Question about Yamaha RX-V395 Receiver
Rx-v800 You posted a reply about a memory capacitor leaking on one of the boards and identified the board as a standup board. Could you help me out with a better descriptiion of just where these caps are? this problem was on an rx-v800.
  • 4 more comments
  • trbodden Apr 01, 2008
    There is no fluid in that area. The cap I see is C646. It is the only cap with a retainer clip on it. It is next to C631 and is unusually flat compared to others on board. Is there a way to disable the protection circuit until I can get a repair manual (best source?) and look into this further.
  • trbodden Apr 02, 2008
    Don't see anything. Can't ID C633. But here is some add'l info. After leaving this system alone for a while ( more than minutes) it will come back on and stay on if I don't do anything. I can do some things (change the effeect) and it will stay on; but the minute I try to change the input, off it goes and the wait starts again.
    PS does vancebaldwin have manuals?
    Bobby , I apreciate your help on this. I found the C633 inscription. It was on the front side of the board. Will the system work if it is removed?
    I have downloaded manual. In the beginning they talk about the remote control key code. Is this the remote that comes with the unit? If so, is there a table or instruction explaining how to generate the codes? In the very beginning there is a way to disable all protection with the exception of overcurrent. I would like to try this, as working on the board would try my soldering skills at htis stage of the game (age). If all else fails, I will try or it or seek professional help. Maybe send the board to you guys,eh? thank you again for your patience, I reallly do appreciate.
    OK, it is out (had to break leads).
    what kind of tools needed for this? vacuum pump? solder ******? Will 91% isopropyl alcohol do as a cleaning agent? any advice will help.
    OK BobbyJ!!! My skepticism is dead...Removed cap, cleaned area and can now change inputs without problems. You're experience here was invaluable. Couldn't see anything wrong until cap was removed and light was shed on the area at the right angle. IL guess I'll order the part but only after I see if I can live without it. Or I may put it in from the backside, where it won't cause a problem if it goes wrong. thanks again
    trbodden
    Sergeant:
  • 395 Answers
The capacitor is on the board that is on it's side (standing up as opposed to laying flat) it is the longest board it also has most of the input jacks housed on it. the supper capacitor is on the top side middle area and it looks like a button and is either blue or black. it is a .047F 5.5 volt super cap located at C633 part number WD294400 get it at www.vancebaldwin.com .
Posted on Apr 01, 2008
  • 3 more comments
  • Robert Johnson Apr 01, 2008
    the electrolitic fluid is hard to see, you need magnifiers to see the corrosion this shorts the micro. you need to clean this up good. you can remove the cap and clean the board and leave the cap out, this is a memory cap used to keep the user settings when the power goes out. clean the area with contact cleaner and stiff brissel brush. try to get into those hard to reach places between leads and under components. do not use water or any thing that contains water. C646 is a .1uF 16 volt cap but the cap you are discribing is C633 and that is the cap to remove. it looks like it has a retaining clip but that is the lead. if you look along the side of it you should see the value and voltage written on it.
  • Robert Johnson Apr 02, 2008
    yes the system will work if removed as I stated in the last post, but you must clean the board!!! all this cap is for is the memory of your customer settings if the power sould be lost.
    the simptom you state is the clasic leaky cap. Ive done a lot of these, infact yamaha has tech posts on this problem and the super cap is the problem.
    if you find that the shut down is over current because the lines that are affected by the fluid are the sense line to the micro of the over current. that is why when you change inputs it shuts down. (mutes first then un-mutes to the amps then shut down)
    I'm glad to help
SOURCE:
RX-V800 shuts off after 7 seconds turned it on, what should I do?
Can you post that diagram here? Or you can email it to me. I can't make any promises, But Im glad to help, I have done much board work in my time, and this one just sounds interesting. L8R
Sep 16, 2007 | Yamaha RX-V800 Receiver
Loses settings after power off
Garetht, there is a capacitor to maintain your settings. This capacitor may have leaked on your board and can damage it. You should replace it and clean the area around it as soon as possible to avoid problems. The capacitor is located on CPU board and looks like a coin with two terminals.
