Question about Sony PlayStation Portable (PSP) Console
PSP Slim UMD Tray Issue
Hello, There is a little lever inside the UMD area that is depressed when you place in a UMD in and close the door. In my PSP that lever is broken and I need it fixed. What is the name of that lever and how can I get it fixed. Please Help.
  • Anonymous Oct 09, 2008
    yeah mine does too except its not broken, its just come off its "tracks" and there seems to bee little holes at the end of the tracks, but the ends dont want to go back that far. this happened when i dropped it.
  • 97 Answers
You need a whole new psp chasis. its not major, maybe 10 bucks off the net. email me - gabrielsimut@yahoo.com for replacing instructions
Posted on May 02, 2008
My sony psp phat umd not read
If it's for all UMD's, you should check something out. Open up the UMD door and leave it open for this test. There's going to be a little lever inside that you need to push down. Looking at the UMD door from behind, screen facing away from you, the little lever is going to be on the top right, you'll see it. Push it down, while the PSP is on and look at where the laser is. You should see a red light coming from it, and it'll be obvious. If you don't see the light, your laser is broken.
May 06, 2010 | Sony PlayStation Portable (PSP) Console
Umd keeps reading
the umd drive is approaching its end of the life. you might need to buy http://www.consolezombie.com/store/slim-replacement-drive-laser-assembly-p-34.html and replace your umd drive. This is what i just did to my psp-2001.
PS: The above link is only for PSP-200x (slim version of PSP)
Nov 26, 2009 | Sony PlayStation Portable (PSP) Slim...
How do i turn on the WLAN?
Bottom left hand corner there should be a switch for the PSP original.
The new one, PSP Slim, the wifi (WLAN) switch should be in the place of the UMD door opening switch. So top center.
Aug 25, 2009 | Sony PlayStation Portable (PSP) Console
My psp 3000 will not read the umd when I put a game in....
When you open the UMD tray chek if there is any thing wrong when it tries to read.
Jul 03, 2009 | Sony PlayStation Portable (PSP) Slim...
Psp always read from umd,making it hang
Hi! I incounter this problem as well even without UMD its still loading and even I disable auto-start UMD still same so I tried reflashing the software but still same problem so I discover the solution before you turn-on your PSP try to open your UMD cover you'll see it will load faster then close again the cover once you see the battery and clock icon... The problem that causing this is the switch inside the UMD possible its stock-up or spoiled already!
Jun 08, 2009 | Sony PlayStation Portable (PSP) Console
Psp slim dosent read umds dono whats wrong makes a little noise
Is this happening with every UMD? If so the laser has gone bad. Google tutorials on how to replace it or have it replaced.
May 31, 2009 | Sony PlayStation Portable (PSP) Console
My psp umd door wont close properly, what is the problem
maybe something on the inside is moved because ive openened a psp before and the thing in the back of the screen is like a hook that holds the screen shut. or maybe the little thing in your umd door that holds that little closing thing broke off. u can solve this also by hacking your psp and running the games trough the M33 driver. =D
Apr 19, 2009 | Sony PlayStation Portable (PSP) Console
Psp 5.03 downgrade to 3.9 m33-3
First, try to determine your PSP's version. If it is the PSP 3000 (PSP slim with a narrow ring on the UMD Door), you can only play game demos from the PSN and can't be modded as of this date. If you have the PSP 2000 (slim with a wide ring on the UMD door) there is a chance you can't downgrade depending on your motherboard. Pandora's Battery and MMS is required to 'jaibreak' your PSP if you are on Sony official firmware.
Apr 11, 2009 | Sony PlayStation Portable (PSP) Slim...
PSP Slim making click sounds when UMD is in
it could be a problem with the inside mechanisms of the UMD dock. Better make sure that the insides are clean and free of dirt or small particles.
Feb 08, 2009 | Sony PlayStation Portable (PSP) Slim...
Psps does load any discs
Hi Tubston1980,
What we have here, is a failure to read the UMD.  Troubleshooting 101,  open the UMD door and depress the little black spur sticking up about 1/8" and it is about 3/4" in and to the left.  Once your depress the Black spur, You should see the the little disc motor spin and the laser beam light up.  Do not stare into the laser. This tells you that at least the laser is lighting and the motor is turning,  Now, get a Q-tip and dampen it with Isopropyl rubbing alcohol.  Rub the lens with the dampened q-tip.  Use the dry end of the Q-tip to dry the lens. Look carefully to see if any lint or foriegn obsjects are inside the UMD disc drive.  If you see anything, get it out. Look at the white gear in that back to see if anything is on it. Clean it if necessary, I know its very close quarters and hard to do.
I repair PSP's with this problem that do not get fixed after cleaning. I can replace your UMD drive with a full brand new drive for $47 which includes Return shipping. Contact me at Repairtech@playstationclinic.com if you need further assitance.
Oct 15, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
173 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
