posted by drking on Apr 01, 2008
When I click on my desktop HP Solution center software, the program initiates for a second then goes off and a window pops up that says,"No HP devices have been detected. HP Solutions center will close now." I can scan pictures through my HP digital imaging program but cannot scan and ocr documents. I am using MS Office 2007 Professional Office Suite. I have scrubbed and reinstalled the Scanner/printer software and it didnt do any good.
Solution #1
posted on May 03, 2008
I have the same problem with my HP Officejet Pro l7580. I was able to get it working, but it is not the optimal solution. First, I restored the system with the system disks but did not put up any of the Microsoft Security patches. Everything works perfect. As soon as I install the patches, I have a problem.
Below is what HP told me, but I have not tried it. I do not believe this is a firewall problem, but I put this out there is someone wanted to try.
Solution:
Add programs to the firewall exception list
1. Open the firewall program.
2. Add the following files to the Highly Trusted programs list:
* hpqkygrp.exe, located under the C:\program files\HP\digital imaging\bin solution centery.
* hpqscnvw.exe, located under the C:\program files\HP\digital imaging\bin solution centery.
* hpzipm12.exe, located under the C:\windows\system32 solution centery.
* hpzinw12.exe, located under the C:\windows\system32 solution centery.
* hpqtra08.exe, located under the C:\program files\HP\digital imaging\bin solution centery.
*hpqthb08.exe, located under the C:\program files\HP\digital imaging\bin solution centery.
NOTE: Not all of the files mentioned above will be present on your computer.
3. If all these executables are already added, then check if full access has been granted to them.
4. Open the following ports on your firewall utility by following the instructions provided by the manufacturer:
* UDP ports: 161, 427 and 137
* TCP ports: 9220, 9500 and 9290
Solution:
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
I have been working on the same problem. Here is what I found. 1) When I rebuild my XP system and do not install the XP security patchs, everything works great. As soon as I install the patchs, the system stops working. HP has been unable to help.
Solution #3
posted on Apr 01, 2008
Hello drking,
I feel your pain!! I have an HP Pro L7650 that behaves the same way. If you figure it out I would sure like to know how you did it. I hate these pickey little problems! Give me SMOKE anytime... I know what to do with that.
haMAR
haMAR
This Problem Also Relates To:
HP Scanjet 4370
HP Scanjet 4200c Flatbed Scanner
HP ScanJet 6200C Flatbed Scanner
Panasonic KV-2025C
Panasonic KV-S3065CL Path-Through Scanner
Panasonic KV S2026C Path-Through Scanner
Acer AcerScan 310S Flatbed Scanner
Can you Help with these Scanners problems?
Umax Astra 6700 Flatbed Scanner
Sug: Window Vista driver of...
Dear Sir I have a umax astra... Answer This...
Acer ScanPrisa 640U Flatbed Scanner
acerscan 620U upgrade to Vista
Hi, I'm trying to get my... Answer This...
Repair Service
Find Scanner Repairman Near You:
