Question about Cameras
Bad Memory Card
I`ve got a 1GB memory card that will not work it will not formatt
  • Vick1 Apr 01, 2008
    I`ve got a Kodak Z612 digital camera that does great during the day but it won`t take good action shots at night what can I do to fix this problem
  • 871 Answers
About the memory card, you can try to have that reformatted on another camera. if it will not reformat, its time to replace that.
about the camera. its about lighting and exposure. shutterspeed also has a factor to that. try adjusting the shutterspeed and provide a bigger flash. or stronger lighting.
Posted on Apr 01, 2008
I`ve a sandisk micro sd memory card 1gb.accidently it got password protected, i don`t have the password, Pl help me.My mobile phone is nokia 6233
you've got to format the card... attach the card to card holder and then card reader to the PC... format it to FAT... this should remove any password protection...
Apr 03, 2010 | SanDisk 1GB microSD Memory Card
Tip
Sony Memory Stick Formatter Software If your Sony Memory Stick has stopped...
If your Sony Memory Stick has stopped working in your digital device,
Sony's Memory Stick Formatter Software may be able to format your Memory Stick in a more compatible way for your device.
Compatible operating systems include:
* Windows® 7 Starter / Home Basic / Home Premium / Professional / Enterprise / Ultimate
* Windows Vista® Home Basic / Home Premium / Business / Ultimate
* Windows® XP Home Edition / Professional
* Windows® 2000 Professional
Preparation
* Confirm that the write-protection switch of the Memory Stick is set to the "Write enable" position.
* Insert the Memory Stick into the Memory Stick slot of the device or computer.
* If you are using a file recorded on Memory Stick with another application, quit the application before beginning the formatting process.
The Format Process
Note: Formatting will erase all files in the Memory Stick. Always double-check the Memory Stick contents before formatting to prevent loss of important data.
* To start Memory Stick Formatter, click Start->Programs->Memory Stick Utility->Memory Stick Formatter.
* At the "Drive List" screen, click to highlight the drive letter that represents the Memory Stick device/slot.
* Click the Start Format button.
* At the "Warning..." screen, confirm that you wish to format the Memory Stick, and click OK. Note: To quit the process, click the Cancel button.
* Do not remove the Memory Stick from the Memory Stick slot during formatting, as this may cause corruption.
* At the "Format was successful" message, click OK.
* To quit the Memory Stick formatter utility, click the Exit button.
Download the Sony Memory Stick Formatter Here.
I hope that helps.
____________________________________
Click here for Sony's Memory Card File Rescue software.
on Apr 18, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Tip
Sony Memory Card File Rescue Service If your Sony Memory Stick has stopped...
use Sony's Memory Card File Rescue software to recover your data.
Download Sony Memory Card File Rescue Here.
I hope that helps.
Download Sony Memory Stick Formatter here.
Formate memory stick
try formating the card using a digital device such as a camera or a playstation portable (PSP)
May 17, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Olympus c-740 reads card error when 1gb xd memory
its non supportive to 1gb card as you will have to get the device upgraded to make it support 1gb.
Mar 03, 2009 | Cameras
Formatting errors on 2 memory cards - old 1gb & new 4gb micro sd sandisk
http://www.sdcard.org/consumers/formatter/eula/
Go here follow the instructions to get a formatter program
May 16, 2008 | SanDisk 2GB microSD Memory Card
Memorex MMP3642A - SigmaTel format
A few suggestions:
1] I’ve tried using a 1GB sd card in the MMP3642A with no success. Interestingly, I can transfer files to the 1GB card when it is in the MMP3642A, but when I turn on the player to listen to the files, I get the sigmatel formatter error message. I tried running the sigmatel formatter, but it doesn’t understand the 1GB size. Apparently whoever programmed this braindead formatter program only programmed it for up to 512MB sd cards. Interestingly, I tried flashing this player with the MMP8500 firmware, and then the player does play files off of the 1GB sd card, but the LCD is mostly cutoff and only 25% of the LCD shows up. So it seems the only obstacle to using a 1GB sd card is this stupid formatter program. I tried formatting the sdcard to fat16 instead of Fat32, but that did not help
2] If you want to use a card with more than 64MB, you need to use the CD that was with the player. DO NOT USE AUTORUN! Explore the disc, go into the "products" folder, run the stusbmscformat.exe application. It will show a the drive letter for the player, click the arrow and select the next drive letter down, then press start. This worked for me, I hope it will be useful. Why memorex doesn’t address this issue is beyond me.
3] How do I correct the error: Reformat external media with sigmatel formatter? If you have installed the software disc that you received with your MP3 player, you will need to follow these instructions; -- From your computer, click 'START' -- then 'PROGRAMS' -- then 'MEMOREX' -- then 'FORMAT' -- choose the 2nd drive If this doesn't correct your error, you will need to return the memory card to the retailer for an exchange. connect your memorex mp3 player , then turn it on and click start .....i did the same and its working now.
Jan 08, 2008 | iLO MP3 Player
Memory card for motorola krzr k1
try formatting & inserting it again.......
it may solve ur prob
Dec 29, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Sd memory for motorola L7
cause it doesnt come with sd lol it comes with 10mb built in u have to buy sd if ya want more memory
:p
Nov 21, 2007 | Motorola Mobility SLVR L7 Cellular Phone
MMc Mobile Memory card
try by restoring ur handset and formating ur memory card once...
Oct 30, 2007 | Nokia 6630 Cellular Phone
Cameras Logo
127 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
