Question about Barco SLM R12+ Multimedia Projector
No start up
The pojector give error no (-2203) the error name is (START BOOST NOK)
  • Alber Nagib Apr 01, 2008
    My Barco not start up & give me error code (-2203 start Boost NOK)
  • 563 Answers
Hi there
The best advice I can give you is to take this unit to Authorised Repairer.
It sounds like a Ballast problem ( lamp's powersupply )
Posted on Apr 02, 2008
Kyocera 5050 error code 2202
This is an error is indicating a connection error when using the send feature.
Below I have provided some information or for more information download the users guide from the manufatcures website using this link. http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=16088&rid=16313
2101, 2102, 2103, 2201, 2202, 2203, 3101:
The network cable is disconnected or the hub that it is connected to is not operating properly. Check the cable and the hub. Otherwise, the server name or the host name of the SMTP server is
not set correctly. Use COMMAND CENTER and register the SMTP server name and the host name
correctly.
2204: The E-mail size exceeds the acceptable send data capacity. Decrease the size or resolution of the scanned data to be transmitted and resend the E-mail. 5101, 5102, 5103, 5104, 7102, 720f:
Turn the main power switch off and back on. If this error occurs several times, make a note of the displayed error code and contact your service representative.(Refer to the corrective action for the error message " An error has occurred.")
9181: The scanned original exceeds the acceptable number of pages of 999. Send the ecess pages separately.
Hope this is helpful,
Shawn
Mar 11, 2011 | Kyocera Mita KM-5035 Printer
Error code 2203 on bizhub 600?
C-2203 during the copy or printing process may be intermittent and for that you may need a technician since probable causes are related with the driving and functioning of process unit.
Feb 14, 2011 | Konica Minolta bizhub C450P Laser Printer
I have a KM 4050 and when we scan it is giving a "send error 2101" Everything else is fine. We are able to print from our computers etc. so I know our connections are ok. Any suggestions?
The following errors are simalir;
2101, 2102, 2201, 2202, 2203, 3101:
The network cable is disconnected or the hub that it is connected to is not operating properly. Check the cable and the hub. Otherwise, the server name or the host name of the SMTP server is not set correctly. Use COMMAND CENTER and register the SMTP server name and the host name correctly.
The link below takes you to Kyocera's Scan to SMB setup guide on GFBM's website (they are a Kyocera dealer). The guide setup guide is good and gives pictures and examples.
http://gfbm.net/Documents/self_help/SCAN%20TO%20SMB%20PC%20setup%20R3.pdf
I hope this is helpful,
Shawn
Feb 11, 2011 | Kyocera Copystar CS-1820 Black and White...
Installation error --- Error Code 2203 Please help, thanks
It's long but this should get your problem resolved and I would appreciate a Four thumbs up if it helps you ,If u have connected your printer only through the USB then leave out the last step.
Fatal Error 2203 - Windows XP
Windows Vista.
Giving permissions to C:\Program files folder may sometimes be difficult but here is the resolution.
Perform L3 uninstallation.
Delete digital imaging folder from C:\program files\hp folder.
Delete digital imaging folder from registry.
Deleting registry key below:
Registry Path - HKEY_LOCAL_MACHINE\SOFTWARE\Hewlett-Packard\Digital Imaging
On completing the above steps
Note: * Do not Restart the computer.
Click Start and type Run command in start search bar.
Right click command prompt and Run as Administrator
Type the following command
Net user administrator /active:yes
The above command will enable hidden account in Vista Operating system. Once enabled,
Once Restarted, "New user account will show up on logon screen called "Admin" and no password required."
Once logged in to Admin account
Reinstall the software.
After successful software installation, Please use the below command to disable hidden account feature
Net user administrator /active:no
1.uninstall the complete HP software, run windows clean up utility
2.under msconfig, disable MSconfig's sevices(non microsoft)
Aug 19, 2010 | Office Equipment & Supplies
Error Code 2203. This I get when I try to uninstall or install
Hi I am Vortash ...I have never used or seen this version of window I am afraid however I cant think it is that much different in it's basic functions to Ordinary Vista Beta systems . So with that in mind I ask this has it got a user account administration function the same as vista home editoin if so turn it off and try again you may have a firewall or program conflict with this .. Have you tried asking microsoft support .. and finaly when did it start to do this recently or has it always done it what was the latest program you have installed before the problem started is it causing a conflicts hope this helps Regards Vortash ?
May 15, 2009 | Microsoft Windows Vista Business Edition...
Error code 2203 when I try to load M/S Office 2007
To resolve this behavior, grant the System account Full Control permissions to... loadTOCNode(1, 'resolution'); To resolve this behavior, grant the System account Full Control permissions to the folder that contains the administrative installation point.
Apr 30, 2009 | Computers & Internet
Small nok in moter for 1 min when i start up
YES BE VERY CAREFUL LOOK LIKE IS GOIN TO BE THE OIL PUMP THAT IS STARTING TO GET DAMAGE GET IT FIX AS SOON AS POSIBLE DAMAGE TO ENGINE MAY OCCUR HOPE THIS IS HELPFULL
Apr 24, 2009 | 1990 Jaguar XJ6
Error 2203 for ASUS Computer
I found a couple of articles related to your problem. One solution that was mentioned was upgrading the Windows installer (apparently this fixes a permissions issue with the installation folder).
Post your results back here, especially if this doesn't fix your problem and I'll do some further digging.
Mar 15, 2009 | ASUS Essentio Desktop with Intel Pentium...
Fatal error 2203
Editing the registry is risky. Use these instructions at your own risk.
First do a normal uninstall of your HP printer
If you have trouble installing officejet j4580, you may need to edit the registry and remove all HP items. Make sure you first go to control panel and delete all installed hp printers. Then go to Windows Explorer and delete all hp folders. Save a backup copy of your registry. Then find all HP registry keys and delete them.
Then restart your computer. Download the latest printer package from the HP site and save to a folder in your Documents. Then install the package from the download.
bvrock41
Nov 20, 2008 | Office Equipment & Supplies
Barco SLM R12+ Multimedia Projector Logo
171 people viewed this question
Top Barco Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Barco Office Equipment and Supply Expert? Answer questions, earn points and help others
