Question about HP 48gx Calculator
Screen Problem with my HP48
Hello! Here i describe my problem: My HP48GX had been stored for a long time, without batteries, so recently i decided to use it again. I bought new alkaline batteries, install it and when turned on my hp48 i realized that the screen had a white line which erased half of the third level of the stack..it's not a color line, it seems a loss of graphic, which is maintained at the same horizontal row if i put differents incoming numbers on the stack.
I hope you can understand, i am not a good english writer...but i need your help.
Francisco from Chile
  • 1 more comment
  • mtsmic005 May 19, 2008
    My Name is Mike from South Africa . I had exactly the same problem with my calculator .
    Regards
    If you find a solution please forward it to mmatshona@yahoo.com or matshomn@eskom.co.za
    Tel : +27 832081217
    Desperate
  • chase30233 Aug 10, 2008
    i put new batteries in my hp after years of no use i does not turn on i am trying to replace the internal battery i have the manual but do not know where to replace the internal battery if you can help i need it
  • andycutshall Sep 25, 2008
    I have the same problem. My HP 48GX has been stored for about a year and now lines in the screen are missing.
  • HP Master
  • 8,016 Answers
Hello Francisco from the land of Pablo Neruda and Salvatore Allende!! Salud.
Try the following procedure (valid for the HP 48G should work for the HP48GX.) If any of the tests fails the calculator requires service
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  4. Release the [ON] key
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.
Hope it helps.
PS Except for a few minor errors in capitalization ( the pronoun I should always be capitalized), the occasional missing pronoun (I), and the adjective which is invariable (no agreement with a plural noun), I would say that your English is fantastic. It is better than the BROKEN ENGLISH written by the vast majority (95%++) of the human race, native speakers included.
I wish my Spanish were as good as your bad English.
Posted on Nov 08, 2009
  • k24674 Nov 08, 2009
    There is an HP customer self repair (CSR) which you can
    contact. On the site it is sais that the service is available for
    products under warranty or on contract. but you have nothing to lose by
    contacting them. Here is the link to the web site
    You can also try this site. They do repairs on most models, except the newer ones.
HOW TO SET THE DATE/TIME
depends oncalulator I HAVE NOT SEEN A CALCULATOR WITH TIME OR DATE
Nov 02, 2016 | Office Equipment & Supplies
My screen has a horizontal line across the screen
Make the calculator perform a self test: Part of the test is the display of some line patterns. You will be able to see if something is wrong with the screen.
TO PERFORM A SELF TEST (No I am not shouting, but I cannot use Bold fonts nor underlined)
  1. Turn calculator ON
  2. Press and HOLD the ON key
  3. Press the "E" key , the key with an E to its right
  4. Release the ON key
  5. Tests will be performed cyclically until you execute a SYSTEM HALT
TO PERFORM A SYSTEM HALT
  1. Press and HOLD the ON key
  2. Press the and release the "C" key key with a "C" to its right.
  3. Release the ON key
  4. You should see the empty stack.
If you need to repair it, google FixThatCalc.
Good luck.
Jan 23, 2010 | HP 48gx Calculator
I just changed the battery in my HP 48GX that I haven't used in some time, but the alert symbol is on and nothing else is happening
The following procedure valid for the HP 48G should work for the HP48GX.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Nov 07, 2009 | HP 48gx Calculator
Hp48s is dead after changing batteries
can someone pl tell me why i cant save a scanned doc from my Vuego Brisa Scanner to a work doc pl
Aug 24, 2009 | HP 48gx Calculator
The calculator is dead. Batteries are OK.model
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the dagnostic tests.
The following procedure valid for the 48G should work for the HP48GX.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Aug 05, 2009 | HP 48gx Calculator
Calc. asks to recover memory, display goes blank, keys beep
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Aug 04, 2009 | HP 48gx Calculator
Hp48gx is autistic
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Jul 16, 2009 | HP 48gx Calculator
I HAVE A HP-48GX THAT WANT TURN ON.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Feb 05, 2009 | HP 48gx Calculator
My HP 48GX with COGO Card is running slow.
You should perform the dagnostic tests.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Nov 12, 2008 | HP 48gx Calculator
ON switch
.The selft tests will show you what is wrong, and if the calculator requires repairs.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Jul 01, 2008 | HP 48gx Calculator
HP 48gx Calculator Logo
795 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
