Question about HP LaserJet 9040n Printer
Scanning How do I Scan a document with this printer
  • 813 Answers
Hi friend
open mycomputer u see there a scanner icon doble click on it then open microsoft scanner and camera wizrd click on next the after put the document in a scanner u whant to scan then after click on priview then after click on next then after click next then finesh
Posted on Apr 01, 2008
SOURCE:
  • 5 Answers
SOURCE: scanning
Many issues are caused when the HP All-in-One is connected to the computer using a USB cable before the HP All-in-One software is installed on the computer. If you connected the HP All-in-One to your computer before the software installation screen prompts you to do so, you must follow these steps: Troubleshooting common setup issues 1. Disconnect the USB cable from the computer. 2. Uninstall the software (if you have already installed it). 3. Restart your computer. 4. Turn off the HP All-in-One, wait one minute, then restart it. 5. Reinstall the HP All-in-One software. CAUTION: Do not connect the USB cable to the computer until prompted by the software installation screen.
Posted on Aug 19, 2007
SOURCE: HP Photosmart 3210xi Scanning Issue
no scan options refer to device documentation to troubleshoot
Posted on Jul 31, 2008
SOURCE: HP 6310 All in one scanning issue
hi
i just talked with hp,
They suggest i (re) install the right software version
via hp.com
click on drivers.
type in 6310 <ENTER>
then click on the right model link
then on the right Computersystem/OS
and then you can download
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1120043&lc=en&cc=us&dlc=en&submit.y=12&submit.x=3&lang=en&cc=us
Posted on Aug 30, 2008
SOURCE: HP Printer - Scanning Documents
i had the same problem with vista home premium. vista does not support one touch scanning (pressing the scan button on the printer). to use scanner with vista home os use the paint application and start scanning with the file section. step by step:
start (windows) icon lower left tool bar
programs
accessories
paint
file
from scanner or camera
the hp should start working - note: i sent a short cut to the desk top for the paint program for future use
Posted on Feb 04, 2009
  • 84 Answers
SOURCE: I have HP Officejet 4355 and want to use it for
open the top covers put the paper(s) in the automatic document feeder, use the software to scan and viola............ u wikk get them scanned....
Posted on May 14, 2009
How do i scan on my brother copier?
Scanning is a standard all-in-one printer feature that converts a hard-copy document into electronic information, which your computer can store and modify. You can scan legal files, office reports or just about any other kind of document and create an electronic backup for your files, send it as email or alter it to suit your needs. Follow these steps to scan a document on an all-in-one printer:
1. Turn on your all-in-one printer and computer. Check the connections between the two machines.
2. Lift the printer's document lid. Examine the scanning surface and the underside of the lid for dust and fingerprints.
3. Put the document you wish to scan face-down on the glass. Use the alignment markers to help you square up the object. These are usually found on the left-hand edge of the scanning area.
4. Close the printer's document lid slowly so the document does not shift position.
5. Select a scan resolution. The higher the dpi (dots per inch) count, the sharper and more detailed the image.
6. Push the scan button. You may have to do this on the printer itself or on your computer.
7. Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.
8. Edit the image as it appears on your computer if you want to make changes. Your scanning software might let you enlarge, resize or otherwise manipulate the final product.
9. Accept the scan and save. Return the original document to a safe location.
I hope you find it very helpful. Best regards.
Aug 17, 2011 | Brother MFC-9840CDW Laser Printer
I have a HP Photosmart 2575 xi all in one printer and I need to be able to scan documents and photos. I have no idea how to do it. How do you scan these things. I use the printer and the copier but have...
1. Turn on your computer, wait for it to boot up, then turn on the printer.
2 Double click the "HP Photo Imaging Director" icon on your desktop ( placed there when your
printer was installed on your computer ). A menu screen will appear showing the scanning
options of the printer.
3 Place your document or photo on the printer's glass top and close the lid.
4 From the menu screen, click on " Scan Picture " or " Scan Document "
When "Scan Document" is selected, a secondary screen will appear from which you will have to
make choices. After making your decisions, click "Scan" from the listed screen.
When "Scan Picture" is selected, one scanning pass will be performed, another pass will be
made after you view the result of the first pass.
Scanned pictures will go to the HP Photo Gallery and your "My Picture" folder.
Scanned documents will go to your "My Documents" folder.
Good Luck with your scanning operations!!
Jan 21, 2011 | HP Photosmart 2575 All-In-One Printer,...
How do i scan a document?
Hi, it all depends on the printer your using.
How to Scan a Document on a Multi-Function Printer
A multi-function printer with a scanner makes backing up your important documents easy. The scanner function of the printer allows you to translate a paper document like a receipt or title deed into an electronic copy that is stored on your computer. Once you have an electronic copy of your document, you can process and manipulate the document as you would any other electronic file. Follow these steps to scan a document on a multi-function printer:
Connect your multi-function printer and computer. Power them up.
Select the side of the document you are going to scan. Give the document a once-over, checking for any flaws that you do not want transferred into electronic form.
Open the printer's lid. Place the side of the document you want scanned face-down on the glass plate of your multi-function printer's scanning bed. Align the document to your satisfaction.
Close the printer's lid carefully. You may want to weigh the document down with another sheet of paper to prevent it from shifting.
Choose an appropriate scan resolution. You may have to do this using the controls of your printer or on the computer, depending on the model and software.
Press the scan button to start the process. This can be done on the printer itself or on the computer.
Preview the scan on your computer monitor. You should be able to make minor changes to the scanned image if needed.
Save the scanned image if you are satisfied with the result. Try again if you are not satisfied.
Tips & Warnings
Scanning documents at high resolution and low data compression will produce the best image quality at the cost of file size.
Not happy with a scan? Re-check the alignment of the document and try it again. Discard the duds when you get a scan that works for you.
Using harsh cleaning chemicals such as acetone or benzene can damage your multi-function printer. Abrasive cleaners are also not good on the machine, particularly the glass surface of the scanning bed.
....How to Scan a Document on an All-in-One Printer?
Hope it helps..
Oct 28, 2010 | Office Equipment & Supplies
How do you scan a document
Follow these steps :
•1
•2
•3
•4
•5
•6
•7
•8
•9
Oct 20, 2010 | Brother MFC 210C All-In-One InkJet Printer
How to scan multiple images into one pdf document
after scanning one page .. do not save the page but choose "add another image /page option " and scan accordingly.. and save the entire document after you are done with the scanning of all the pages.
Sep 30, 2010 | HP PhotoSmart C4280 Laser Printer
How do you scan a picture?
simply installoffice 2003 and there will be microsoft office tools select microsoft office document scanning select scan new document.....first of all u have to install printer drivers my dear friend
Mar 11, 2010 | HP PSC 1210 All-In-One InkJet Printer
Unable to copy from scanning bed
There is probably a little switch that gets tripped when the document feeder is in correctly. This is preventing you from scanning from the glass.
Jun 02, 2009 | HP Officejet 7310 All-In-One Printer
Touble scanning more that one page as a document
If you are scanning using the Scan to PC button, the unit will scan as you described. In order to scan multiple pages into one document, you need to go go through the Smarthru software, or whatever scanning software your unit includes. Since your unit is manufactured by Xerox, you can go to www.samsung.com and download the SmartThru software of your choice for free.
Sep 16, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Hp printer scanning prblm
Are you able to make copies only (just press copy color or copy balck and check)
And are you able to scan pictures.
If yes then make sure you are scanning from HP Director as Scan documents and follow the on screen direction.
If you do not get the option to scan documents then in HP Director go to> Settings> Scan Documents settings> You will see a option saying promt for these setting at the time of Scan> Put a check mark on that and click on Apply and ok and then try scanning document.
If this does not work the go to Start> Control panel (or Start> Settings> Control panel> Then printer and other hardware or Scanners and cameras> then Right click on the Printer icon> and scan from the options there.
Good Luck
Aug 22, 2008 | HP PSC 1315 All-In-One InkJet Printer
Scanning a combination of one-sided and two-sided documents
Use the "Separate Scan" button on the panel. By pushing this you are telling the scanner that you have separate scans to scan as one document. Once all files are scanned, push the separate scan button again to indicate you are finished scanning.
Oct 17, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
HP LaserJet 9040n Printer Logo
Clive
Clive
Ekse
Thomas F. Schneider
