Question about KitchenAid 24 in. KUDI01ILBS Stainless Steel Built-in Dishwasher
Dishwasher won't start KUDIO1ILBS
I have a load of dirty dishes in the washer. When I push the buttons, they light up but won't come on. Do I need to replace the control panel?
I have the same problem. Sometimes after trying and trying again it will start. Sometimes I hit cancel, wait for it to 'cancel' and then sometimes it will start.
I'm getting fed up.
Posted on Apr 28, 2008
  • handymanSkip May 04, 2008
    Follow up.
    I took apart the electronics area on the console (After unplugging the unit of course). There were cobwebs/spiders/stuff in there. I dusted everything off, used some good electronics cleaner since there were IC's, capacitors and such. I put in some bug spray for prevention. Has been working like a charm ever since.
    Perhaps the BUGS were short circuiting the workings.
Dishes are still dirty. I have used every kind of dishwasher aide, half loaded it and dishes are still dirty, I let the water run until very hot before starting the washer. The washer says you don't have...
Suggest the problem may be a plumbing issue - likely substantially blocked drain system, so the dirty wash water cannot properly pump out but rather remains in the dishwasher.
Suggest getting a plumber in to "snake" out your kitchen drain system. You will probably notice your sink drains will suddenly work much better too...
Aug 02, 2010 | Dishwashers
How old is this dishwasher that you are using? Is this under warranty
Apr 24, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Dish washer will not latch
Latch is locked, but the door is open, panel will not light up. Tried to close door after loading, wouldn't close, water started running, tried to figure out what was wrong, something in the way, etc, but nothing. Then water sprayed all over, started pushing buttons, and finally it quit, now latch is locked, but the door is open.
Jul 01, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
The clean light is blinking and I can not start a new load. I have cleaned out the washer and loaded dirty dishes and it will not start
Press the heated dry then normal wash buttons in the same sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the cancel button.It will clear any existing faults and makes the dishwasher to operate normally.
To prevent the issue from recurring, run your hot water faucet first to ensure that hot water is present in the entire supply line before starting the filling.
Please let me know if these does not resolve the problem.
Nov 30, 2009 | Refrigerators
Flashing green ''clean'' light and will not start a wash cycle.
the computer senced that the heater did not work last cycle. Push your sani clean, energy saver button s back and fourth a few times. It will run a self diag cycle. let it run for a few min. If it happens again your heater may have burned out.
Nov 11, 2009 | Kenmore Elite 45986 Front Load Washer
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
Kenmore dish washer lights up but will not start wash cycle.
turn off your dishwasher then try it again ok
Feb 27, 2009 | Kenmore Dishwashers
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
Diswasher stopped working
there is a fuse in the washer that needs to be replaced reply to me and will walk you through it
Dec 31, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Turning on dishwasher
although the light may be a true indication of a pending problem, try this test: Find the circuit breaker and switch it off to remove power to washer for 30 minutes. Then power back up. Any changes? If light still on, then threat of trouble is real and must be fixed. Not sure what to CLEAN, though. Search for manual online...I'm sure Kenmore put that light on for a real purpose.
Jun 14, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
Open Questions:
See all KitchenAid 24 in. KUDI01ILBS Stainless Steel Questions
KitchenAid 24 in. KUDI01ILBS Stainless Steel Built-in Dishwasher Logo
207 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
