Question about Sony Ericsson P910a Handheld
Touchscreen screen stuck when you touch it the signal bar meter flashes \\
  • 29 Answers
I would like to ask a couple questions that might be of some use.
First, does the same issue occur when using the phone with the flip closed? That is, can you use the jog dial and keys on the flip properly?
If the phone works fine with the keypad and jog dial, then you should be able to try to recalibrate the touchscreen.
To re-calibrate the screen:
1. Select Applications tab
2. Select Control Panel
3. Select Device
4. Select Display or Screen
5. Follow the instructions on the screen.
6. Select Yes or No
Second, if you turn the phone off and on again, with the flip open, does anything load by itself, or does the touchscreen react as if something is being pressed?
This may indicate that there is a problem with the hardware.
It is possible to purchase a new touchscreen for under $100 from a few parts retailers such as http://cnn.cn .
It may also simply be a glitch or bug in the software or firmware OS. In this case, you can try a master reset or updating the firmware using Sony Ericssons update service (not compatible with Vista for the P910), or you could use a third party firmware utility such as from DaVinci etc.
If you choose any of the master reset, firmware or update options, you will lose ALL user data on the phone, so you should back it up before you proceed.
Posted on Apr 02, 2008
Having trouble trying to figure out how to do the touch screen calibration
Touch screen is not supposed to be "calibrated" by users. All my family uses touchscreen smartphones and computers and NEVER anyone mentioned the need of calibrating a touchscreen. If you have some problem with your touchscreen, it is something beyond standard devide operation and you should take it for service, if it is on warranty, to site where it should be serviced
Apr 12, 2015 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
Screen cracked
Probably it won't be usable because the sensors on the screen is corrupted. You need to replace it with a brand new screen.
Oct 19, 2014 | Samsung Galaxy Fame GT-S6810P Smartphone -...
My v touch pro touch screen wont work
b> The Touch Pro2, manufactured by HTC, is a smartphone designed to be used with the Verizon wireless phone network. This smartphone combines a cell phone, PDA, MP3 player and wireless Internet access into a small, portable device. If the device begins malfunctioning or freezing, you can perform a soft reset. A soft reset does not delete any of your saved information. It shuts the phone down and reboots the phone to the Verizon Today Welcome Screen.
Pull the stylus upward to remove it from the side of the phone. Push the back cover upward using your thumbs until it pops from the back of the Touch Pro2 phone. The back cover can then be lifted away and removed from the phone. Press the "Reset" button, on the upper, left side of the back panel using the stylus tip. The device will now restart and display the Verizon Today screen. Snap the back cover back onto the back of the phone. Touch Screen is Not Working
As most tablet PCs ,Phones and Mp3 players are full touchscreen devices, you use your touchscreen for everything you need to do on your Tablet PC. If the touchscreen stops working, you can't get much use out of your Tablet. Touchscreen issues are caused by hardware or software problems, but check with your manufacturer before attempting a DIY repair.
Hardware Issues Damages to the surface of your Tablet PC can cause the touchscreen to malfunction or stop working entirely. For example, putting pressure on the screen, such as placing the Tablet PC in a bag with other heavy items, can cause cracking along the screen. Exposing the screen to water, even in small amounts, can cause the electrical system within the touchscreen to malfunction. If the electrical system malfunctions, the touchscreen stops working properly. b> Screen Sensitivity b> Pressing the touchscreen on your Tablet PC sends a signal to the internal motherboard. The motherboard then transmits to other components, such as the hard drive. The accuracy of the touchscreen depends on the screen's sensitivity. Many Tablet PCs include a program for calibrating the touchscreen. This program may fix minor responsive issues. Even a small amount of dirt or debris can effect how the touchscreen responds. Cleaning your touchscreen with an electronics cleaner or a microfiber cloth may help improve sensitivity. b> Software Issues b> A driver is a software program that interacts between hardware devices and an operating system, Your Tablet PC needs the right drivers for your OS to work correctly. Outdated or missing drivers can cause the touchscreen to work improperly, or not respond at all. Visit the manufacturer's website to find the right drivers for your Tablet PC. b> Repair b> While you can perform some minor repairs yourself, such as re-calibrating the touchscreen sensitivity or installing drivers, only perform a hardware repair if you have a good working knowledge of electronics, specifically Tablet PCs. Before attempting to repair your device, contact your manufacturer. If your Tablet PC has a warranty, completing an unauthorized repair may make you ineligible for claiming that warranty. Hope this helps
b>
Jan 20, 2013 | Visual Land V-Touch Pro (8 GB) MP3 Player
Garmin 1450t stuck in loader loading error after downloading maps
Please follow the instructions below to remove the "Loader Loading" message from the unit.
