Question about Sony Ericsson P910a Handheld
Touchsrcreen is stuck in some mode.
The touchscreen is stuck in some mode. when trying to access an application via the touchsreen it only makes the signal meter blink and sometimes the flight mode screen will appear .
  • 29 Answers
I would like to ask a couple questions that might be of some use.
First, does the same issue occur when using the phone with the flip closed? That is, can you use the jog dial and keys on the flip properly?
If the phone works fine with the keypad and jog dial, then you should be able to try to recalibrate the touchscreen.
To re-calibrate the screen:
1. Select Applications tab
2. Select Control Panel
3. Select Device
4. Select Display or Screen
5. Follow the instructions on the screen.
6. Select Yes or No
Second, if you turn the phone off and on again, with the flip open, does anything load by itself, or does the touchscreen react as if something is being pressed?
This may indicate that there is a problem with the hardware.
It is possible to purchase a new touchscreen for under $100 from a few parts retailers such as http://cnn.cn .
It may also simply be a glitch or bug in the software or firmware OS. In this case, you can try a master reset or updating the firmware using Sony Ericssons update service (not compatible with Vista for the P910), or you could use a third party firmware utility such as from DaVinci etc.
If you choose any of the master reset, firmware or update options, you will lose ALL user data on the phone, so you should back it up before you proceed.
Posted on Apr 02, 2008
My touchsreen isn't working anymore
Do you mean the touch function isn't working? Try reloading the lenovo drivers.
Do you mean the screen is dark or non functioning?
The usual cause is the flat cable from the body of the laptop to the screen is broken.
Warranty or repair shop.
Apr 12, 2014 | Lenovo IdeaPad S400 14in. LED Notebook -...
How do I change my email settings, windows 8
If you're computer doesn't have a touchsreen then go to the top-right corener and then down, you'll see Charms, click on Settings, then you're ready to change what you need to.
If you have a touchscreen then swipe in from the right and tap on Settings.
Feb 19, 2013 | Computers & Internet
My stop/clear and start buttons on my touchscreen are not working rendering the unit useless
Hi and welcome to FixYa. I am Kelly.
This is a keypad problem. Most keypads can be replaced. Some are all in one control panel and keypad units. Without a model number I can not provide you with a source for a keypad / outer panel. I note you said "touchsreen" so it makes me wonder what Appliance we are discussing. Make and model number please and I will see how I can help with replacement parts or keypad testing steps.
Thanks,
Kelly
Jul 20, 2011 | Maytag Microwave Ovens
How to calibrate touchsreen my samsung corby no wifi
Sorry dude but there's no Calibration service for all Samsung Corby handset since the phone is already using Capacitve Touchscreen technology. Just make sure that you are using original accessories for your handset because it really affects the performance.
Cheers!
Jul 02, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
I have a motorola blaze phone that turns on but the touch screen does not respond
the problem of your phone is the touchscreen maybe its broken, you need to replace the touchsreen
Jun 07, 2011 | Cell Phones
Touchsreen stoped working
these are hard enough to be self repaired .....pls take it to the nearest service centre asap..........:-)
Jan 13, 2010 | Computers & Internet
Touchscreen isnt workin need a solution
Try this:
First, do a reset of the phone, and see if the touch screen works at any time during the first few moments that the operating systems is running. I bet it doesn't though.
Second, take a business card and gently trace the edges of the display. If able, just barely put the corner of the card under the frame.
What you are trying to do is to dislodge any debris that may have gotten between the frame and the top layer of the display. If there is debris here, the phone may register it as a "touch" and prevent anything else.
Alternatively, and this is getting common with sliders, the delicate ribbon cable that connects the display functions may be starting to come loose. That will likely require mechanical intervention that your local Cell Phone Retailer may or may not be able to do onsite.
Aug 29, 2009 | LG Xenon GR500 Cell Phone
TouchScreen Freezes
i have same problem to,after reseting back to factory setting my touchsreen going freezes..
how can i fix it? please give me advice....
Jul 04, 2008 | Motorola Mobility E680 Handheld
My touchsreen doesn't work
GO TO MENU AND DO CALIBRATE DVD MAYBE THAT CAN HELP YOU
Aug 14, 2007 | Dual XDVD8181 Car Video Player
Sony Ericsson P910a Handheld Logo
178 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
