Question about Refrigerators
Samsung american style fridge/freezer needs repairing
Samsung american style fridge/freezer without water dispenser,after making a lot noise from the fan and freezing the contents of the fridge ,I turned the f/f off. On turning back on the freezer works the fridge does not
  • Anonymous May 11, 2009
    We had noise from the fan and now the water dispener does not work
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Posted on Sep 20, 2009
Samsung american style f/f without water dispenser. Fan started making a lot of noise. Switched the f/f off. On turning back on the freezer works but the fridge does not, although the back light still operates when the door is opened and the LCD shows a temperature of 2 degrees
Posted on Aug 20, 2008
Fridge/freezer freezing up
common issue on uk samsung rsh1 american style appliances
easy cured - diy repair kits been on the market a few years now
watch this youtube video for some extra help
Jun 10, 2014 | Samsung RSH1DTMH American Style Silver 524...
I have a samsung fridge freezer model no RSH1DTMH and the fridge will not go lower than 13degrees and the freezer and water dispenser seem ok. The fridge freezer is only 3 years old. Any ideas/
We had the same fault on our Samsung American style RSH1DBRS fridge freezer as lots of other people seem to be having. After doing lots of research, we found the best solution seemed to be to buy a repair kit from Appliance DIY Repairs. The instructions were fantastic and the installation was a doddle. Excellent service & well priced.
Jan 19, 2011 | Samsung RS2630SH Side by Side Refrigerator
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Samsung american fridgefreezer
2 years is much too short for starting problems with a refridgerator contact your dealer for a condition because of warranty on the repair you eventual will spend on it. Hidden defects are factory falts are there some holes for melting water are clogged inside the fridge somewhere
An ordinary refrigerator is made for a 17-year life span. like brands as Bosch Siemens Kuppersbusch easely have that lifetime but your dealer is the right point to get your service .
Aug 18, 2017 | Samsung RS2630SH Side by Side Refrigerator
Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Jul 23, 2008 | Refrigerators
Have a samsung American style fridge/freezer with water and ice dispenser. Water gets to the water dispenser but not to the ice cube maker. can not see anyway of getting to the pipe inside the...
verify on the back side of fridge sometimes you will see the water lines if not there's like a a cover that goes vertically if removed, probably you'll have access to water line its probably plugged up...
or sometimes air gets trapped in the supply line to purge just simply loosen the nut or fitting it should spit some water do this just enough to let air out about after 30 sec. if there was some air in the water line i should start to spit water...
hope i could be of help
Apr 13, 2008 | Refrigerators
Samsung side by side American style fridge/freezer
make sure your fan is running in freezer section. you should hear it
Dec 02, 2007 | Freezers
SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Oct 12, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
923 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
