Question about Microwave Ovens
Removing burned out bulb on GE Profile Mode JVM1480WA 001 with switch on and there was a "pop" and other light went out. Replaced both bulbs and circuit appears dead. All other functions and interior light are working.
  • 4 more comments
  • jkolson Apr 01, 2008
    Is this just a fuse problem or is it most likely a wiring problem?
    My error ... should be JVM1460
    Internal light is fine. It si the surface lights that are out.
    I have opened the bottom panel and the sockets and wiring from the two lights to the master board behind the the touch pad appear to be intact. Before I pulled the plug I turned the surface light touch pad on bright and then to night light and then off. each change appeared correctly on the digital display so that it appears that the touch pad for the surface light is okay. There is no outward indication of damage to th master board.
    I may not be clear or there is a connection between the door interlock switches and the "surface lights" that I do not understand. The microwave interior light continued to function correctly and would go on and off when opening and closing the door. The two "surface lights" that illuminate the stovetop below the microwave have operated as if they were independent of the door opening and closing and were turned on and off with the "surface light" pad on the microwave. All other functions,interior light and microwave on and off appear to be reacting to opening and closing the door in a normal manner.
    Not very helpful.
    All of the functions of the microwave are working!! I can cook with it.
    It is a space saver model mounted over a cooktop with vent fan and lights which shine down on the cooktop when turned on. The controls for the vent fan and light that shine down on the cooktop are on the microwave cotrol panel. The only thing not working are those two lights. As previously noted there does not appear to be any damage to the wiring and specifically the yellow wire that runs from the light sockets to the control board. Pleas look at my last two comments. Thak you
    Genius:
  • 3,422 Answers
HI,
Did you check the interlock switches?Please read the below steps:
Testing and replacing of interlock switches: With the oven unplugged, put an ohmmeter across the AC input just before the
interlocks (but beyond the power relay or triac if it precedes these). Open
and close the door slowly several times - there should be no significant
change in resistance and it should be more than a few ohms. If it approaches
zero while opening or closing the door, the interlock switches and door
alignment should be checked. (You may need to disconnect one side of the
transformer primary since its resistance is a fraction of an ohm. Refer to
the schematic pasted inside the cover.)
Replace with switches having a precisely identical fit and equal or better
electrical specifications (terminal configuration, current rating). When
removing the old switch make a note as to where each wire goes. Check
the embossed marking on the old switch - don't depend on location as your
replacement might just have a different arrangement. Make sure the new
switch aligns correctly with the actuating mechanism and then check for
correct electrical operation with an ohmmeter before applying power.
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 01, 2008
  • 871 Answers
With regards to what Master_Tech has said,
if this was a fuse problem, it was supposed to be dead.
but you yourself mentioned that everything else works fine. so in essense, this would fall to the category of wiring problem.
look for wiring connections that has burnt feature on it and at the same time, try to check if the fuses are in good condition. if your already thinking twice, replace the old fuses with new ones.
thanks for using fixya.
  • earl norman llanera
    earl norman llanera Apr 01, 2008
    they are reacting because they are not independent as of the moment you close and open the door for that. it must be grounded.
    Master:
  • 788 Answers
If you are comfortable with opening the oven you could look at the board for any burnt or broken/loose components. Then either replace that component of the entire board if you can find it.
IMHO it's probably cheaper and easier to replace the over, I just bought a GE 1100W 1.1cuft oven for $80 from Walmart and have a one year warranty.
Good Luck!
  • Dean Joly
    Dean Joly Apr 01, 2008
    Those lights then are probably independant of the microwave circuit. There may be a fuse for them and probably a seperate board.
    Use a multimeter to check for voltage throughout the circuit, especially from the board to the power supply, and from the board to the sockets. Be careful not to shock yourself.
  • Dean Joly
    The only way of knowing is to troubleshoot and in this case I would check for power at every possible location until I found the source of the problem. If the light controls are on the board and the LCD is detecting your button presses then I would think that voltage is not reaching the bulbs. Check for voltage between a ground point and the yellow wire. The voltage should also rise as you raise the intensity of the lights. If no voltage than the board that the yellow wire connects to is most likely the problem or the ground between the light sockets and the chassis is open.