If you are not experienced with this kind of repair, take the amp to a qualified technician.
Nov 30, 2008 | Yamaha RX-V800 Receiver
RX-V800 Shutdown on Function Change
If you can get it to turn on, you can check the problem by holding down the A/B/C/D/E and Right Preset buttons (on the amp not the remote) while turning it on (pressing Standby). This enters diagnostic mode and displays a message. If it says NO PROTECT then the protection circuits have not been triggered (see below).
If it won't turn on at all, try unplugging it and leaving it for a few days to let all the capacitors discharge. You often only get "one hit", so turn iton in diagnostic mode first.
If the dignostic message says "DC PRT nnnn" then one or more amplifier output stages have DC voltage and you will need to identify which one(s) and replace the blown output transistors and any other affected components. They aren't all that expensive, but dismantling this model is a bit of a struggle! However, if it turns on and stays on until you press a button, then the amp output stages may well be OK.
In which case, it is more likely that the microprocessor is detecting a voltage or current anomaly (PS PRT :nnnn or I PROTECT).
I had the same problem and, after replacing all components on the three main power boards, the problem went away until I reassembled it all, then it suddenly started again.
I now think this is possibly a grounding problem. Many of the boards are grounded via the chassis, and after some years use a grounding /chassis screw may get loose or oxidised causing the problem.
I dismantled the amp and soldered a length of hookup wire from a grounding point on each board to a grounding point on the next, so that all of the main boards' grounds are directly connected back to the power supplies grounds. I didn't worry about the front panel boards.
Also replace the 0.047F 5.5V memory backup button capacitor near the top of the input / microporocessor main board (second board from right) as this is prone to leakage, and check / clean any leaked electrolyte from this board. Icouldn't get a 0.047F capacitor so I used a 0.1F 5.5V one.
So far (touch wood) this has worked and I am running the amp as my main receiver for a while to make sure it's fixed the problem.
Hope this helps someone.
Serafis.
Aug 15, 2008 | Yamaha RX-V800 Receiver
RX-V800
if you can identify whats blown what ic or pcb board. you can get it replaced through yamaha. or many other various used reciever parts lists online. If you wanted to identify the transistor thats blown find it online and just resolder that one you could do that. But id say try and look into a replacement of the board. if you shorted the poles, then there will be a lot more damage on that channel then the amps final maximizer, or amp as you refer to it. -Thanks Nate
May 17, 2008 | Yamaha RX-V800 Receiver
Yamaha rx-v800 remote control's damaged
it can be accessed via the main unit controls but you need to go through your manuals. Maybe you can get your remote repaired still... maybe not badly damaged caused by corrosion.
[email protected]
Feb 04, 2008 | Yamaha RX-V800 Receiver
Problem in yamaha rx v800
Hello!!! Are you electronic technician? You should see the transistors Q22A, Q22C, Q19C e Q19A and its drivers on Main Board. All the best, Rasgador
Aug 03, 2007 | Yamaha RX-V800 Receiver
Problem in Yamaha rx -v 8000
your system goes on auto protect mode. it can be repaired even without the shcematics if this is the only problem.
what particular module is he asking for?
Jul 29, 2007 | Yamaha RX-V800 Receiver
Rx-v800 shuts off after few seconds
Hi, You should try to see, on main board, the ground G2(TP00385), just to make sure if the screw is too tight. Its location on Schematic Diagram (Main) is E8. All the best, Rasgador
Oct 27, 2006 | Yamaha RX-V800 Receiver
Will only power-on after multiple atempts.
That problem is well known problem with a memory capacitor on the stand up board that is the control board. It is .47F 5.5 volt capacitor that resembles a button battery. The cap leaks all over this board the fluid is conductive and corrosive. So the cap must be removed and the board scrubed clean with contact cleaned and dried before replacing with new cap. the unit can run without this cap but if the power should be removed all customer settings will revert to the default. also check the copper ground screws for tieghtness.
Aug 31, 2006 | Yamaha RX-V800 Receiver
Yamaha RX-V395 Receiver Logo
243 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
