Question about Canon CanoScan LiDE 30 Flatbed Scanner
Scanner won't initialise properly
Hi, when I plug my scanner into the USB port the head moves to the start position, it looks like it's doing some sort of calibration or something and then it slowly scans the whole bed (white flickering light) and it tries to go further than it can such that the motor/belt then starts clicking. I seem to have no control over this from my PC as the driver looks like it is waiting for the scanner to report that it is ready. I updated the driver to 7.0.3.1 to no effect.
  • 2 more comments
  • Simplastic Apr 11, 2008
    Hi, there is no rust on the roller rod - it looks as clean as a whistle. However, I can't seem to work out how to open the scanner anyhow. It appears that it is glued together down the sides of the glass. Still no solution found.
  • Anonymous Apr 28, 2008
    Exaclty the same problem under Vista home premium. No, it is not rust on the drive shaft or roller.
  • Simplastic May 11, 2008
    Hi, thank for the advice. My scanner WAS plugged directly into the
    computer, one of the front USB ports on my PC case. I tried to plug it
    into one of the other ports on the back of the case and it came up as
    installing new hardware, but ... hey presto - it worked! Why? Who
    knows - stupid windows!
  • Anonymous Sep 16, 2008
    Please note, the problem is not with Windows, it's the Canon device's inability to work thru a USB hub.
This happened to me with the LiDE30, and I found that this will happen if the scanner is plugged into a usb hub that sits between the scanner and the computer. Try plugging directly into the computer and see if that helps.
Posted on Apr 28, 2008
    Problem Solver:
  • 12 Answers
There is rust on the roller rod please open it and oil the rod and wipe it with clean cotton.
Thaks.
Posted on Apr 03, 2008
When plugged in via usb, the LIDE 600F scanner makes a high pitched buzzing noise and will not start up.
Hi
The scanner is not able to find the home position to start.
Hence open the scanner and check to make sure the scanner assy. is moving to the end and when it senses the home position it will try to move a little away from it and then return back. But if the sensor is dirty or broken it will make a loud noise like belt slipping.
Try to find the sensor on back of the Tube assy. and try to fix it.
Jul 23, 2011 | Canon CanoScan LiDE 600F Flatbed Scanner
I have properly connected my HP Scanjet 2400 scanner with my system and the appropriate software was successfully installed, the light is blinking and when we try to scan, it tries to start, but it...
sometimes the power management causes the scanner to act up or fail altogether.
Try: Solution: Disable power management on the USB hubBy default, Window XP tries to disable USB port when the HP Scanjet scanner is not in use to save power. The scanner fails to wake up when called. To fix this problem use the steps below:
  1. Click Start , right-click My Computer , then click Properties . The System Properties window will open.
  2. Click the Hardware tab, then Device Manager . The Device Managerwindow will open.
  3. Double-click the Universal Serial Bus controller branch to expand it.
  4. Right-click USB Root Hub , then click Properties . The USB Root Hub Properties window will open.
  5. Click the Power Management tab.
  6. Remove the check from the Allow the computer to turn off this device to save powercheck box.
  7. Click OK , and close USB Root Hub Properties window.
  8. Close any other open windows.
Aug 28, 2010 | HP ScanJet 2400 Flatbed Scanner
5800usb says there is a lock on the bottom of the scanner. to click OK after you have unlocked the scanner. I do not find a lock anywhere on the scanner
There is no lock on the Visioneer 5800 USB scanner. I had the same problem with my 5800 and finally noticed that the scanner lamp was going bad. I replaced it with a good lamp out of an old Acer parallel port scanner that even had the same plug, noticed that an older HP that I have sitting around would have interchanged as well. My 5800 now works great and has been tried on both 98SE and XP with SP2.
Dec 04, 2009 | Visioneer OneTouch 5800 Flatbed Scanner
My scanner could not start after transporting it without locking. SOME BODY LOOKED AT IT AND SAID THE PROBLEM WAS WITH THE MOTOR. HOW CAN I GET THE MOTOR.
Possibly the lock button got moved in handling - look under the front of the scanner for a small button that moves sideways - it will have a lock and unlock position. It may have moved to the lock position - that prevents the head from moving.
Oct 24, 2009 | Canon CanoScan 5000F Flatbed Scanner
Hp PSC2355 scan function inop
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aswq9
Aug 25, 2009 | HP Officejet 5610 All-In-One InkJet...
The scanner(travelscan pro 600) gets a no power or not connected message!
Go to Device Manager and most likely the travelscan pro 600 is not popping up under imaging devices where it should be. Unplug the scanner and plug it into a different USB port. Try this on all the USB Ports on the machine if it reappears in device manager then the software will work. If you are using a USB extention cord or USB hub get rid of them till you try all the ports. If it doesn't i would suggest contacting the manufacture and seeing if the scanner is still under warranty.
Apr 17, 2009 | Ambir Technology TravelScan Pro 600
I can not get my scanner to scan
If the lamp simply will not move then the green latch on the bottom of the scanner is locked and holding the scan head in the locked position.
If it is a scan to network issue or scan to E-mail you need to use a USB or parallell cable and you may have to change the USB port speed, But without knowing which problem you have I am not sure exactly where to head with this problem.
The scanner lock is located on the underside of the scanner. If you look in where you reach to remoce your copies, you will see on the bottom of the scanner a green latch, about 2 inches long and a half an inch wide. Push it in then pull it toward you until you feel it snap locked . Then power the machine off and back on.
Feb 02, 2009 | Xerox WorkCentre M15i Laser Printer
Continually scanning
Make sure the lock switch is in the unlocked position. The lock switch is on the bottom of the scanner. It sounds like something is preventing the scanning bar from getting to the home position. If the scanner was somehow locked with the scanning head being out of the home position, then the result would be what you describe.
Jun 25, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Scanning drops in middle of scanning
Check to see if the computer has adequate RAM's installed to work with the scanner. Don't forget that in the background it is running scanner software, and the operating system at the very least.
It is also possible that there is a buffer over-run timeout error occurring with the USB port processing. There may be an IRQ address conflict. The over-run timeout error from the USB port may not be reported.
Try connecting a USB powered hub between the computer and the scanner. The powered hub will offer some isolation, and being a hub it has some internal memory with data repeating circuits. I have seen this approach fix a lot of problems with digital cameras and scanners.
If it still has the same fault with the hub, then try using the hub with the scanner on different USB ports. There may be an issue with IRQ's and addresses. Moving to a different port will sometimes allow for a different address for reading the scanner.
Past these options that I mentioned, the fault is very involved. If you do not have the in depth knowledge base about how to trouble-shoot this fault, you will have to get some assistance.
Jerry G.
May 02, 2008 | Umax Astra 2000U Flatbed Scanner
Scanner
THE PROPER WAY ON INSTALLING USB DEVICES A. Enable usb ports on the BIOS. 1. Do not plug in your device right away. Install all drivers and software first! 2. Reboot 3. Plug the power or turn on your USB Device 4. Plug in the USB Port. 5. Windows Will detect the Device Automatically. Finish! Hope this helps.
Sep 21, 2007 | Microtek ScanMaker 4900 Flatbed Scanner
Canon CanoScan LiDE 30 Flatbed Scanner Logo
79 people viewed this question
old marine
old marine
Corne Viljoen
