Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer problem
No matter which cycle i choose, heavy duty, normal, it will stop several minutes later with an error code F H I am at my mothers house and she is in the hospital and my clothes are being held hostage in the washer. It is on normal cycle and the status is wash and add garmet. It is beeping and flashing an F and an H and I can't get it to finish the cycle. Help, I need to get to the Hospital to visit with her by 9:00 a.m. and it is 7:11 now.
    President:
  • Whirlpool Master
  • 2,651 Answers
Turn the water supply on,, f/h is a fault occurring when ther is no incomig waterdetected
Posted on Apr 02, 2008
Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet 9100 starts cycle then stops & wont drain
F2 code is a drain issue. If you are not using he detergent you can cause slow draining and then you will get the code. Try using less detergent. Also, try disconnecting the power to the washer to reset controls.
Mar 24, 2009 | Whirlpool GHW9100L Front Load Washer
Whirlpool Duet Washmachine F11Code
The error code F-11 on your washing machine means:--
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
both this parts needs to be checked.
You will have to check the following to confirm where the fault exactly is:---
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU).
Check the Drive system for any worn or failed components.
Check MCU.
Check CCU.
Check Motor.
Check Wire Harness.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed. Press PAUSE/CANCEL two
times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make
4. Check the drain pump filter for foreign objects.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
First, try to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code reappears, then proceed with the steps outlined in the link I provided for you.
This is one of the more "involved" error codes that you may need spend some time with. Although, it may NOT be a difficult repair, it still may require some diligence to figure out the cause. I would recommend checking your washer installation for a potential siphoning problem and then check the drain pump as these are the more common causes. If you require additional assistance, please let me know. I hope this helps you.
Jan 04, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
"F" error code in WTW6600SG1 Cabrio Washer
I don't have a solition and am looking for one my duet whirlpool keeps coming up code F
Jul 07, 2008 | Whirlpool WTW6600SW Top Load
Our machine was giving the HF code at 37 min after over filling with water. I unplugged the machine, popped the top (took the 3 torx screws off the back) pulled the small hose off the pressure switch sensor (round sensor on the upper back right of the machine) and blew it out just by mouth. It obviously cleared some junk. It works fine now. (also unplugged the 6 wires on the sensor, turned it around and blew on that and heard it clicking, so I knew that was ok.) Hope this helps someone.
Oct 14, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
741 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
