this problem- to gain more knowledge and skill.
Thank-you and best wishes on your project
Jul 15, 2013 | Whirlpool LGR3624JQ Gas Dryer
My gas dryer model # lgr3624eq1 coils are lighting up and igniting for approx 10-15 seconds. after that the coils will only light up for 10 sec. and dim down without igniting. from this point it continues...
check the thermostats they look like this http://www.partselect.com/assets/repair/images/Dryer_thermostat.jpg Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. We strongly recommend that you test your thermostat at room temperature. if that doesn't work, or the thermostats check out to be fine, replace the coils on the gas valve itself, you can see them here http://www.google.com/products/catalog?q=gas+valve+coils&um=1&ie=UTF-8&tbm=shop&cid=4089675631004876356&sa=X&ei=T-kQTsTCF4SmsQOlssWuDg&ved=0CC0Q8wIwAQ
Jul 03, 2011 | Whirlpool Gas Dryer Flame Sensor 338906
My dryer heats up,, glow works, igniter works,, then cycles approx 3-4 times then stops cycling
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 18, 2010 | Whirlpool LGV4634JQ Gas Dryer
Whirlpool gas dryer. Ignites at the start of cycle but not again.
You will think this is crazy but change the ignitor and it will work again...
If you have a gas dryer.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 22, 2010 | Amana ALG643RB Gas Dryer
Amana gas dyer wont turn model #lga30aw
Hi.
If the machine stays completely off, does not ignite, does not spark, does not turn, and does not show any sign of power, check the power outlet, and the power cord.
If the machine starts, ignites, but the drum does not turn, then the following parts must be tested:
PS2166310 Motor Switch Kit (part 3 diag 2 )
PS2021298 Motor Assembly (part 5 diag 2 )
PS2046298 TIMER, 4 CYCLE (part 5 Diag 1)
If the Dryer does not ignite or does not heat test the following:
If it does not ignite:
PS2039618 BURNER IGNITOR ASSY (part 7 - diag 4)
PS383994 Two Terminal Gas Valve Coil (p.8 -d.4)
PS383993 Secondary Coil Valve (p.12 d.4)
PS2046673 VALVE,ELBOW SHUT-OFF (p.14 - d.4)
PS2039380 Gas Valve Wire Harness
PS2201082 Limit Thermostat (part 7 - Diag 3)
If it turn but does not heath check also fan assembly and PS2046273 Cycling Thermostat (part 27 - Diag 2)
Here the diagrams
Mar 13, 2010 | Amana Dryers
Gas Dryer. Heat for only one burn cycle.
Try vacuuming out the intake and exhaust of the burner to remove any lint or other debris. If no help, the main burner may need to be replaced.
Feb 03, 2010 | Dryers
Drying on-and-off
I would replace the coils on the burner valve assy.
Mar 17, 2009 | Whirlpool Dryers
Dryers Logo
78 people viewed this question
Top Dryers Experts
