Question about Samsung SMH7178STD Microwave Oven
No heat! Our 3 year old microwave has worked great but now it won't heat. Help!
  • 871 Answers
You have to replace the heating element for that old microwave. its already been 3 years. sometimes this do happens because of the use and this is the solution.
Posted on Apr 01, 2008
SOURCE:
I have an old Sanyo Microwave Model EM-FL90N which has worked great, everything works but it seems not to be heating stuff up. The manual is not of much help either. Any suggestions? Help?
Javaid,
You might want to consider replacing the microwave if it is more than 8-10 years old. Sounds like you have a magnatron that is going bad and that is what does the cooking, and to replace it could cost you almost as much as a newer microwave. Hope this helps!
Mar 24, 2016 | Sanyo Microwave Ovens
Ge spacemaker microwave JVM1650 won't heat
sounds like possible magnatron or diode thats the case its not worth repairing. but if your handy then google model nuber and get the part be extreamly careful because of the power capacitor holds extream volts. turn off and allow to sit 15min before working on
Oct 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't heat
The problem is in the magnetron or the inverter board if 7 years old or less.
May 25, 2012 | Cuisinart CWM-100 Microwave Oven
My morphy richards p80d20p-yu microwave runs normal but won't heat food
The problem is caused by a bad magnetron, inverter board, "7 years old or less" and possibily the keypad control board.
May 02, 2012 | Microwave Ovens
Problem with the GE Spacemaker (JVM1640SJ) Microwave Oven GE Spacemaker XL1800 won't heat food anymore....It worked this morning, now won't heat. What should I do?
GE Will replace the magnetron for 9 years! Mine is a 2004 model with a one year warrently according to manual. HOWEVER they did say the magnatron was covered for nine years: call 888-239-6832. When I called they said thats all they get calls for and would send out in 3-5 days. NO CHARGE. I had to ask if there was coverage longer than a year on major parts and that's when they offered the info and I eventually was transferred to the right office. Saved $120 bucks on parts alone.
Jun 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag Microwave apprears to work but does not cook
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101-==-
May 17, 2010 | Maytag MMV4205 Microwave Oven
Microwave on w/light but fan and heat not working
The problem is the door switch is defective. I'm on my third new switch in 3 years. The part number is 5304440026.
Mar 29, 2009 | Electrolux Microwave Ovens
No Heat.
Hi dadedulitl,
When you say "putting out no heat", I take that to mean it's not heating the food up. When a microwave suddenly stops heating food, but still appears to run, it's usually a defective/dead magnetron. Prices for replacement/repair will vary, you will need to find out what that service costs in your locality before having enough information to decide on repair or replacement.
When my first microwave lost it's magnetron (~20 yrs ago), it was 5 years old at the time, and the cost of buying a new oven was only a little more than the repair - but I had the repair done anyhow. Since then, we've replaced the entire oven instead (twice). Newer one's may have more power/less energy wastage, etc.
If it's ~ 3 years old, do you have an extended warranty?
If so, you might be able to use that (check the terms of the EW). Most standard warranties are for 1-2 years max, so unless you bought the EW, you're probably back to deciding between repair and replacement.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Feb 21, 2009 | Panasonic NN-P794SF Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
Microwave Ovens Logo
191 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Ekse
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
