Question about Canon IXUS 860 IS Digital Camera
Canaon is 860 Blured image. Always right hand side of picture.
Almost every shot I take, regardless of setting is blurred on the right hand side of the screen when displayed on PC. It seem worse with landscape shots. I've tried back to back similar shots with diferent settings with no improvement. Lens is spotless. Thanks.
  • Alan_t Apr 01, 2008
    Thanks, it's as I suspected. I just wanted to be sure.
Listen you need to take the camera back where you got it and tell the person at the store because it is the camera that needs to be fixed i had the same problem except with the bottom right hand corner of my camera.
Posted on Apr 01, 2008
SOURCE:
The pictures are so bright and very blurred
Hi there:
I suggest check EV setting is on the + side and not neutral (0). Either that or Image Adjustment setting is wrong. Check EV by pressing the +/- button (right side near On/Off switch). Hold EV selector and make sure 0.0 is in the display.
Hope this helps.
Aug 23, 2012 | Sony Cyber-Shot DSC-W570 Digital Camera
IM USING CANNON SX 210 IS MODEL MOST OF THE SHOTS WHEN IM ZOOMING ITS GETTING BLURED, ITS NOT LIKE HOW I EXPECTED FROM CANNON.
Make sure you are shooting in a mode with the flash enabled and that should enable the anti-blur features of the camera
Feb 28, 2011 | Canon PowerShot SX210 IS Digital Camera
Sometimes when taking photos the photos are fine and sometimes they are really blurry. Why is this haening?
this may not be the camera but the lighting situation of the photo. or how the camera is held this also happens on film cameras.
if the subject is not well lit or the flash fails to go off or is blocked by a finger then the shutter stays open longer to get enough light to see the image. if the auto focus apature is blocked it will not focus on the subject and will come out out of focus
if the camera moves in the time that the shot is taken it will blur.
if the blufing is from left to right or up and down it means the camer moved during the shot.
if the whole picture is blured all over this looks like being out of focus and not due to movement.
check your IOS speed setting for your camera if it is set low then the camera will needs a lot of light or show shutter speed to capture an image. set it to auto or higher than 100 is best for most situation
if the camera is set to manual an not automatic the camera will only shoot at the set shutter speed and this can cause bluring.
try some test shots on a table or a tripod and take several shots in automatic mode with auto focus on take them one after the other they should all be the same but if one is blurred then there is a problem with the metering of your camera if they are all fine they it is due to camera shake when the picture was taken.
a few tips.
hold the camera to the eye with the elbows against the side of the body.
in dark lit places try to use a tripod or some other support or external light source or flash.
ensure the fingers are away from the auto focus apature the lens and the flash light.
i hope this was helpful
Dec 12, 2010 | Olympus Stylus 770 SW Digital Camera
My camera shows blurred viewfinder...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Jan 02, 2010 | Canon PowerShot A60 Digital Camera
Blurred images & screen on my Olympus camedia C55 zoom
try to take a picture with 1/100 shutter speed and make sure that your hand is not shaking when taking pictures. another is try to take picture with your current setting and set your camera on a tripod or place it on a table, set the timer and take picture. if the picture is not blurred then always set your camera to auto, if this doesn't resolved the issue maybe your lens has a problem.
Aug 20, 2009 | Cameras
My Fuji s2000 always shoots picture that are blured. I have tried many settings and different exposures however I keep getting the same result. What can I do ? The worst mode on this camera is the auto...
Found the same thing and I think the answer is the opposite of previous suggestions. The s2000 is truly awful at anything above about 400ASA The degree of pixel binning it uses just makes the pictures look terrible. Force the camera to use 400 or slower (lower numbers), force flash and I think you'll see a great difference. I was on the verge of sending mine back before I discovered this.
Ian
Aug 10, 2009 | Fuji FinePix S2000hd Digital Camera
Actions shots are blured
The various solutions include:
try to set focus range (settings), to infinity or to an approximate distance to the object you need to take a photo of as sometimes the automatic setting does not always do a godd job at focusing , or look at the lens when it is on if its got grease use a wet camera lens cleaning kit (someone touched the glass of the lens ) a s grease makesa it hard for the camera to focus , hence blurrig or go into your options and lower the iso mode or take it off night node if any as the iso mode leads to high exposure time which means any light that changes would record as a smear hence blurring or use flash.
Nov 14, 2008 | Cameras
Blurring on one side - Viewing and photo
A friend managed to find a very easy solution to this problem...the lens was dirty due to a 6 year olds sticky fingers...so I just needed to clean it.
Nov 06, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
Canon Power shot 570 IS problem
Check to see if your camera is in Macro mode. This may cause blur. Also hit your function/set button to see if it is in digital macro mode.
Make sure your lens is clean.
Make sure you are set to automatic mode and zoomed all the way out. There are several things that may cause blur, the most of which is camera shake. Make sure your Image Stabilization is turned on. If it is, you will see a little hand in the bottom right corner of the LCD screen.
If it's not on, turn it on in the setup (tools) menu.
If your shutter speed is slow, this will cause image blur, but in auto mode, you won't have to worry about the shutter speed, it will be set automatically.
Hope this helps.
Apr 22, 2008 | Canon PowerShot A540 Digital Camera
When i dont use the flash on a nikon it is blured
When taking a picture the camera needs a certain amount of light to hit the sensor before it can record a good image. If you are outdoors in the sun and the camera still takes blurred pictures due to a long exposure time then there is a malfunction. In bright lighting situations the camera should decide on its own not to use the flash. For indoor situations the camera has to either supplament the available light with the flash, or increase the duration of exposure to collect more of the existing light. There is no way around it - the sensor needs a certain amount of light to create a quality image. On some cameras you can override the shutter speed setting and force a fast exposure but without proper lighting you will just end up with dark images. You might also be able to override the F setting to the lowest possible value which would let in the most light. However, these cameras are generally very good at deciding how much light they need to take a quality image. If the flash is set to auto and the camera decides to use it then there is simply not enough light to get an exposure with a fast shutter time. This is one of the factors that gets better the more expensive the equipment is. Higher end point and shoot units and SLR units can collect more of the available light with their larger lenses and thus get good exposures in lower light conditions while still maintaining fast shutter speeds. Additionally "image stabilized" cameras help compensate for this situation by electronically assisting the photographer in stabilizing the image - allowing longer exposure times to be shot hand-held. You could also try a tripod if that is appropriate to your needs, that would help you shoot longer exposures in low light without so much image-wide blurring. Of course anything in motion will still blur. David Millier Advance Camera Repair
Feb 18, 2007 | Nikon COOLPIX S6 Digital Camera
Canon IXUS 860 IS Digital Camera Logo
87 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
