Question about Brother HL-5240 Laser Printer
No longer prints envelopes from manual paper feed
After upgrading to Apple OS X 10.5 the Brother HL-5240 no longer prints envelopes from the manual paper feed tray. The printer will only print from the automatic paper feed tray.
  • 2 more comments
  • macmick Apr 22, 2008
    how do you do the simple change in configuration?
  • Anonymous Mar 14, 2014
    how do you lower tray 3 paper feed
  • Anonymous Mar 23, 2014
    Try to print, paper tray is properly full, still get "out of Paper" error and won't print.
  • Anonymous Mar 24, 2014
    the printer won't pick up the envelope. Just says it is out of paper
You need to change driver configuration
very easy
elvis
Posted on Apr 18, 2008
SOURCE:
HOW TO PRINT ENVELOP IN BROTHER HL 5240
straight paper path. take out tray and toner.. pop down back the paper will be in one of the places.. check for nicks or damage to leading edge of the paper. If its labels get back to us.
Jul 26, 2014 | Brother HL-5240 Laser Printer
How to load evelopes HL 2140
Brother Hl 2140 Printing on thick paper, labels and envelopes 2
When the back output tray is pulled down, the printer has a straight paper path from the manual feed slot through to the back of the printer. Use this paper feed and output method when you want to print on thick paper, labels or envelopes.
Open the back cover
Open the manual feed slot cover.
Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
Using both hands, put one piece of paper or one envelope in the manual feed slot until the front edge of the paper or envelope touches the paper feed roller. When you feel the machine pull in the paper, let go.
• Put the paper into the manual feed slot with the side to be printed face up.
• Make sure that the paper or envelope is straight and in the proper position on the manual feed slot. If it is not, the paper or the envelope may not be fed properly, resulting in a skewed printout or a paper jam.
• Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
• If you put any Media (paper, envelope and so on) in the manual feed slot before the printer is in the Ready state, the media may be ejected without being printed on.
Jul 18, 2011 | Brother HL 2140 Laser Printer
My Brother HL-5240 printer constantly has the paper light on even though there is paper loaded
You probably printed a document that was forced to the manual feed. Place some paper there and it should print. Go to your printer preferences and set the default tray to tray1 instead of Auto.
Jan 31, 2011 | Brother HL-5240 Laser Printer
My brother HL-5240 won't feed from paper tray, only manual feed. It makes a clicking noise. Toner is newer, definitely not empty. I've tried all the tricks of removing some paper, using different paper,...
Pull out a paper cassette, lift up the printer and under you see paper feed roller (it is rubber), just clean roller with cloth and water or alcohol.
Jan 28, 2011 | Brother HL-5240 Laser Printer
PRINT LABELS
You will need to use the manual feed slot which is above the paper tray.
The manual feed is meant for labels and envelopes
Dec 02, 2009 | Brother HL-5240 Laser Printer
It won't print - says manual feed - load paper tray. Its a brand new printer (Brother HL-4040CDN) and the paper tray is full
The printer has an "alternate" feed, i.e., for envelopes and/or for special paper.
Open the door to access that "manual" tray, take some paper from the "normal" tray, and insert the paper into the "manual" tray.
Or, on the printer's controls, set the "standard" feed, rather than the "manual" feed, and press PRINT.
Nov 11, 2009 | Brother HL 1440 Laser Printer
Strong Noise on Brother HL-5240
Make sure the end tab in the paper tray is not too tight. The tab where you set the paper length. The paper should have about 1/16 inch space and not hold the paper too tight.
Jul 02, 2009 | Brother HL-5240 Laser Printer
Brother HL-5240 printer problem
This usually means a print job is stuck in the queue that was set to "manual feed" or to a different paper size, such as legal. Add paper to the front manual feed and press "Go". If this is the problem, the stuck document will begin printing from the manual tray.
To clear the problem without printing from the manual feed, cancel all jobs on the printer, delete any jobs out of the Windows print queue and restart the computer.
Dec 04, 2008 | Brother HL-5240 Laser Printer
HL-2140 printer: error light on: But, paper is in the tray. I have removed the tray several times and returned it. I have turned the printer on and off. THis problem occurred right after printing on the...
pls. try to download the latest driver from your printers website and upgrade your driver. updated driver will fix the problem.
PS, pls vote. tnx
Sep 15, 2008 | Computers & Internet
Printing envelopes and labels
I foubd the Brother website to be very helpful with my label and envelope printing:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000063/faq000063_007.html?reg=us&c=us&lang=en&prod=hl5240_all&Cat=4
Apr 01, 2008 | Brother HL-5240 Laser Printer
Brother HL-5240 Laser Printer Logo
472 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