To fix this problem on Windows:
  1. With the nuvi powered off, press and hold the upper left hand corner of the touchscreen with your finger
  2. Continue to hold the touchscreen while pressing and releasing the power button on the device. The Garmin Logo should display
  3. Continue to hold the touchscreen while connecting the device to your computer
  4. After 30 seconds, the screen should flash white. At this point, release the touchscreen. A green progress bar should display on the device. After the progress bar completes (45-60 seconds), the device should go into Mass Storage mode
  5. Open the nuvi drive that appears in My Computer or Computer
  6. Locate the Voice folder and delete the extra Voice files that are not needed
  7. Type ".System" (without quotations) after the nuvi's letter in the address bar
    • For example, if your nuvi appears as E:\ then after typing ".System" in the address bar, it should look like this: E:\.System
  8. Locate the GUPDATE.GCD file and delete it
  9. Safely remove your device from your computer
After the corrupted update file has been removed, the device should work properly. Run the WebUpdater program to update the device's operating software.
To fix this problem on a Mac:
  4. After 30 seconds the screen should flash white. At this point, release the touchscreen. A green progress bar should display on the device. After the progress bar completes (45-60 seconds), the device should go into Mass Storage mode
  5. Open the nuvi drive that appears on the Desktop
  7. Click the GO menu at the top of the computer screen
  8. Click Go to Folder
  9. Type .System
  10. Click Go
  11. Locate the GUPDATE.GCD file and move it to your trash
  12. Empty the trash
  13. Eject the nuvi from the Mac
Jan 06, 2012 | Garmin Nuvi 1450T GPS Receiver
Part of my LG Viewty touchscreen appears to be stuck to the LCD
fix the botom by double sided self adhesive tapes.cut it accordingly as per the size needed
Apr 09, 2010 | LG KU990 Viewty
DS Lite bottom touchscreen seems "stuck"
i think you should either get a new ds or tap the touch screen hard. if tapping the touch sreen harder does not work then that means it is time for a new ds.
Jan 18, 2009 | Nintendo DS Lite Console
Touchsrcreen is stuck in some mode.
3. Select Device
6. Select Yes or No
Apr 01, 2008 | Sony Ericsson P910a Handheld
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign If you are facing any kind of issues in Toshiba laptops or other products related to Toshiba brand, then you have come to the right place, as this article is an overview of where you can find the right kind of services, required for proper working of the gadgets by any tech savvy person, in particular the ones using Toshiba products. Another beneficial thing about using Toshiba products is its reliable Toshiba Customer Service , which can be reached any time for assistance with guaranteed satisfactory results. Toshiba customer care services are provided by highly efficient and knowledgeable tech support technicians having years of working experience in the field of providing dependable services to the customers of Toshiba. Toshiba support services provided by Dataalign are the best in class for their consistent services and highly advanced way of resolving tech issues faced by the customers. Dataalign tech support team comprises of expert technicians and they make use of high class technology for fixing the issues in Toshiba laptops and other devices as they have proper knowledge of all kind of issues with their perfect resolution. Dataalign technicians can be reached easily anytime from anywhere through the toll free helpline number +1888784-9316. Dataalign assistance providing Toshiba Tech support engineers are selected through a rigorous process of selection which makes them efficient for providing right support in minimum time with high accuracy. Technicians of Dataalign assist the customers in the most polite way with the assurance of providing highly accurate solution for every issue. For the answer of any kind of query related to Dataalign or for help regarding tech issues contact Toshiba support on their toll free helpline number.
Jun 21, 2018 | Toshiba Computers & Internet
See all Sony Ericsson P910a Handheld Questions
Sony Ericsson P910a Handheld Logo
96 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
