Question about Panasonic PTL-520U 2000 ANSI lumens/SVGA LCD Projector (PTL-520U, PTL520U) Multimedia Projector
T5AH250V You have a post mentioning that you replaced the fuse T5AH250V for your projector - where did you buy the fuse, as I am unable to find it anywhere. Thanks, Sumeet [email protected]
  • 563 Answers
Hi there
You can buy it from your nearest TV or AV Repair shop.
Posted on Apr 03, 2008
    New Friend:
Help my panosonic PTL-520U has a good picture but the color is blue what could be wrong email me please [email protected]
Posted on Nov 29, 2009
6ya staff
SOURCE:
A slide got stuck in the projector, and when I took it out the projector just died. No power. Any ideas about what's happened? Thanks
If this is a Kodak Slide Projector, there are 2 thermal fuses (1 is in the motor and NOT replaceable and 1 is in the area of the lamp). Almost ALL Kodak projectors had 2 thermal fuses as described. You need to determine the model, as that will determine which fuse or motor assembly you will have to buy & install to fix your projector. If its a Kodak, let me know the model and I can help you further! You can buy parts for Kodak projectors at: www.micro-tools.com.
Good Luck! Jim
Feb 04, 2013 | Office Equipment & Supplies
I lost my fuse to my Iriver fm transmitter and no one knows what fuse i need to buy! I cant find info anywhere on what fuse it uses
I have found several mentions that the standard fuse is 0.5 Amp.
Considering the amount of power such devices draw this is a reasonable value for the fuse.
Feb 11, 2011 | iRiver AFT-100 FM Transmitter
NEC VT660 Had large black oval on screen when on surrounded by yellow tinge, set against blu background Just replaced globe and still have same problem?
From what you have described it sounds like a damaged internal lcd panel, can you post a photo anywhere and I can confirm?
Feb 24, 2009 | NEC VT47 Multimedia Projector
250V T6.3AH Slow Blo Fuse
Depending upon the way in which the lamp finally smoked, it is not unusual for the feeder fuse to blow. Replace the fuse and try the projector. As long as you haev a new lamp, it should work OK.
Dan
Sep 11, 2008 | NEC VT670 Multimedia Projector
Epson 7300
Hi there
The Epson Powerlite 7300's lamp has got a chip on the side of the lamp's bracket that resets the lamp timer automatically when a new lamp is inserted. And it only does it once - first time the unit is switched on after replacing with a new lamp.
The fuse on this chip blows and causes the lamp timer to be reset. Unfortunatelly this is the only way to reset the lamp timer on this model. There is no manual way.
So to cutt to the chase , you will have to buy the original lamp and replace it before it will reset.
Part Number is : ELPLP05
Apr 17, 2008 | Office Equipment & Supplies
Power problem
Hello BobSmalley,
From your post, I gather that you know your way around electronics. So, why don't you use a VOM (Volt Ohm Meter) to trace power starting at the PS and see where you lose it. You may find a blown fuse along the way as you didn't mention fuse status (and that projector surely has one). If you do have access to a meter you could also check the ballast to see if it's putting out enough voltage for the lamp. But since you stat that it doesn't power up at all, I would lean towards the Power Supply (PS) and locating the fuse (could be an AGC, etc... or a printed circuit fuse soldered in circuit right on the component side of the board near the edge where power comes in).
Keep us posted, and Good Luck.
Mar 10, 2008 | Optoma EP716 Multimedia Projector
Ballast Assembly Replacement
post the number on ebay see if any are availble
Jan 09, 2008 | NEC (50019497) Projector Lamp for VT440,...
Faulty projector
You will have to give a Make and Model of your Projector.
Could either be your lamp that needs replacement or a faulty Ballast ( lamp's powersupply )
Nov 09, 2007 | Toshiba TDP-T45U DLP Projector
Open Questions:
See all Panasonic PTL-520U 2000 ANSI lumens/SVGA LCD Questions
Panasonic PTL-520U 2000 ANSI lumens/SVGA LCD Projector (PTL-520U, PTL520U) Multimedia Projector Logo
2,186 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
