These are the possible codes and the reason for occurence of this code in your copier
010-150, 155 -Too much or not enough paper in duplex tray
010-300 --Fuser thermistor,
010-302 --Low fuser temperature ,
010-304-- Bad fuser temp,
010-308 --High fuser temperature or open thermistor,
010-310 --High fuser temperature ,
010-312 --Fuser not up to temperature after energy save,
010-314 --Fuser problem ,
010-320 --Fuser web finished ,
010-330,327, 335, 340-- Exit switch, vertical sensor switch actuated when power is turned on
Thank you!!
SOURCE: XEROX WORKCENTRE 5222/5225/5230 A FAULT OR
010-150, 155 Too much or not enough paper in duplex tray 10-300 Fuser thermistor 10-302 Low fuser temperature 010-304 Bad fuser temp 10-308 High fuser temperature or open thermistor 010-310 High fuser temperature 010-312 Fuser not up to temperature after energy save 010-314 Fuser problem 010-320 Fuser web finished 010-330,327 335, 340 Exit switch, vertical sensor switch actuated when power is turned on
SOURCE: I have received an error code of 010-327 and I
Fuser thermal error. Check for paper wrapped around the rollers, but you will need to replace it.
PN 126K24980
Whit
Item, Inc.
SOURCE: fault code 010-327
This is a fuser error, so we'd start by replacing that. The fuser PN is 126K16480.
This particular error code may be a false error, in which case either the Power Unit 105E11370 or the MCU Board 960K09910 might be bad.
Whit
Item, Inc.
SOURCE: ERROR CODE 010-327
Solution : Power the Machine OFF and ON CAUTION: Wait at least 30 seconds between powering the machine OFF and powering the machine ON. Damage to the optional hard disk could occur.
IF THAT FAILS TRY THIS NEXT:
NOTE: If the machine is equipped with the optional hard disk, the machine remains on for approximately 10 seconds, while storing files and preparing for shutdown. The machine then shuts down completely.
Solution : Clear the Paper Jam Behind Cover A
For pictures on this procedure please follow link: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=218,E=0000000002703126506,K=8100,Sxi=4,Solution=obj(1027)
Hope it helps!
