Question about Toshiba TDP-TW90U Multimedia Projector
Projector Lamp We purchased this projector brand new approx 3 years ago. Each year for the last two years we have had to replace the lamp. Each time we had to replace the lamp it was not anywhere near the life time that the lamp should have been replaced. This is used in a church, and is used approx 6-8 hours per week, is there any reason that the lamp should have to be replaced each and every year? Thanks
  • Anonymous Mar 25, 2014
    how can i troubleshoot the projector lamp or the ballast?
  • 563 Answers
Hi there
Does your Projector go in for regular services ?
Have a technician check out the fans of this unit as well.
I would suggest you hook up a UPS to this Projector , because eventhough you might not have power dips or failures - the power supplied to appliances is not spike free and Projectors struggle to handle this well.
Posted on Apr 02, 2008
SOURCE:
Origional Epson 3010 bulb burned out after 2 years. New bulb died in a month
our company supply the Original lamp ,unit price is USD200
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Dec 08, 2013 | LC EPSON ELPLP68 / V13H010L68 Projector...
Dull image on projector
This is an old projector which was released in May 2005. Projector image degrades over time as the lamp dims, and other internal factors affect brightness. The original rating is 1600 lumens which is not bright compared to a modern projector.
You can check to status which may give you lamp information by pressing ENTER on remote or projector and going to HELP.
You may find that replacing the lamp helps, however older lamps are expensive and could replace the whole projector with new one of higher specification, complete with 3 year warranty if you spend double as much. A new lamp will not restore a projector to its new state either. Here's a link to the lamp (for the UK), it's over £200 + VAT + delivery, and that's not even for a genuien HP lamp
http://www.every-projector-lamp.co.uk/projector-lamps.php?&brand=HEWLETT+PACKARD&model=VP6310
As I say, you can get projectors with a better spec for as little as £372 + vat + delivery. This one is similar to yours, in that it is a 4x3 business projector. It has an XGA resolution. (Yours is VGA). It is 2000 lumen brightness and it has a 3 year warranty.
http://www.ivojo.co.uk/projector-spec.php?pid=Samsung_SP-L201
Hope this helps...
Feb 21, 2011 | HP VP6310 Multimedia Projector
We have had this projector for 2 years. The projector will not turn on. It will turn green for 3 seconds then turn red and the lamp light turns red. I feel like the lamp could not already be worn? I was...
Whether or not you need to replace the lamp depends on how many hours of use it's had. You should be able to find the lamp time somewhere in the menu on the projector. Lamps for this projector are rated for 2000 hours (bright mode) or 3000 hours (Eco mode). In my experience they usually need changing at approx. 1500 to 1600 hours (bright mode). On Page 54 of the owners manual ( http://www.projectorcentral.com/pdf/projector_manual_4177.pdf ) are instructions for changing the lamp and zeroing the timer once it's changed. The lamp is Type number : DT00911. You should be able to get one from the manufacturer, the dealer you purchased the projector from, or specialty bulb and lamp stores. Be prepared. They aren't cheap, but it's better than having to buy a new projector.
Jan 14, 2011 | Hitachi CP-X450 LCD Projector
Newer lamp not workering
I don't think that resetting the lamp is the problem if you have had it in there for a few months already. This lamp is rated for 2000 hours. That is abaout 1 year if you use it about 5 or 6 hours a day. If you don't use it that much you should get close to 2 years. There are a variety of factors that will reduce the life of your lamp. Do you let the fan continue to run after the projector is turned off? If not, you will see about half of the regular life. Are the filters clean? You can use a vacuum or rinse out foam filters to clean out the dirt and dust. The lamp needs good air circulation to cool evenly. Are the vents blocked or close to another componant? I'm pretty sure that you just need another lamp. If the lamp was purchased more then 4 months ago, you are probably out of warranty. You can save yourself some money if you buy the bare bulb and replace it in the old cartridge. It looks like the complete lamp module from Sharp runs around 295.00 but the usually have a bare bulb available. We supply a variety of brands fior each projector. You can contact me at 866-470-9877 or go to allprojectorlamps.com. Good luck!
Jun 26, 2010 | Sharp XR-11XC DLP Projector
(XL-2400) Projector Lamp for KDF-E42A10, KDF-E50A10: I have a KDF-E50A10. 4 years old. Lamp went out af...
This is by far the best xl2400 site ive come across so far. Has all the details as well as replacement guide and a direct link to amazon.com for purchasing...definitely check it out if you have any questions or concerns.
May 18, 2010 | Sony (XL-2400) Projector Lamp for...
Flashes change lamp after a couple of hours run
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Oct 02, 2009 | Sharp ANXR1LP Projector Lamp for XR1X,XR1
NEC VT676 lamp error
indicating ballast unit problem
Sep 11, 2008 | NEC VT676 Multimedia Projector
Dark Picture
If the Lamp condition is okay then check the FE lens just next to the lamp in the projector after removing the lamp out of prj. replace if that is burnt.otherwise replace Lamp.
Viren
Nov 13, 2006 | NEC VT460 Multimedia Projector
Toshiba TDP-TW90U Multimedia Projector Logo
113 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