  • 770 Answers
Cant find a JVM1480 model can you check that?
  • 4 more comments
  • Gary Davd
    Gary Davd Apr 01, 2008
    There is a 1460 then it jumps to a 1490 model but cant see a 1480
  • Gary Davd
    Either way the units lights are controlled by a door interlock switch (small mico-switch) you will need to check that first for proper operation
  • Gary Davd
    Not a fuse problem unless the unit is completely dead
  • Gary Davd
    you are correct now i know it is the surface lights that helps they are controlled by the main control board there is a black relay box on the board they go out you can be careful and open the ctrl panel tilt it out and tap on the relay see if it unsticks and turns on if not it needs to be replaced
  • Gary Davd
    to test the you can swap the fan and light wires on the relay board and turn on the fan if the lights work the relay is bad
  • Gary Davd
    Have you swapped the wires to see if the power goes to the unit?? you can jumper them as well it would be like the relay is closed and feeding power down to the lamps
    Guru:
  • 1,894 Answers
I think you need to check your control circuit
  • dewan nafees ahmed Apr 01, 2008
    it means bad connections
    Totally dead oven
    First, check power to the outlet using a lamp or radio you know works. The
    fuse or circuit breaker at your service panel may have blown/tripped due to
    an overload or fault in the microwave oven or some other appliance. You may
    just have too many appliances plugged into this circuit - microwave ovens are
    high current appliances and should be on a dedicated circuit if possible. If
    you attempt to run a heating appliance like a toaster or fryer at the same
    time, you *will* blow the fuse or trip the circuit breaker. A refrigerator
    should never be plugged into the same circuit for this reason as well - you
    really don't want it to be without power because of your popcorn!
    If you find the fuse blown or circuit breaker tripped, unplug everything from
    the circuit to which the microwave is connected (keep in mind that other
    outlets may be fed from the same circuit). Replace the fuse or reset the
    circuit breaker. If the same thing happens again, you have a problem with
    the outlet or other wiring on the same branch circuit. If plugging in the
    microwave causes the fuse to blow or circuit breaker to trip immediately,
    there is a short circuit in the power cord or elsewhere.
    The microwave oven may be powered from a GFCI outlet or downstream of one and
    the GFCI may have tripped. (Removing a broken oven lamp has been known to
    happen.) The GFCI outlet may not be in an obvious location but first check
    the countertop outlets. The tripped GFCI could be in the garage or almost
    anywhere else! Pushing the RESET button may be all that's needed.
    Next, try to set the clock. With some ovens the screen will be totally blank
    following a power outage - there may be nothing wrong with it. Furthermore,
    some ovens will not allow you perform any cooking related actions until the
    clock is set to a valid time.
    Assuming these are not your problems, a fuse has probably blown although
    a dead controller is a possibility.
    If the main fuse is upstream of the controller, then any short circuit
    in the microwave generator will also disable the controller and display.
    If this is the case, then putting in a new fuse will enable the
    touchpad/display to function but may blow again as soon as a cook cycle
    is initiated if there is an actual fault in the microwave circuits.
    Therefore, try a new fuse. If this blows immediately, there may be a
    short very near the line cord, in the controller, or a defective triac
    (if your oven uses a triac). Or, even a shorted oven lamp - remove and
    inspect the light bulb and socket.
    If it does not blow, initiate a cook cycle (with a cup of water inside). If
    the oven now works, the fuse may simply have been tired of living. This is
    common.
    If the fuse still blows immediately, confirm that the controller is
    operational by unplugging the microwave generator, power relay, and/or
    triac from the controller. If a new fuse does not now blow when a cook
    cycle is initiated - and it appears to operate normally - then one of
    the components in the microwave generator is defective (shorted)
    Some models have a thermal fuse as well and this may have failed for no
    reason or a cooling fan may not be working and the oven overheated (in
    which case it probably would have died while you were cooking something
    for an important guest - assuming you would use a microwave oven for such
    a thing!).
