Question about Whirlpool MH7130XE Microwave Oven
Blown Range lights - Damage to Circuit Board
Hello MicorwaveSvc,
I have blown out my range lights and damaged the circuit board by trying to change the bulbs and neglecting to disconnect the power supply.
I read in an old post that you used to repair these. Is this a service that you still offer?
Thanks,
Ed
  • Anonymous Apr 08, 2008
    it happened to me too. I tried to unscrew the light bulb and sparks came out of the circuit board. Did you get a replacement part? I'm looking for one now.
  • Anonymous Apr 23, 2008
    My problem is the same. I just want to know how to access the circuit board so I can send it to you.
                                         Don --VMI59@aol.com
  • Whirlpool Master
  • 9,098 Answers
Frank7580 and Guest:
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 08, 2008
  • William Miller
    William Miller Apr 18, 2008
    Full details of our service are athttp://www.microwavedisplay.com
  • William Miller
    William Miller Apr 27, 2008
    Guest:
    information
    Or seehttp://www.microwavedisplay.com
When changing the lightbulb under the over the range microwave oven I heard a pop sound and now neither of the lights or the fan won't work but the microwave and the clock on it still works, it is just...
probably caused a short while replacing the bulb(s) and, causing damage to the circuit board. pull the board out and carefully check for burned foil traces; and rebridge with solder. it may or may not work. always unplug the microwave when replacing the range lamps.
Aug 06, 2011 | Hotpoint RVM1435 Microwave Oven
The light went out an the turntable won't stop when I close the door...i tried to push clear, but it still turns. I couldn't find my model number on the below pull down, but my model is 721.8001...
721.80019401 (without spaces) is the correct model number.
If it was the cooktop lamp(s) that went out, I would suspect that it shorted, damaging the control circuit board.
We see and repair this problem on a regular basis with our $39.95 repair service.
Or you can order a new control circuit board (part number 6871W1S354A) for $75.80 from the Sears Parts Direct Web site.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
May 24, 2011 | Kenmore 80012 Microwave Oven
Does not work. has F2 displayed on screen.155l model khm
hello,
This error code on a Kitchen Aid range indicates a keypad short on the Electronic Range Control (ERC) board. This is the clock/timer on the operator console. The recommended fix is to replace the ERC. You can generally find replacement parts at these websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop and compare.
Replacing an ERC is not a difficult repair and can be accomplished by the average do-it-your self offer. If you decide to order the part and wish to repair this on your own, follow these steps:
1. UNPLUG the range. Dangerous voltage is still present inside even with the range turned off.
2. Pull the range away from the wall and turn the unit around so you can access the rear panel.
3. Remove the screws on the back of the operator console.
4. Carefully disconnect the connector plugs to the ERC. Take note of how they are connected, so that you can reinstall them correctly.
NOTE: The connectors are usually color coded with the colors printed on the circuit board. However, if the colors are not printed on the board, write them down. (A digital camera also comes in real handy for this).
5. With the connectors removed, remove the mounting screws to the ERC and the assembly will come out.
NOTE: Most replacement ERC boards do not come with the overlay. This is the plastic pre-printed number display. The overlay can easily be peeled off and re-used. Just make sure you properly orient the overlay so that you don't inadvertently place it on the new board upside down. If your existing overlay is damaged, you will need to order separately.
6. Install new ERC using the steps provided in reverse order. Minimize handling the new circuit board with your bare hands to avoid damaging the board.
I hope this information helps you.
thank you for using fixya.
Jul 12, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I have the Panasonic over the range NNSD227B/W microwave - I started having problems with turning the light on under the microwave - button wasn't working. Now the whole microwave has shut down - No power...
Unfortunately the unit will have to be opened up to check any further problems. If you can, check inside on the power circuit board for blown fuses or any other component which seems to be burnt. It's not always possible to see if a component is blown without testing it but the problem is almost certainly on the main power board.
Best wishes,
Graemevm
Jan 24, 2010 | Microwave Ovens
Microwave shorted out when metal grease filter contacted inside
It might be that the internal power fuse of the MW may have blown. You may have to just replace that fuse if possible. Other wise the electronics (most likely a circuit board) may have been blown.
Jun 29, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Sanyo EM-710F display dead
Low voltage Tx actually OK. Restored vaporised circuit tracks on controller board, fuse and interior light globe. All working OK.
Jun 18, 2008 | Microwave Ovens
GE spacemaker xl 1400, lights on bottom won't work
To Person who answered Best Solution above,
This worked nicely thank you.
After removing my circuit board the long silver strip was intact, however where it makes the turn about quarter inch, the solder or foil seam had a break in it which I filled-gap with solder.
My guess is if the "foil" or thin 2" long strip is serving as a fuse, it would still melt again even with my solder on the shorter section, in event of overload. Also seen on the plastic area directly behind where the circuit board would mount, and where the "foil" was blown, was a small blackened area as evidence of the blown foil. 2 new bulbs and all is well again Thanks!
Jan 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Range light and oven vent fan
This usually indicates damage to the circuit board of the control unit assembly. We repair these control units nationwide for only $32.50 postpaid. If you decide first to remove or replace the bulbs or check the sockets or wiring, please unplug the microwave first. Failure to do that is usually how the boards get damaged. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can usually find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 BUT - I don't recognize NN-2501 as a valid model number. Could you confirm that? Thanks!
Feb 18, 2007 | Panasonic NN-S251 Microwave Oven
GE Microwave Spacemaker oven, Model JVM240
That would almost certainly be a problem on the control circuit board. If the bulbs happen to short / blow out or if they are removed or installed while the microwave is still plugged in, there is often an arc which causes damage to the board. We repair regularly these boards for such problems for $32.50 nationwide.
Dec 23, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
JVM1320WB001 1000W
The problem is damage to the control circuit board. This damage is usually caused by removing or installing light bulbs without disconnecting the oven from the power line first. We regularly repair these GE / Samsung smart boards for this problem for customers from across the country for $32.50. We have an important file called "safety.txt" which you can find by doing a search for "microwave safety.txt" on Yahoo.com. It's important information to consider before proceeding. When the varistor fails, it will be shorted. That will cause the whole oven to be "dead". It's almost certainly fine.
Jun 28, 2006 | GE JVM1542 Microwave Oven
Whirlpool MH7130XE Microwave Oven Logo
147 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
