Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi 52'' TV Model WD52525
I have installed a new lamp and problem still there: After watching TV (Mitsubishi 52'' TV Model WD52525) for about 30-45 minutes sound and picture is gone and have a blue screen for about 25 seconds then the lamp light indicator starts blinkin green then tv shuts off - - -- - restart tv and repeats same sequence of events
  • Mitsubishi Master
  • 8,457 Answers
U restart the tv,u hear alots of clicking?That mean the Ballast is dead or have problems,that why ur picture lamp not sustaning the picture.Replacing the Ballast might or will sustance the picture.
Posted on May 18, 2010
SOURCE:
When tv is turned on got flickering picture. Checked bulb and bulb appears intact and in good condition. Bulb lights up for a second then shuts off then no picture. Any ideas? Mitsubishi wd52525 DLP
I suspect the B+ voltage on the power supply can't regulate the voltage needed for the lamps to run entirely. The B+ voltage regulator looks like a small black box with a tapered top. This is dangerous to replace so be careful. Once you get a new one installed this will fix the issue you are having.
Hope this helps :)
Mar 07, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Lamp Indicator is Red
Its much more likely that your getting a 34 error which is a lamp abnormality vaused by defective capacitors on the power board. You can get the V26 DLP power PWB repair kit at the following link that should repair the issue. Chances are your old lamp is still good.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
May 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green or blue vertical lines on my WD52525
it is not the lamp. the DM board is causing this problem. if the DM is going bad the FMT is not far behind. it will cost you $250.00 plus shipping one way. see www.tv-techs.com
Jan 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No picture no sound
it sounds like the chassis has gone bad. check out www.tv-techs.com
Dec 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green screen
sound like a DM or FMT board failure. this is not the 4 cap blinking green light problem. check out
www.tv-techs.com
Nov 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No picture and no sound after replace lamp for Mitsubishi WD-51525
did you use an original mitsbishi lamp. did it slide in easily? one of the most common problems with a lamp replaement is pushing the connector away from the lamp if it doesn't slide in easily. unplug the set, take out the lamp and look with a flashlight to see if the connector is in place. if so put the old lamp in and see if it works. if it does then your new one is bad. if it doesn't then email me
ima_rm2000@yahoo.com with your number and we can talk more.
ken
Nov 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD52525 DLP TV
Yes, this can happen and there also are fuses that needs to be changed(F9A09) and caps C9A37,38
Mar 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Dec 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525-Code 34-Sound OK-No picture!
I had another problem kinda the same and emailed ctechnicians.com and they gave the fix.
Nov 02, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
416 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
