Question about Ovens
New World(Stoves) Twinline Gas Oven About 9-10 yrs old
The programmer on this appliance failed almost immediately when it was first installed. However the appliance still worked ok.The oven section failed to work at all just recently, on inspection I found that the "One shot blow devices" attached to the wire wound resistors had gone open circuit. I replaced the programmer, the cooling fan control circuit board and the mains interference filter,all of which I had bought as spares but not fitted (as I stated the appliance worked fine).The oven worked perfectly for 24 hrs, then again refused to function although the grill section did.On doing a continuity check I again found that one of the "One shot blow devices" attached to the wire wound resistors had gone open circuit. I connected the fan directly to the mains, and it ran perfectly OK, did not get warm, no funny noises or anything else to give me cause to suspect it to be at fault.
Moreover, when the grill is in operation, the fan comes on as it should under the control of the resistor and thermal switch (mounted on the same board as the wire wound resistors), and cuts out after a set period when the grill has been switched off. I am therefore somewhat at a loss to pin down exactly what is at fault, the programmer is not receiving any elec. supply, because the one shot devices have isolated it to give a clear indication of a fault and hence prevent the oven functioning.
It grieves me to have to turn to people int the US for help, but the company who are now responsible for service support on this appliance are completely useless as far as assistance is concerned, they won't put me in touch with one of their service engineers, and because I live on a boat won't come out to me anyway !!. Without someone's technical help I cannot progress the problem, I am a qualified electro/mechanical engineer and will be able to fix the appliance with a bit of help. The gas side of the oven is not involved, the fault I am sure is solely electrical.
I look forward in anticipation to your response.
Kind regards John Hall
  • 871 Answers
Hey john, i would suspect there is a faulty flow of the current. is any of the wires torn or worn off? is there anything there that you see that is grounded?
Posted on Apr 01, 2008
  • earl norman llanera
    earl norman llanera Apr 01, 2008
    in regards to ginko,& The Machine ,
    there is a big possibility that the board although still working, is alreaady unstable and that is why you coulndt pin down which is giving the problem. even after doing the continuity process again and again.
    keyword here is " unstable".
    Master:
  • 788 Answers
Sounds like the oven has been more problem than it's worth. Time to replace it it seems.
  • Ovens Master
  • 19,396 Answers
The control board should probably be replaced
  • Ginko
    Ginko Apr 01, 2008
    I see you have more problems at same times. As I thought at start the control board may be the cause for the problem. I know you already replaced it, but if after 24 hours working fine with new PCB you restarting having the problem, this means the control board fried up in 24 hours. A short on some connection to the control board may be the cause for it. Test again the components on control board and see if you can find any of them that blew. If you find it try identifying which connection to the control board may be cause for the problem.
Gas wont stay lit after ignition
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 19, 2011 | New World G60m Gas Single Oven
No manual. How to set self cleaning electric oven that is approx. 20 yrs old.
If you can give the make and model of your oven a manual could probably be found.
However before you consider running the self clean feature be sure to read this...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
Heatman101
Mar 10, 2010 | Stoves Ovens
New world twinline 4000 oven - bottom oven door won't shut properly - looks as though the hinge(s) are too slack
You are right in thinking it is the door hinges that is the cause of the problem .they are non adjustable, so only solution is to replace both hinges.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Ovens
Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Dec 22, 2008 | Stoves 720EF Electric Double Oven
Gas smell when start oven
Hello, Kimquy25 -
Fixya.com is not a website for scheduling a Sears technician to inspect your gas stove.
Since you live in Houston, Texas, see the information here:
https://www.searshomeservices.com/locations/appliance-repair/tx-houston/4201-main-st
Personal opinion: If you can avoid it, do not use your gas stove / oven until a repair person checks it. Also, if you think there is a gas leak, IMMEDIATELY LEAVE YOUR HOME, go to a safe location and call the CenterPoint Energy natural gas Leak Emergency Hotline: 888-876-5786. - See more at: http://www.centerpointenergy.com/en-us/residential/customer-service/reporting?sa=LA#sthash.fGZo7JXh.dpuf
Best wishes.
Dec 19, 2017 | Stoves 720EF Electric Double Oven
Stoves 720ef electric double oven not working
According to the circuit diagram on page 31 of the handbook, power for the ovens passes through the clock. The power feed is direct for the actual clock but via a seperate Thermal Cutout for both the top and bottom ovens. I think it is highly unlikely that both Thermal Cutouts have failed at the same time. I would try turning the power off totally to the oven for a while and then turning it back on, set the time and ensure the oven is in manual mode. As the top and bottom ovens have seperate controls after the Programmer and both are not working, it has to be the programmer that is not extending the power through to the rest of the oven.
Nov 11, 2008 | Stoves 720EF Electric Double Oven
Stoves 900G gas oven stopped working
A lot of times the problem is with a dirty or a clogged burner. Make sure the burner is clean.
If you have a pilotless model, it uses a spark igniter to ignite the gas, which works in a combination with a spark switch (located on the burner gas valve) and a spark module. Because it is not simple to test these parts and find out which one is defective, we recommend to contact a professional appliance technician.
Sep 03, 2008 | Stoves Premier 900GRa Gas Double Oven
Stoves Gas Oven
i am having the same problem but i have been told it is the cooler fan so i have ordered a new one,the fan unit requires running as it is linked to safety sensors the equal air preasure and if not equiled by the fan moter it cuts everything off and in my case it trips the mains power but may not in your case
Jul 07, 2008 | Stoves Premier 900GRa Gas Double Oven
I have a double gas oven and no instructions
I have an O'Keefe & Merritt double oven gas stove. The model number is 72 7242 23. The upper oven is about the size of a large microwave and sits above the range burners. The lower (full-size) oven is below the burner unit and includes a broiler draw below it.
So, when you say, double oven, I wonder if you are just talking about the main oven with broiler drawer (both of which are below the burner unit.)
Mine was a builder-supplied appliance in the new house we purchased in 1986. The upper oven has never performed very well. And, yes the upper oven can only be used for baking.
I have an instruction manual for it, but it doesn't provide that much information. Getting parts for it is extremely difficult, since Tappan is no longer manufacturing this brand. (I've been trying to locate a flat oven ignitor for the upper oven and can't seem to find a replacement that's the same 6-1/3" length.) In the 1980s Tappan apparently purchased O'Keefe & Merritt and marketed this brand for several years. Models originally manufactured by O'Keefe & Merritt in the 1930s-1950s are considered collectible antique stoves!
If you want to email me, I'm at oldvic@erols.com
Apr 20, 2008 | Stoves Premier 900GRa Gas Double Oven
Ovens Logo
100 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
