Question about Samsung SF 5100 Laser Printer
My samsung lcd error message reads fuser error
  • 1 more comment
  • Anonymous Mar 27, 2009
    show fuser error
  • Anonymous Apr 29, 2009
    CRU FESER ERROR
  • belma May 11, 2010
    I have a problem with my samsung laser SF-5100...keeps reading fuser trouble.
I need fuser error solution as soon as possible please.
Posted on Oct 13, 2008
Massage error CRU fuser Error
Posted on Jul 30, 2008
3 Suggested Answers
  • 8 Answers
SOURCE: error message Engine Fuser Overhaet
The fuser rollers (large orange rubber rollers visible with top cover open) are getting too hot, or the temperature sensor/wiring is faulty and misreading the temperature. Assuming sensor is okay, check the exhaust fan is running and expelling warm air as over time it will clog with dust and the fuser unit won't be cooled effectively.
Posted on May 04, 2009
  • 113 Answers
SOURCE: Samsung CLP-650N Engine Fuser Inverter Error 3
the fuser and dave home drive got to be repalce.
most likely it has worn out.
Posted on May 13, 2010
May 10, 2010 | Samsung CLP 315 Laser Printer
Samsung clp-300 Error message is "fuser low heat error
The problem is that the Fuser is not heating up. Its possible you have a broken heat lamp.
The Fuser will have to get replaced, if you want to spend less but more labor, the heat lamp can be ordered.
Mar 07, 2010 | Samsung CLP 300 Laser Printer
Samsung clp610nd ADC Power Slope
this would be a problem with the fuser unit. the analog to digital converter, ADC, is malfunctioning or there is a problem with the heat being put out by the fuser itself. if cycling the power doesn't clear the problem you will more than likely have to replace the fuser unit.
Nov 12, 2009 | Samsung CLP-610ND + Demo Laser Printer
Low heat error
the fuser is defective and needs to be replaced.
Jun 11, 2009 | Samsung CLP-600N Laser Printer
Error message Engine Fuser Overhaet
May 04, 2009 | Samsung CLP-500 Laser Printer
Ricoh FX16 open heat error
the Open Heat error indicates that the sensing circuitry for the fuser has detected that the fuser is not heating up. This can occur because either the sensing circuitry isn't detecting correctly or the fuser actually isn't heating up. Probably the latter in most cases.
How to fixya? Probably install a new fuser and you'll be fixed. Want to be sure before you spend $$ ?? Pull the fuser out. You will see a wiring hookup with two heavy wires that supply 110V to the heating lapm. Connect an ohm meter across the two wires that are on the FUSER. A good fuser will read around (0) ohms - complete circuit. A fuser with a bad lamp or a bad thermostat will read infinite resistance (open circuit).
The thermostat is probably available as a separate item. It's probably about $15 from several online sources. I believe you will need a JC47-00013A. I could be wrong. You'll need to do some research if you find that to be the problem.
Jan 26, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Error Message-
there is a thermostat circuit that regulates the temperature of the fuser. A sensor reads its tempurator and something is out of wack -either the sensor or the sensor tempurature circuit .
Dec 21, 2008 | Samsung CLP-500 Laser Printer
Samsung SF-5100P
Machine will require fuser(hot bit at rear) replaced before it will operate, take to dealer for quote or if brave and 240v happy then buy a fuser and get your tools out rip off the covers and in the back you will find fuser assy.
link to service item fuser U.S.
http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=JC96%2D01621A&search%5Fmodel=SF5100
Nov 14, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Engine Fuser Low Heat Error
Basically the error message is telling you the printer cannot keep the fuser temperature at the proper temperature (too low). It could be a lot of things but typically it is due to a fuser assembly gone bad.
Feb 20, 2007 | Samsung ML-2551N Laser Printer
Samsung SF 5100 Laser Printer Logo
423 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
