Question about Garmin eTrex Legend GPS Receiver
ETrex Legend, GPS Coordinates from Google Earth Don't Match Basemap
I obtained GPS coordinates from Google Maps and entered the coordinates (correctly) into the unit as a waypoint. The location of the waypoint is significantly off compared to the basemap of the Etrex legend.
Even moving the arrow on the legend to known intesections of major roads and comparing the readout to google map coordinates of the same place shows significant difference.
Any ideas?
Thank you
  • Garmin Master
  • 638 Answers
Are you sure you're using the exact same format on GoogleEarth and your GPS?
GoogleEarth: save the waypoints in a KML file (NOT KMZ) to your computer, naming it appropriately.
Go to http://www.gpsvisualizer.com/gpsbabel/ and convert the KML file to a GPX file, using their converter. They will present you with a file to download. Download it and send those waypoints to your unit and you'll be set to go.
Posted on Apr 01, 2008
I have a Garmin etrex handheld unit. The gps data from it does not correlate with google maps gps coordinates at all. There is a 30 mile, not feet but mile difference in the waypoints. Any idea what I may...
You need to make sure your GPS unit and Google maps are using the same map datum.
In your user manual:
http://static.garmincdn.com/pumac/eTrexLegend_OwnersManual.pdf
Page 44, Setup Options, Units, Position Format: I suggest setting to:
hddd.ddddd as this is the digital format and easier to read
In Google Maps, right click - Drop Latitude/Longitude marker and this should show the co-ordinates in digital degrees. Alternatively, you can hit the SEND button in GoogleMaps, and it will send the marked location to the GPS via the Garmin website. You may have to install the Garmin plug-in into your browser first, but it's well worth it.
If this solves your problem, please come back and rate our solution, thank you.
Dec 19, 2010 | Garmin eTrex Legend GPS Receiver
How do you enter coordinant into GPS to find a
the 1212 will not do what you want it to do...its just not capable of taking longitude and latitude.you can get copy of your manual for your 1212 here
.probably the easiest way around this problem, is to get the address somehow (was there a phone number provided with the rv location list)
if you know the approximate location, you can use google maps to zoom in and get a street address
google maps here
you could also use google earth if you have it..if not, you can get it here very cool even if youll only use it once.
you can enter longitude and latitude in google earth
let me know if you need more help
good luck
May 05, 2010 | GPS
Consistent error entering garmin etrex coordinate in google earth
Consistent errors are usually projection or datum related. If you are taking coordinates collected in one projection and displaying them in your GPS in another, you the points will offset. I'm not talking about the decimal degrees 00.000n 000.0000w vs 00 00 00N 00 00 00W. I'm talking about the geographic model to represent the surface of the earth. Google Earth generally uses a geographic projection with WGS 1984 or WGS84 Datum. Make sure you are using the same settings on your GPS.
Apr 09, 2010 | Garmin eTrex Legend GPS Receiver
Cant find how to manually input cordinates
First create a waypoint, and then modify it. Hold down the enter button for two seconds (the thumb-toggle on the face of the unit). This opens a screen with a number at the top and coordinates of your current location below. Once you've grabbed the coordinates you can change the name and the coordinates and the name and save it as a waypoint. Use the thumb-toggle to bring up number pads and letter pads for each line.
May 07, 2009 | Garmin eTrex Venture HC GPS Receiver
Entering coordinates into a etrex yellow
Mark a waypoint, then edit the waypoint, entering the new co-ordinates.
Oct 04, 2008 | Garmin eTrex GPS Receiver
How do I enter gps coordinates into my Etrex H
Mark a waypoint, and then edit the waypoint's co-ordinates. You can also create a waypoint in Mapsource and then transfer the waypoint(s).
Jun 29, 2008 | Garmin eTrex GPS Receiver
Loading gps marks e Trex hand held yellow
Your manual tells you how to enter waypoints
http://www.fixya.com/support/p237226-garmin_etrex_gps_receiver/manual-14514/page-16
Mar 29, 2008 | Garmin eTrex GPS Receiver
Converting GPS coordinated to google earth coordinates
Feb 10, 2008 | Garmin eTrex Legend GPS Receiver
Plotting Waypoints
Here's the link to the user manual if you need it; http://www8.garmin.com/manuals/GPS60_OwnersManual.pdf Garmin says; To manually enter in the coordinates for a waypoint on the 60 or 76 -series units, use the following steps: Press and hold the 'Mark' button. Use the up arrow to scroll up to the "Location" field and press 'Enter'. A new box pops up to enter in the new coordinates. Go to "OK" and press 'Enter'. Select "OK" at the bottom right corner to save all changes. Hope this helps :)
Jul 17, 2007 | Garmin 60 GPS Receiver
Garmin eTrex Legend GPS Receiver Logo
1,008 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
