Question about BenQ PB6110 Multimedia Projector
Benq 6110 - mounting projector onto ceiling
Help required to get the image flipped correctly when trying to mount the projector onto the ceiling
    Novelist:
  • 155 Answers
You need to navigate to the 'advance' menu and under the 'mirror' setting select 'ceiling front' or 'ceiling rear' depending on whether you are front or rear projecting. It should all be on page 29 of the manual.
Hope this helps
Matt.
Posted on Apr 01, 2008
How to se benq mp623 screen upside down?
Very fixable - Go to your main menu (using your remote) and navigate to the option to flip the image. This feature is to accommodate projectors mounted upside down to the ceiling. Check your manual under general operation.
-GWOOD
Jul 14, 2014 | BenQ MP623 DLP Projector
I mounted the projector on the ceiling and need to flip the image
ok go in the main menu u see 4 windows under on eof the options flip throw the windows to get it to go right side up ok in menu settings on the sony ok
Feb 02, 2008 | Sony VPL-VW100 (Ruby) Multimedia Projector
I have a Panasonic PT-LM2U; when it is turned on, everything powers up fine but the image projected is upside down. I've looked through the menu but didn't see an option for flipping or rotating...
Every modern projector that I have seen has a setting that will allow you to flip the image for this.If you purchased it used it was probably configured as a ceiling mount in an upside down orientation or rear projection onto a translucent screen. (The projection method can be set from the "OPTION2" menu. in a Model LM1 so it should be similar. http://service.us.panasonic.com/OPERMANPDF/PTLM1U.PDF
If yours doesn't have this option, then you'll have to use mounts that require the projector to be upside down.
Jul 18, 2011 | Panasonic PT-LM2U Multimedia Projector
Ceiling-mounted benq projector giving upside down immage? how can i reposition the immage? thanx
it should be an option in the on screen menu to flip picture
all projectors have this as option
it will be under "source" and it is "mirror" setting
good luck
Mar 21, 2011 | BenQ PB6100 Multimedia Projector
Casting image lower on wall
I don't know the model number for your projector, but most projectors are designed to place the image level with the bottom of the projector, which works great for tabletop mounting but not so great for ceiling mounts.
If you're mounted at ceiling height, try turning the projector upside down to see if it places the image in the right place on your screen. If that fixes it, then use the on-screen menus for your projector to flip the image and you should be all set.
Dec 09, 2009 | Dell Office Equipment & Supplies
Mounting the Projector from the Ceiling
Projectors, in general want to project the bottom of the image 1 foot above the lens at a typical range. When mounted upside down, they project the top of the image 1 foot below the center of the lens. If you don't want to turn the projector over, you'll have to change the angle and probably go to the extreme on the keystone correction.
Aug 05, 2009 | Dell 1200MP DLP Projector
Upside down image
These projectors are designed to be mounted upside down. Think of a projector that is ceiling mounted in a classroom. Change this setting in Menu - Advanced Menu - Setup - Mirror.
Jun 09, 2009 | Hitachi CP-X445 LCD Projector
Mustang projector mount required mounting projector upside down...
You may have figured it out by now... From the remote, you go into the menu and find the setting "Display Image" and the option is "Ceiling".
Dec 26, 2007 | Panasonic PT-AE700U Multimedia Projector
BenQ PB6110 Multimedia Projector Logo
165 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