    Other possible causes: bad controller power supply or bad controller chip.
  • 813 Answers
Hi frined
u have to go with a good techision he will chaged if do ur self it make to problem to damge it so go with good technision
Where to get light for ge profile microwave
It should be listed here:
https://www.geapplianceparts.com/store/parts/category/lightbulbs
With more information about the microwave, a Google search could find the exact bulb, and its price/availability.
Jan 15, 2018 | GE Microwave Ovens
Bulb on ge microwave keeps burning out
Hi anything is possible being that you even replaced two different brands of bulbs. I don't think the wiring harness is the problem but like I said anything could be the problem. Might I make a suggestion. Why not replace both the left and right side bulbs with LED bulbs with the same base configuration. Maybe that just might be able to solve your problem. I would like to know if it does. It also seems that a lot of others are having the exact problem. Good luck.
Marty
Apr 14, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
My GE Advantium Microwave first had the cook top light go out. I replaced the bulb and it worked for about a week. The control panel went haywire, and then the interior light went out. I have replaced...
In this case, you have to check the control panel. There might be wire connections and contacts that loosens. The bulbs inside the oven is connected to a switch that that only functions once the oven is in closed position.
Nov 05, 2010 | GE Advantium SCA1001SS Convection /...
Replacing surface light
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
Replace the burned-out
bulb with a 40-watt
incandescent bulb
(WB36X10003), available
from your GE supplier.
1 To replace the bulb(s),
first disconnect the power
at the main fuse or circuit
breaker panel or pull the
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
removing. After breaking
the adhesive seal, remove
the bulb by gently turning.
4 Replace the screw.
Connect electrical power
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
1 To replace the oven light,
plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
3 Next, remove the screw
located above the door
near the center of the
oven that secures the
light housing.
to the oven.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Have an installed GE Microwave jvm1870 with a burned out oven bulb. Have replacement bulb but can not see how to get to the old bulb to replace it.
From the owner's manual:
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and EMO4000, replace the burned-out bulb with a 120 volt, 40-watt incandescent bulb (WB36X10003), available from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from your GE supplier.
To replace the bulb(s), first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the screw at the left edge of the light cover and push on the right edge of the cover to open.
Be sure the bulb(s) to be replaced are cool before removing.
After breaking the adhesive seal, remove the bulb by either gently turning (for models JVM1850, JNM1851, DVM1850 and EMO4000) or pulling straight out (for models JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the top grille by taking out the screws on top of the grille that hold it in place and sliding the grille to the left (opening the door makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located in the center of the top opening.
Remove the screw that secures the light cover and lift the cover off.
On some models, the light cover is located at the left of the top opening.
Lift the cover off.
Pinch the clips that hold the light socket in place and lift the socket out.
Remove the bulb from the light socket by pulling straight out.
Replace with the same size and type bulb, then replace the light socket and cover.
Replace the grille and screws.
Jun 26, 2009 | GE Microwave Ovens
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE MIcrowave model JVM1631BJ01 hood lights won't work
The part that controls that is goes through your control panel on your microwave. For the lights to come on to start with the door being closed switches have to be working right and when you press start the lights come one. When the microwave is through cooking and you open then close the door then the lights should go out. The logic IC on the control panel board that detects all these events is not being reset correctly. Unless you get a microwave tech to track down the component on the control panel circuit board it is not something that you could do on your own since it takes voltage and signal checks with the proper equipment and then some soldering and desoldering of the defective component(s). Good luck and God bless.
Dec 22, 2008 | GE JVM1631 Microwave Oven
Burning smell and light switch does not work
The controller needs to be repaired. We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board. For safety, disassembly and other info see http://tinyurl.com/yzjozk
Jan 14, 2007 | Whirlpool MH7135XE Microwave Oven
Microwave Ovens Logo
56 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
