Question about Electronics - Others
Memory card gentleman, I can't see my pictures with my camera and my SD Card reader. The message is : memory card error, check your memory card. I inserted several times, it doesn't work. I hope I don't loose all my pictures Thank you Marcel Cataldo marcelc@bellsouth.net my card is SD card 256MB
  • kallu25 Dec 07, 2008
    gentleman,
  • 94 Answers
Hi
try formating once. may be the card is okay but formated in diffeent format.
also, try using on other camera or pc to find is it working
Posted on Apr 02, 2008
Eclipse avn110m sd card error 013006
This must be very upsetting for you - what make and model of camera has this occurred on ?
Jan 05, 2017 | Cameras
I have an Akai DC6371 digital camera and the card I have in it is a Kodak 128mb SD card. However, the camera will only let me save 4 pics to the SD card. I tried putting a different card in it that's...
Hi I can tell that sometime you have to format within computer using external memory card reader, not from camera. It is not recommend switching around one sd card to another camera. It cause card error. If you want to use it, then you have to save pictures somewhere in other storage or computer, and format the one you want to use in computer using external memory card reader. And then one more time format in camera (you have to insert memory card into camera) These method very helpful on like your problem. If not working, then you have either camera defective or memory defective. Thanks and best regard!
May 25, 2011 | Akai DC6371 Digital Camera
I am getting error message that sd card is blank and/or when i want to use my camera error message comes as insert your sd card..i try to format the sd card by following format sd card section but nothing...
Try formatting your SD card by plugging in Laptop's or using a memory card reader. Don't use the cell, after formatting insert in cell and re-format. it will work.
Nov 10, 2010 | Sony Ericsson XPERIA X10 Cell Phone
SONY DCS T1 FORMAT ERROR C:13:01
Hi.. I think you have solved the problem yourself... replace the adapter with a memory stick... You have eliminated the micro sd card as bad... now try a new known good memory stick..
Thanks
jim
Feb 18, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
KINGSTON 4GB MEMORY SD CARD
Check if your camera can support a 4G card. Some don't support than 2GB. if it supports, re-insert the card.
PS. If you have a card reader. Formatting once from your computer can help.
Jan 15, 2009 | Kingston 4GB Secure Digital High Capacity...
Camera not reading SD card after being removed from my reader
Put the SD card back into the card reader. Are you files still there when the computer tries to read them?
If they are not, then it is very likely the card is corrupt. This happens when the card is removed before the computer is done reading/writing to the card.
There is also a SLIM chance the card is just bad.
Nov 06, 2008 | SanDisk MobileMate SD+ 5-in-1 USB 2.0 Card...
Optio E10
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Oct 11, 2008 | Pentax Optio S7 Digital Camera
Memory Full Error
You need to format the SD memory card using the camera format function. The manual should tell you how to do this. If you don't have the manual, you can download it from the samsung website.
Jul 05, 2007 | Samsung Digimax S700 Digital Camera
Electronics - Others Logo
205 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
