Question about Sharper Image Hybrid GP (SI724) Air Purifier
Hybrid GP Just wanted to about the refurbished replacement. SI tells me this is only if you puchased the extended warrenty, True?
  • Anonymous Jun 20, 2008
    Yes, it is true. If you have the reciept or the original owenr logged into their system they maybe you will have a good chance to get a refrb unit. Otherwise you are sol.
  • 3 Answers
The company is bankrupt so you can no longer get replacemet
Posted on Mar 23, 2009
TRYING TO FIND REPLACEMENT PARTS FOR A SHARPER IMAGE HYBRID GP GERMICIDAL AIR PURIFIER MODEL SI724 NEED THE WIRES AND BEADS TO REPLACE SOME BROKEN ONES
I have 2 of these air purifiers and I love them. I came to this site looking for a resolution because 1 of them stopped working properly. After running for about 30 seconds, the red light would come on. I had cut out 1 wire that was broken and thought that was the problem. There were sparks when it was turned on. After reading a couple answers here, I took a closer look and noticed that a second wire was also broken at the bottom. I just cut the second broken wire off the top and removed it and the purifier works great now. No more sparks!
Aug 16, 2012 | Sharper Image Hybrid GP (SI724) Air...
I bought the hybrid S1724 but the filter was missing. Where can I get a filter?
Ebay??Amazon??They can be upwards of $70-$100,but keep a lookout and you'll find a Deal..Good Luck!
May 06, 2012 | Sharper Image Hybrid GP (SI724) Air...
I have a Sharper Image GP Hybrid model 1724. I cleaned the pull out blades and the inside of the unit. When I turn it on, the needs attention light comes on almost immediately. How can I get the machine...
i found a solution to the sparking problem in the ionic breeze. purchased scotch brite cleaning pads from home depot. using a long strip of pad scrub the plates back and forth especially in the areas that seem to be emitting sparks. i did this and the unit runs quiet as a whisper.
Jul 05, 2010 | Sharper Image Hybrid GP (SI724) Air...
Hybrid GP won't turn on. Tried different outlets. There is a green light thats hidden in the bottom of the unit that does stay on. I push the power button and the unit does not turn on.
The front and rear plastic grills of the Hybrid GP trigger a power cut-off safety mechanism if either of the grills is not entirely in place. The grills have a tendency to slide down ever so slightly if bumped. The tiniest amount of slippage is enough to engage the power cut-off and it's not generally noticeable unless you know what to look for. If the Hybrid GP has no power at all, you may need to slide one or both of the grills upward just a hair. You should hear and feel a slight click when the grills are properly locked into place.
Feb 28, 2010 | Sharper Image Hybrid GP (SI724) Air...
Ionic Breeze GP S1830 just seems bead, no lights
these things are junk. you could also be doing more harm than good to yourself and the indoor air quality in your home with the amount of ozone these appliances omit into the air. throw it away
Sep 11, 2009 | Sharper Image Hybrid GP (SI724) Air...
Sharper Image Hybrid GP. Unit powers on, goes to
The solution drgoff provided ( the guy that used to work for Sharper Image ) actually did the trick !!!! Super excited to have this unit working again , thanks drgoff
Jul 07, 2009 | Sharper Image Hybrid GP (SI724) Air...
I purchased a Hybrid GP germicidal Air Purifier, Model # S1724 ((Electric Air Cleaner AC110v 20w 50/60Hz)). My unit is severly malfunctioning and i nee to either send it in for repair or be given detailed...
Locate the photo electric eye that picks up the need to clean and give it a thorought cleaning. Good Luck and I hope you get it repaired. That photo cell should be your problem It's probably a little black or ruby red dot in a fin or on the housing where yhe air passes.
Jul 06, 2009 | Sharper Image Hybrid GP (SI724) Air...
Ionic Breeze Hybrid GP air purifier only 1/2 grid gets dirty.
I have been doing research on this unit. I read that only every other grill is suppose to collect. The remaining grills increase the electrostatic charge making the collection plates, the ones that get dirty more effective. So the bottom line is there is nothing wrong with your unit.
Apr 24, 2009 | Sharper Image Hybrid GP (SI724) Air...
Sharper Image Hybrid GP Germicidal Air Purifier SI724 NO POWER
Oh there are a lot of known issues! I used to work for sharper image and I believed in this items very much so until mine broke. However after a year I figured out how to fix it. Take the big square collection grid out and the back screen off. Now get you a thick rag and be very careful because there are several tiny wires going up and down. Smaller than dental floss, you need to be very careful because you can either brake them or slice your finger wide open( Under any circumstances I can not be held liable for the information I am giving you try this at your own risk). Now with the towel very gently go up and down each wire like you are polishing a brass pole(once again these wires are thin and can break or cut you). Do this from the back side of the unit and from the inside where the collection grid that you took out sits. Take your time and be thorough, and presto your 400 dollar air cleaner is working again.
Nov 21, 2008 | Sharper Image Professional Plus Ionic...
Unit seems stuck in the "drying grid" mode
I had the same problem with my GP. It has worked great for four years and only recently seemed to get stuck in this drying cycle. I cleaned the grid many times, cleaned the wires, cleaned the whole unit as much as I could to no avail. The trick: You need to clean the two metal prongs and surrounding area that insert into the bottom of the grid, when you inserrt the grid. they are sharp like nails, so take care. Use an alcohol based cleaners and clean the prong and around each base. This fixed the problem for me and she's back up and running well.
Aug 31, 2007 | Sharper Image Hybrid GP (SI724) Air...
Sharper Image Hybrid GP  (SI724) Air Purifier Logo
134 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
