Question about Sony KV-27V22 TV
Sony kv27v22 TV
Set seems fine but shuts off at random intervals (can be minutes or hours) with a bright blue flash. Can be reset by turning power off and on again whereupon it returns to it's random behavior.
  • Rd_4 Apr 01, 2008
    Thanks, I have the schematic and I'll check it out.
  • 149 Answers
Check horizontal drive tramformer for intermitance is common problem some time blows horiz transistor to or vertical IC intermintence to
Posted on Apr 01, 2008
Sharp 80le632u lcd turn off randomly & suddenly
Checked Power Board is it any solder is not proper. Resolder all main point.
Jun 04, 2017 | Sharp Aquos Televison & Video
Samsung DLP 72" HL72A650C1F keeps turning off amd on
Did you buy the original lamp?
If the problem is related to the lamp door switch, you will get a different error instead of lamp LED.
Do you hear the color wheel spinning?
Again, if it's a color wheel problem the error will be different!
My good guess is the lamp but, it could be the ballast or both.
Best of luck
www.aaatvservice.com
May 08, 2012 | Samsung SELECT HL72A650C1F Rear Projection...
Screen loses brightness at irregular intervals, then eventually returns to normal brightness.
Shut off the whole TV including the cable and the wires. Wait for about an hour and then turn it back on!
Dec 10, 2011 | LG 32LG30 32 in. LCD HDTV
TV Turns Off Automatically While Watching
Stop trying to turn on the set. You are causing more damage. The hissing sound you are hearing is either a High Voltage Transformer on the SMPS (Switched Mode Power Supply) indicating a short somewhere in the set or some capicitors that have shorted out. Also there can be a CRT that is leaking cooling fluid onto the Main bd or the Power/Deflection bd or both bds. Have a trained Samsung tech troubleshoot the set.
Jul 15, 2009 | Samsung HCM4215W 42" Rear Projection...
When powered off, TV turns on and displays white screen, then shuts off
I ended up exchanging the TV for a new one that works fine.
Sep 12, 2008 | Televison & Video
Monitor Randomly Turns Black
I have exactly the same problem with my Benq FP71E+ ..
What i found is a temp fix is this :
When monitor dims and goes black i turn it off , hit the bottom left side (near the BENQ logo) turn it on again and it works ..
This works every time for me . But after a while it switches off again , could be 5 minutes could be 5 hours . Its random
May 02, 2008 | BenQ FP71E 17" LCD Monitor
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Flashes bright white randomly
resolder the tv circuit in the power supply and the flyback area that will solve your problem as the symtoms are intermittent just some loose components due to consistent heat over the years.good luck.
Jul 27, 2007 | Toshiba 34HF84 34" TV
Pt 56tw53 picture trouble
I had the same problem with my TV, It seems the high voltage trasnformer blew which in turn casued the pin cushion?? to blow. It then shuts the tv off to prevent more damage to it. $500 with service charges to get it fixed!
Nov 05, 2005 | Panasonic PT-56TW53 56" Rear Projection...
Televison & Video Logo
135 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
