Question about HP OfficeJet G85 All-In-One InkJet Printer
Not printing none of the troubleshooting solutions is working
  • Anonymous Apr 04, 2008
    paper jamed in printer will not print now paper has been cleared
Have you tried shutting down the spooler temporarily, then restarting. Works for mine, on occasions when certain printing jobs seem to freeze the printer.
Posted on Jun 15, 2008
HP CP5225 printing from iPad problem
HP has a list of solutions for print quality problems. Have you tried all the solutions suggested here?
Troubleshoot problem for HP Color LaserJet Professional CP5225 Printer...
There were also a couple Mac specific solutions available (links look the same but are different). Both solutions are about prints being different than expected.
I am an HP employee.
Apr 20, 2013 | HEWLETT-PACKARD CP5225dn Laser Printer
I have a inpiron 530 with a Photo 926 printer. It will only print the last page of a print job.
Hello randy,
This is going to take some troubleshooting.
Please try the following, and test after each change. Hopefully we can get this working for you quickly Verify that when you hit print it under print range that only the last page is selected.
Try printing a different document, this is assuming you've been only having the issue with one document. Try printing a different type of document, using a different program such as word, notepad, or even a multi-page website.
If any of these has worked for you then it has either narrowed it down to the specific document, or the program, re install the program in question.
If none of the following has helped.
go to start/run type cmd to open the command prompt type following net stop spooler net start spooler this will restart the print spooler service.
If none of the above worked, delete the printer and reinstall. If problem persists install printer on a separate computer to verify that it works correctly.
Good luck, and I hope i was helpful.
Aug 14, 2011 | Dell 946 All-In-One InkJet Printer
My Xerox Phaser 8560 is not printing the red properly. It comes out more llike a brown. The light blue comes as a teal and bubble gum pink comes out like a light pale plum. Peach comes out as beige. Is...
Solution : Print the Troubleshooting Print Quality Pages and Make Sure the Colors Are Accurate CAUTION: Use of inks other than Genuine Xerox Solid Ink may affect print quality and printer reliability. It is the only ink designed and manufactured under strict quality controls by Xerox for specific use with this printer. The Xerox Warranty, Service Agreements, and Total Satisfaction Guarantee do not cover damage, malfunction, or degradation of performance caused by use of non-Xerox supplies, or the use of Xerox supplies not specified for this printer.
To print the Troubleshooting Print Quality pages:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Problems], and then press the [OK] button to print the test pages.
  4. Go through the pages and find the Light Stripes Test page.
    For each color, remove an unused solid ink stick from the printer, and then use the ink stick to make a mark of color next to the corresponding color on the printed page. If the colors do not closely match, that color will need to be purged from the print head. Continue with step 6 if the colors do not closely match.
  5. NOTE: If the colors do closely match, the problem is not related to the printer's hardware. There is no hardware adjustment available on the Control Panel for calibrating individual colors.
  6. Create a document consisting of a full page (100% fill) of the color not printing correctly, or download and use one of the resource files provided in the table below. For example, if cyan ink is actually printing black, create a document that is a solid fill of cyan, or download and open the Cyan fill page provided in the table below.
    IMPORTANT: Make sure to set the Print Quality mode in the print driver to "Standard" and the TekColor Correction to "None" before performing the next step. This will allow the job to purge only the problem color. Other settings may cause the printer to use a percentage of the other ink sticks.
  7. Print approximately 50 - 100 pages of the document, as necessary, until the printed color returns to normal.
IF THAT DOESN'T SOLVE THE PROBLEM TRY THIS: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=156,E=0000000002703198886,K=8233,Sxi=10,Solution=obj(964)
May 27, 2011 | Xerox Phaser 8560N Laser Printer
Itunes won't start up in windows XP Home edition already tried the solution from mneilsen2084 but did not work Please help. Stil getting een error no no but won't go an y further.
Itunes has posted a solution here: http://support.apple.com/kb/TS1717
Follow the steps carefully and print the page off before you start, making sure you print off both the System-wide troubleshooting and User-specific troubleshooting sections. Good luck.
Feb 01, 2010 | Apple iTunes
LCD Error: "Check Printer"
I FOUND A SOLUTION that worked for me for the CANON F50:
F30/F50 Printer
1. Enter Service Mode - by pressing "menu then copy then #"
2. Select TEST MODE
3. Select (8) PRINTER TEST in TEST MODE
4. Select 3 (EEPROM CLEAR)
5. Select 0 (INK COUNT)
6. Press Stop/Reset key
7. Press On/Off Key
Jun 03, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Won't Print
Usb or Parallel cable? if USB the computer should say new hardware found. If Parallel the should be checked to see if enabled.
Aug 29, 2007 | HP LaserJet 4L Printer
Printer not working
You can read the user manual here: http://www.brother-usa.com/Data/Documentation/Fax/User/UM_MFC210C_420CN.pdf Page 123 (11-4) lists your problem and gives several suggestions on how to resolve it. If none of these suggestion work, you can also try here: http://solutions.brother.com/ http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc210c_all
Sep 26, 2006 | Brother MFC 210C All-In-One InkJet Printer
HP OfficeJet G85 All-In-One InkJet Printer Logo
94 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
